| Discuss Power Line conditioners at the Audio Video Accessories within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Originally Posted by arj This is the APC smart UPS right ? the 2KVA version ... |
| Notices |
| Audio Video Accessories Speaker stands, hi-fi racks, power conditioners, remote control, headphones, isolators, etc |
Thread Tools |
#21
Re: Power Line conditioners
Quote:
@vea: Battery power is the best power one can get. Thats the reason why online UPS systems are being suggested here. |
| Sponsored Links |
#22
Quote:
Now the question here: Whether to replace the stock power cord or not and if YES then how much to spend on a new Power cord This can be looked at in two different angles; Angle one: Whether stock power cord is sufficient in terms of Electrical characteristics:
Angle Two: Whether to spend thousands on some exotic power cord or just get a well made but reasonably priced power cord. (Assuming that existing power cord is lacking any of the electrical characteristic mentioned in Angle One and the replacement is required) Let us take the angle One first. Angle one is objective. Stock power cord can be examined for Electrical properties. If it is Okay then there is no need to replace as far as Electrical properties are concerned. However my experience is Stock cords are not sufficient enough. So we need to replace it with something better. One can use a well-made power cord like that of HP printer power cord or power cords made for Medical Equipments. Those are not that expensive and can be had for Rs 300 to Rs 500. One gets some DIY power cord (from some small operators/ Hobbyist) for about Rs 1000 to Rs 2000. One can buy those exotic power cord from those big cable makers , costing anything between Rs 5K to RS 25/50K. Now we have 3 varieties of power cords;
All three cords meet Electrical properties needed for my HiFI gear. Now here Angle two comes into picture. Angle Two:
My listening tests showed that there is NO difference between a Rs 300 HP printer cord and Rs 1000 DIY cord and Rs 5000 Big brand cord (I couldnât get Rs 25000 cord for trials) What so ever small changes I did observe were nothing but a Placebo effect. Cables and power cords are the biggest mark up value items in any HiFI dealer's inventory. So there is always a tendency to promote such items by making you believe that : â Once you spent Rs 200k for this HiFI gear then it must be powered by a Rs 25000 power cord.â " You won't get the real sound from this Rs 150K system unless and until you put Rs 10K power cord" Don't eneter into this trap. [b]So my conclusion here is:
Hope this helps. Last edited by SuhasG; 17th August 2008 at 10:56 AM. Reason: Typo, additions |
#23
may be my post came out a bit different what i mean to say is that a servo stabiliser is anyday better than the offline UPS..but the online UPS is far ahead anyday.
#24
I think most of us are making judgement without ever trying a good power cord or power conditioner.
If ONLINE pure sinewave UPS's were good for music than every one would have been using UPS around the world by now as it is readily available. I agree there is a huge mark up in high end audio specially power cords and plugs and interconnects and speaker cables.. Also a customer doesn't really get a chance to audition and hear the differences specially home auditioning in his system. This leads us to make generalised assumptions based on electrical properties of cables or based on general assumptions only. I also used to think the same way before but changed my mind after listening to differences myself. Now how much one should pay for these cables has to be decided by every indivisual based on his pocket and his system. There are very good reasonably priced Interconnect and power cables and power cords available but we don't get chance to try and select. and without listening it is very difficult to decide. If a system is of moderate value say NAD integrated amplifier with a NAD CD player with a bookshelf speaker probably expensive power cords may not make much difference. But surely good Interconnects and speaker cables will make sound much better. I must have tried more than 15 brands of interconnects/speaker cables and if i change one interconnect in my entire chain i can notice the difference. I give lot of importance to all kinds of cables. As one move up and start upgrading his system he feels real need to upgrade his cables to get best out of his system. There definitely is LOT OF hipe and over pricing no doubt but we certainly cannot ignore benefits of good cables power or system cables and power conditioners. Also it is not necessary that a higher priced cable will sound good for sure. So it is a big RISK unless you hear it yourself. The main reason of higher price is limited market and emotional blackmail of music lovers. An audiophile will always be looking to improve his system as he is never satisfied and this is what manufacturers are looking at. Also there are people who are willing to pay these prices in US and europe specially. Just try to change wall outlet to which your system is connected to Hubbel or PS Audio and I am sure you will notice the change. |
#25
I started this whole affair,and uptil now member from different places in India have replied,after going through all this i assume that all the members discussing the points are from cities where there is power outages and surges,while in Mumbai,we are having normal stable power supply,with no surges or outages,in this situation i expect members to suggest keeping the stable power input in mind,if i change power cords or add power conditioners,or spike busters or add battery powered supply,will it improve sound as quite a lot of amplifiers use batteries for power line input for clean power supplies.also keep in mind that i have ordered valve amplifier,which consumes lots of power and if yes which make is available in mumbai or india
#26
Thats quite true..and a very important factor
I spent around 2 years in Singapore..power there is very very clean. i actually found a power conditioner to affect the dynamics negatively. in Paris, considering i lived in an apartment complex the Source and the pre sounded better via a conditioner while the amp was better directly plugged In bangalore..i just cannot use direct power without a conditioner ! i am planning on upgrading my power outlet with a Oyaide very soon and if possible a separate line in from the main transformer to see if it makes a difference. If not an online UPS might be the only option But Mekr, from what i could figure out the Audiophile purepower products (http://www.audiophileaps.com/) seem to be very highly rated and are battery driven. the older PS Audio systems used to be basically a Push pull power amplifier utilizing a pure sine as its Pre amp input ..which meant only around 50% efficiency although i hear the new models use a different design. although they still do nt use batterys and are dependend to some extend on input power But i have been recommended APC smart UPS (what reignofchaos mentioned)as something which is not a classical UPS. it actually Shapes the waveform as well as it was meant for sensitive medical equipment which needs pure power as well.. you should be able to try it out as APC are quite customer friendly..only dont explain too much regarding audio to them as they look quite zapped then
#27
Quote:
On another thoughts about "high priced power cable promoting industry" - do they also change internal wiring in my house - because that in some cases could be weakest link. Thinking further in these terms there is no limit! |
#28
Quote:
In most advanced countries, reasonably clean power is available 24/365, and for general household usage there is no need for an UPS. Of course UPS and generators are installed for critical application such as a hospital, a computer centers, etc. In these places Audiophiles try to take their products one step ahead of the competition by power regeneration, power cleaning etc. My point is that in India, there is no guarantee that power will not get disconnected any minute, leave alone clean power. if you connect a multi meter to the mains at 220V, you will see the needle constantly jumping. That is the reason I was looking at an online UPS as against a servo controlled stabiliser. If the UPS provides constant voltage and frequency within tolerable limits and adds a small back up time to boot, why not? They certainly look better that a stabiliser !!! ![]() In any case, over the next few days I plan to visit the offices of Numeric, Krykard, and Vertex to see what their technologists say. Things will be clearer in my mind after that. Of course an UPS has the liability of a battery maintenance. At the same time, modern UPS come with maintenance free batteries that are warrantied for 2 years. Quote:
Quote:
My wife listens to music on a simple 2-in-1 for an hour or two in the morning, and she just does not care about anything except that the music should play. I was the one who went to umpteen shops, heard umpteen systems, before zeroing in on a 2-in-1 that I felt sounded nice. Believe me, the max music I hear is in my car's system when I go in for long distance drives. I have a simple JVC system connected to Boston speakers. No sub, no power amplifier, nothing. But for some strange reason, the speakers completely disappear, and the music floats across the car at your ear level. The speaker cables are what came with the car. Maybe If I change the cables, the sound may be better. But my JVC dealer and I agreed that this sound is good enough and not to rip the car apart to change the cables. I have sat in many cars with hyped up music systems, and always felt like running back to my car and 'cleaning' my ears with a few minutes of nice music. ![]() When we listen to music in a car we readily accept the environmental noise made by the engine and the traffic. But will we accept such a thing in our music and HT rooms? No way. Let us get down to enjoying our music and movies. Cheers |
#29
I think this topic is done with now and getting boring. Believe me, this thread will go on and on and on with no real conclusion. Cable topics are always volatile on all forums as both sides have strong opinions and theories on the subject.
Mekr, If your neighbour uses a light dimmer or appliance with a poorly designed speed controller (hair dryer, etc.) on the same circuit as you, you have EMI and noise in your power. In an apartment in Mumbai, you probably share a power line with many others. Voltage may be constant, quality may not. I suggest you try and borrow some cables and a power conditioner and try them. If you hear a difference you like, buy them. If not, consider yourself lucky for saving money and spend it on some CD's. There is no other way to know. Last edited by awedeophile; 17th August 2008 at 02:06 PM. |
#30
Powercords and power conditioners definitely make a difference. Each cable and conditioner brings its own character. I have owned the Shunyata Hydra 8, the Powerwing and currently i use the RSA Haley. They definitely bring improvements. A much quieter background is what you immediately get. The cd player and the preamp benefit the most. I have not had a great experience using conditioners for tube amps. However SS amps benefit. This has been my experience.
| Sponsored Links |
| Bookmarks |
| Thread Tools | |
Similar Threads for: Power Line conditioners
| Thread | Thread Starter | Forum | Replies | Last Post |
| Power Cord Shoot-Out: 22 Power Cords Reviewed | Neal | Audio & Video Cable Reviews | 28 | 6th December 2008 03:33 PM |
| NewCDP Line | odyssey | CD Players | 42 | 19th November 2008 11:06 PM |
| Power Conditioners | ChetanSouthMumbai | Audio Video Accessories | 8 | 1st August 2008 10:26 PM |
| TDL RTL3 Transmission Line Speakers (UK) | Srinath_Murthy | Speakers | 0 | 25th January 2008 04:17 PM |
| DIY transmission line speakers | Anil kumar | DIY | 0 | 5th September 2007 04:08 PM |
