Excellent Universal Remote OneForAll URC 8308 Kameleon 8
Discuss Excellent Universal Remote OneForAll URC 8308 Kameleon 8 at the Audio Video Accessories Reviews within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Hi, Just started using the universal remote control Kameleon 8 from Oneforall. Its excellent & ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > Audio Video Essentials > Audio Video Accessories > Audio Video Accessories Reviews
Notices
Reply
Thread Tools
  #1
Old 23rd September 2008, 02:47 PM
euclid1 is on a distinguished road
Thumbs up Excellent Universal Remote OneForAll URC 8308 Kameleon 8
Its excellent & what a great value for money!!!!!!!!!.
i hv presently 6 devices:
1.Philips lcd
2.Philips upscaling dvd player
3.Sony dvd player
4.Tata Sky set top box
5.Denon AV receiver
6.LG DVD/VCR Recorder
so wanted to go for a universal remote to remove the clutter.I narrowed down to 2 brands :Logitech & One for All.
i wanted to purchase the logitech harmony one (was priced reasonably in the US ;200$ which would amount to Rs 10000 approx.) But the launch price in India was a shocker Rs 18499!!!!!!!! i did not want to go for the cheaper Logitech 525 as it had nothing new to offer (no touch screen,no rechargeable dock etc.)
Thus i decided for the Kameleon 8 & what a right decision it has been.
It has an EL tactile touch panel which lights up on touching & looks really cool space age stuff.the keys light up according to the modes which is really convenient as the record,play,rew,ff functions are not available in the tv mode & vice versa. the respective key has to be pressed (remember its a touch panel) to use the function.personally i liked the tactile effect.
I configured all my devices in half an hour or so.there was a problem with the philips lcd code which was corrected the next day with a new code by the customer service.....prompt & quick.i also programmed a few macros yesterday (switching on the tatasky setop&tv together;dvd,amp&tv together)
The only minor problem which i hv faced till now is that you cannot customise the labels of the keys but as almost all the common keys are present so its not very inconvenient.it does not hv rechargeable batteries(powered by 4 alkaline AAA batteries) so will update later regarding its battery life.
And Now comes the clincher................the price: Rs 5999.You cannot really expect a touch panel full featured universal remote at this price!!!!!!!!
Three cheers to OneForAll.
U can check it out at :| Universal Electronics.
Sponsored Links
  #2
Old 23rd September 2008, 06:13 PM
alladinkachirag is on a distinguished road
Re: Excellent Universal Remote OneForAll URC 8308 Kameleon 8
That was an excellent for about an exciting stuff . BTW where did you buy it from?
  #3
Old 23rd September 2008, 07:04 PM
Dushie's Avatar
Dushie is on a distinguished road
Thumbs up Re: Excellent Universal Remote OneForAll URC 8308 Kameleon 8
1.Philips lcd
3.Sony dvd player
5.Denon AV receiver
I am myself interested in a univeral remote, but i not well versed with how to get it to work , as u need to input codes and other stuff, for various devices to work with it, if someone can shed some light on the process, it will be great.
i have the following devices which i would want to configure on the same -
Denon 1907 amp
Samasung Q9 plasma
Samsuing HD 860 dvd player
DM500S
Yamaha DSP A 496 Amp
will i be able to run the above devices with this single remote, and will all features works
  #4
Old 23rd September 2008, 07:27 PM
psychotropic's Avatar
psychotropic will become famous soon enough
hey DUshie, universal remotes work in two ways 1) codes and 2) learning. Most of the new generation universal remote controls can do both. Most universal remotes come with massive databases of codes supplied along with them, which can be programmed onto them for them to be able to almost fully replicate the particular remote control for which the code has been entered. Chances are most of your devices would be on this list.
Now if the codes are not available these remotes are capable of "learning" using the infrared signals from your original remote. essentially you have to point the infrared transmitter of your original remote to the IR transceiver on the learning one and press the original button on the original remote, and the corresponding button on the learning one (or some combination of actions like that) and voila, the learning remote would have "learnt" the function of the original remote. It's quite simple.
So although I am not specifically aware about the Kameleon (i hear very good things about it), most contemporary universal remote controls should be able to take care of all your needs. Do look at picking them up abroad though....much much cheaper there....there are even a few Sony models that cost in the region of 2-3k INR.
  #5
Old 27th September 2008, 02:54 PM
Quote:
hi,
U can easily buy it online from the various portals like : rediff,itdepot,etc.
  #6
Old 27th September 2008, 03:04 PM
Denon 1907 amp
Samasung Q9 plasma
DM500S
Hi Dushie,
i was also in a great dillema regarding the buying of a Universal control. But this one has been quite good for me till now.The code list given in the user manual is quite extensive & the toll free customer support will be able to provide the exact code for the device if u tell them the model.Moreover as Psychotropic rightly pointed out that the learning feature is present on these universal remotes which will easily allow u to program the non working buttons on the universal remote according to the original remote of your device.
Hope this helps you.
  #7
Old 29th September 2008, 01:52 AM
By the way I did a little digging around. The OneForAll guys also have a proper hard button universal remote (5 devices) and it is available for 1600 bucks. That sounds like a bargain. It doesn't have a display and stuff, but that you can really live without. Or else the Logitech Harmony 525 is available for about 5500 bucks. THis is again a very good remote.
  #8
Old 29th September 2008, 04:03 AM
ajinkya's Avatar
ajinkya is on a distinguished road
All the Kameleon remotes seem to have very bad reviews with battery life. They need 4AAA batteries and depending on usage, can drain within a week. There was also a problem with the motion sensor on the remotes being very sensitive to movement, thereby draining battery. The new versions seem to have a firmware option to disable the sensor. So make sure you get a 2008 model which has this upgrade.
Any One4All remotes which have rechargeable battery and are affordable? I don't much care for screen but would like a learning function.
  #9
Old 29th September 2008, 10:34 AM
Dushie's Avatar
Quote:
Any idea regarding the model no of the hard button remote , what make is it and what's the review for the same ,
  #10
Old 29th September 2008, 02:08 PM
This is the hard button remote that I saw. Products : URC 7556 Digital 5 | Universal Electronics . can't seem to find any reviews, but I doubt it would have a battery life issue, as it does not have an LCD screen or a motion sensor...two things that would cause battery drain......it has a learning function....and it costs 1600.......sounds like a good value proposition....i may buy it but not immediately.....probably once i get my hi fi setup as well....
Sponsored Links
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Excellent Universal Remote OneForAll URC 8308 Kameleon 8
Thread Thread Starter Forum Replies Last Post
Making Remote control universal vashok Audio Video Accessories 25 11th November 2008 07:46 PM
Questions - Universal DVD Player and more amol12 DVD players & DVD/hard-disk recorders 8 22nd July 2008 05:59 PM
Brand New One For All 6 Kameleon Remote Control For Sale Kaval For Sale 1 26th May 2008 04:02 PM
Logitech Z5500 in excellent condition for sale balablr For Sale 0 18th May 2008 01:53 PM
What makes an Excellent speaker ? Aryan Speakers 5 4th February 2008 08:37 PM
Copyright © 2006-2008, HiFiVision.com All Rights Reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
