| Discuss Mains power trip switch? at the Audio Video Accessories within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Hi, I have my 2-ch music system, and tv connected, via a made-to-order extension, to ... |
| Notices |
| Audio Video Accessories Speaker stands, hi-fi racks, power conditioners, remote control, headphones, isolators, etc |
Thread Tools |
#1
I have my 2-ch music system, and tv connected, via a made-to-order extension, to the wall-plug, and am quite happy with such a power supply arrangement. (this set-up was previously connected via a ups, but since the ups died, for reasons not related to the load, I had opted for direct connection) The question I have: Is there a switch/relay/trip mechanism such that when the mains power goes off, the input get cut, and remains cut when the power comes back, UNTIL it is MANUALLY (or via a timer) reset? Cheers PbR |
| Sponsored Links |
#2
Re: Mains power trip switch?
Current electric circuits are fitted with a circuit breaker fuse system. If a fault develops, a switch is tripped. These trip switches are usually fitted near your fuse box, and near your electricity meter. When an fault occurs in the circuit, before blowing the fuse, these switches trip, meaning they move to 'Off' position cutting off power to your room and appliances. These trip switches are usually mechanical - this means that power is restored only when you re-set the switch to 'On' position manually.
Switches can trip for a number of reasons: * An over loaded circuit - too many electrical appliances used at once * A faulty appliance * Shorting dues to water or leakage * Faulty connections on appliance leads. If a switch is tripped, unplug all the appliances. Set the switch to on position. Plug the appliance one by one till you locate the faulty appliance. When you connect a appliance and the switch trips again, that is the faulty appliance. A image of a switch is shown below. Cheers |
| The Following User Says Thank You to venkatcr For This Useful Post: | ||
PbR (13th August 2008) | ||
#3
some ELNOVA Upss have that feature , i have a Elnova 500VA
it does the same ! if you want a low cost solution u can try the circuit attached ! kaushik Last edited by kaushik; 13th August 2008 at 05:35 PM. |
| The Following User Says Thank You to kaushik For This Useful Post: | ||
#4
Quote:
I am not sure if any ready made Switch is available to offer this exact functionality. Check with people who do panel wiring, pump-motor dealers . What Venkat has shown is a Circuit braker its operation is different than what OP has asked for. If no such device is available or found but expensive then a.A small electronic circuit can be designed to do this job. A realy + simple driving circuit (with latch) (just a Transistor and couple of resitors) with Push button (momentary action) make it on and a simple DC power supply to power this circuit. This is called as a Latching relay circuit. The Relay will actutally make / brake a big switch that in turn deliver / cut off powewr to . HiFI gear. When you power up the set up. (Latching) Relay is in OFF state so the big Swich is also OFF means there is no power to your HiFI gear. Now you need to press the Push Button, Relay will be ON (and because it is latching type, will remain ON as long as power supply is there) that will make the big Switch ON and power will be delivered to your HiFI gear. Now if power fails and restores back, Relay though powered will return to default OFF position and unless you press the Push Button no power will be delivered to your Hifi gear. I lost touch wiht electronic components market but such small gadget can be had for Rs 300-400. Find any Electronic Hobbiyst or final year engineering (Electronics) student, s/he will built this circuit over a week end. Hope this helps SUhas Last edited by SuhasG; 13th August 2008 at 05:19 PM. Reason: Typo, new lines added |
| The Following User Says Thank You to SuhasG For This Useful Post: | ||
#5
Quote:
Cheers, PbR |
#6
Thanks SUhas,
Yes this is exactly what I am looking for! Some time ago, when I described such a device to a household electrician, he could not understand it (or perhaps my tamil!!), hence the query. Cheers, PbR |
#7
Thanks kaushik, let me see if my electrician can do this!!
PbR |
#8
Quote:
If you want something with a timer based reset, these are also available with or without high/low voltage cut off, etc. Products Main |
| The Following User Says Thank You to awedeophile For This Useful Post: | ||
#9
Instead of 2 X 555 use 556 . It is 2 X 555 in one single package, more economical in terms of cost and PCB space.
#10
Sorry PBR and everybody else on this thread. I seem to have misunderstood the requirement.
PBR you seem to have got the answers you want. Cheers |
| Sponsored Links |
| Bookmarks |
| Thread Tools | |
Similar Threads for: Mains power trip switch?
| Thread | Thread Starter | Forum | Replies | Last Post |
| Voltage switch from 110 to 220 | Colecutter | Amplifiers | 6 | 1st May 2008 11:15 PM |
| Switch Off!!!!!!!!!!! | dinyaar | General Chit Chat | 54 | 1st May 2008 01:05 PM |
| Power Cord Shoot-Out: 22 Power Cords Reviewed | Neal | Audio & Video Cable Reviews | 1 | 1st April 2007 01:10 PM |
| Speaker Switch | paj4x4 | Speakers | 4 | 9th February 2007 07:47 PM |
| Mains Power supply and Hi-Fi | Mohan | AV Enhancers & Room Acoustics | 2 | 8th September 2006 12:32 PM |
