| Discuss Mains power trip switch? at the Audio Video Accessories within the HiFiVision.com - India's Audio Video Hi-Fi Forum; thank u PbR , yes as Suhas said 1 556 Ic should suffice! but 555 ... |
| Notices |
| Audio Video Accessories Speaker stands, hi-fi racks, power conditioners, remote control, headphones, isolators, etc |
Thread Tools |
#11
Re: Mains power trip switch?
thank u PbR ,
yes as Suhas said 1 556 Ic should suffice! but 555 is 7Rs 556 may be 12Rs , so not tht big deal with 2 pieces of 555..verroboard 4X8cm will be 10Rs and should accommodate all the stuff except relay,which may be Mounted on the cabinet box.For mass production of the unit 556IC will be economical. Test your relay with the ckt , if it needs a higher current , 1 transistor[BC 548] is needed to drive , see relay circuits with 555 on internet u will get that relay driver ! ----------------------------------+ 9v ... ....................| .......................||c .......................||c Relay 9v .......................||c ........................| .......................|D| diode -> check online ckts ....................... | from pin3..27k.. b..../c -|~~~~|----| BC 548 ... ... ..... ..... . \e ..... ... ...... .... .| ...... ... ..... ... ._Gnd in that case the pin 3 will go to a resistor,relay coil one end connects to collector and other +ve rail,emitter grounded. |
| Sponsored Links |
#12
Pls dont go for an electronic circuit for such a simple requirement. What you can do is buy a single phase contactor, connect the mains on one side and the load on the other side. Now feed power to the contactor through a N/O micro switch. Wire the contactor in such a way that the switch has to be pressed to get the circuit complete. Once the contactor gets activated use the same for completing the circuit..
This approach will eliminate the dependancy of having an electronic circuit which make things complicated. |
#13
Thanks to all who responded...It will keep me occupied for some time!!
Rgds |
| Sponsored Links |
| Bookmarks |
| Thread Tools | |
Similar Threads for: Mains power trip switch?
| Thread | Thread Starter | Forum | Replies | Last Post |
| Power Cord Shoot-Out: 22 Power Cords Reviewed | Neal | Audio & Video Cable Reviews | 28 | 6th December 2008 03:33 PM |
| Voltage switch from 110 to 220 | Colecutter | Amplifiers | 6 | 1st May 2008 11:15 PM |
| Switch Off!!!!!!!!!!! | dinyaar | General Chit Chat | 54 | 1st May 2008 01:05 PM |
| Speaker Switch | paj4x4 | Speakers | 4 | 9th February 2007 07:47 PM |
| Mains Power supply and Hi-Fi | Mohan | AV Enhancers & Room Acoustics | 2 | 8th September 2006 12:32 PM |
