| Discuss How to improve FM Reception quality at the AM/FM Tuners & Satellite Radio within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Hi all, I have a tuner and but the FM reception is not really good ... |
| AM/FM Tuners & Satellite Radio AM/FM Tuners & Satellite Radio |
Thread Tools |
#1
Hi all, I have a tuner and but the FM reception is not really good in my apt. I live in Bangalore and the apt is away from city. I have connected the FM indoor antenna ( aprox 2m wire on back of the tuner 75ohms FM ANT jack). But I hear lot of noise mixed up. 1) how to improve this? 2) Will it help if I extend this wire antenna to the roof top. This option is possible. 3) Do I have to buy any other type of FM antenna? Any pointers would be helpful. Sunil |
| Sponsored Links |
#2
Re: How to improve FM Reception quality
hi Sunil,
Did you buy the FM indoor antenna (75ohms FM ANT jack) in Bangalore? If yes, can you let me know where. Thanks. |
#3
Hi sunil, connect a long 75 ohms cable to a (dipole) television antenna, that's what i am doing....it works. If you have no access to TV antenna, use a alluminium hanger (without sleeve) mounted on roof top. check the attached image for ref.
Anil Quote:
#4
Quote:
* Buy a few meters of TV cable. The thicker the better. Specially pay attention to the main core. The solid wire at the center should be at least thick enough to be used as a contact point by itself. Also, don't buy the ready made pieces with connectors at both the ends usually available in the market (as they are mostly twisted in order to get packaged). Buy loose cable because the inner core should not have any twists etc (or at least as less as possible). * Buy a connector and fit it on one end. * Don't peel the other end. Just leave it smoothly cut. * Connect it to the tuner and lay down the free end on the floor in way it is as straight as possible. Some parts would be gone inside the rack/furniture. Once the cable has come out, try to keep it as straight as possible. * If possible, try to point it towards the TV transmitter, if you know its position (may help a bit more). Or play with the direction till you get the best reception. This will not boost the reception by a huge margin over the bundled wire antenna that you are mentioning, but will reduce the multi path problems resulting in a cleaner signal. |
#5
Thanks all for the suggestions.
I have the roof top access. So I will extend the wire to top. |
#6
dichkaun,
Actually I didn't buy. The FM wire antenna came with the tuner. Thanks, Sunil |
#7
I am away 45 kms from fm relay station. I took my old tv v type antenna supplied with my sony tv and tied it to a wooden post in the roof of my house. With co-axial cable with out any cut or joint i fed through my tuner no booster or anything. Nice reception. As if in the heart of the city i hear with hifi power pre amp so is the undistorted quality. Pay attention to the real good quality co-axial full length. Thanks give me your feed back
#8
The wire antenna supplied with my onkyo is not good enough. But when I wrap it around my tata sky cable the quality increases considerably.
Can I use a tata sky cable as an FM antenna directly? |
#9
Hi, use a dipole antenna or a aluminium hanger for improved FM reception, check the attached picture, this is what i have done [DIY way]
one more link; Dipole FM antenna ![]() Hope this helps. Regards, Anil |
#10
Guys,
I've got Marantz SR 4003 AVR & the antenna supplied is too short + I have bad reception (Mumbai) I am unable to figure the connector used by Marantz to connect the wire on the AVR. Please suggest what type of wire to be used? Thanks, Abhijit |
| Bookmarks |
| Thread Tools | |
Similar Threads for: How to improve FM Reception quality
| Thread | Thread Starter | Forum | Replies | Last Post |
| How to improve SQ dramatically for less than Rs.100 | gobble | Amplifiers | 8 | 29th March 2009 03:35 PM |
| Subwoofer improve Music SQ ? | ame | What Should I Buy? | 24 | 6th February 2009 07:15 AM |
| Picture Quality - DVD vs high quality downloads | sud98 | General Chit Chat | 3 | 28th January 2009 07:49 AM |
| Please help... I need quite a bit of advice to improve my setup... | gautamz | My Audio/Video Setup | 5 | 13th January 2009 10:08 AM |
| Tv Cable reception | mjamal14 | Television | 10 | 22nd September 2008 08:29 PM |
