HiFiVision.com - Audio Video Hi-Fi Forum
Wrong timing in Digital clock
Discuss Wrong timing in Digital clock at the AM/FM Tuners & Satellite Radio within the HiFiVision.com - Audio Video Hi-Fi Forum; Hi, I had bought a Sony Digital alarm clock with AM/FM radio from Singapore a ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > AV Sources > AM/FM Tuners & Satellite Radio
AM/FM Tuners & Satellite Radio AM/FM Tuners & Satellite Radio
Advertise Here
Reply
Thread Tools
  #1
Old 10th June 2010, 10:55 PM
Reputation points: 15
jayantadak is on a distinguished road
I had bought a Sony Digital alarm clock with AM/FM radio from Singapore a couple of years back. After coming home, I set the clock accordingly, it kept good time for 18-20 hours, and after that, it just goes crazy. Either it gains 10-15 minutes in 24-hours or looses the same. I tried it for a couple of days more, but it always gave the wrong time. I checked the same on battery too, still the same story.
I called the Sony guys here in Mumbai, and they told something about the problem of Hz. That digital clocks work on 60Hz in India, and this particular unit had 50Hz. Let me give the exact specs. 230V 50 Hz. Original showroom purchase, with bill warranty everything.
Well if the matter is so that it will work on 60 Hz, then it should at least work properly on the cells. The cells have nothing to do with our electric supply.
The brand new clock is lying somewhere in the dumps in my home, since I can't use it. Do any of our forum members have come across such problem, and have resolved it. Pl let me know.
Thanks and regards
JAYANT ADAK, Mumbai
Sponsored Ads
  #2
Old 11th June 2010, 04:53 PM
musicmypassion's Avatar
Reputation points: 43
musicmypassion is on a distinguished road
Re: Wrong timing in Digital clock
I have an unbranded digital clock with me and it is having the same problem. I tried to correct the timings several times with no use. Now it is running 50 minutes faster than normal time and I now got adjusted to it.
  #3
Old 11th June 2010, 05:05 PM
just4kix's Avatar
Reputation points: 1719
just4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant future
What the shopkeeper told you is not correct.
The problem is 50 Hz itself. All these electric digital clocks use the AC frequency as the clock sample frequency. In India, we do not get the constant 50 Hz. At some places the frequency is as low as 45 Hz while at some places is 50+ Hz. And this is not constant throughout the day.
Hence these digital clocks always loose or gain time.
A better (table) digital clock would be one with Quartz crystals.
  #4
Old 11th June 2010, 11:06 PM
I got a possible reasonable reply from just4kix. But I again fail to understand that how come it does not keep correct time on the battery mode as well. I believe batteries have nothing to do with 50/60 Hz.
JAYANT ADAK
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Wrong timing in Digital clock
Thread Thread Starter Forum Replies Last Post
what if this savant is wrong? suri AV Lounge 19 16th February 2010 12:38 PM
What is wrong with Donnie Brasco mahiruha Movies 4 20th January 2010 02:18 PM
PSU for clock upgrade cha_indian DIY 3 28th July 2009 09:31 PM
What could be wrong ? vinod_david Television 15 13th February 2009 11:59 AM
Upgrading Clock , I/V stage and regulators on a DAC sachi DIY 1 19th January 2009 08:16 AM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199
