| Discuss Power Line conditioners at the Audio Video Accessories within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Which are best power line conditioners for local voltage are available in Mumbai or abroad,which ... |
| Notices |
| Audio Video Accessories Speaker stands, hi-fi racks, power conditioners, remote control, headphones, isolators, etc |
Thread Tools |
#1
Which are best power line conditioners for local voltage are available in Mumbai or abroad,which may be best for Hifi equipment,Further i am currently using direct power from my residential power line,what measures can be used for enhancing and improving the sound of my Hifi
| Sponsored Links |
#2
Re: Power Line conditioners
Quote:
If you are talking about Mumbai then you don't need any power conditioner. Power conditioners, stabilizers, UPS etc at the best can be considered to protect your expensive HiFi gear from over voltage / surges and spikes and brown out conditions. These devices won't contribute much towards enhancing and improving the sound, less than 1-2%. Power cords also fall under this category, you may notice a minuscule difference but mostly it is a placebo effect and nothing else. if it is not reasonably priced (Rs 500-1000 at the most for a 1.5 m power cord) then it is a snake oil. Clean power helps but for that you need to invest in Power regenerator and that might cost more than your entire system put together. Changing tires of Maruti M800 will increase its safety rating but it won't convert it into a Ferrari (or Honda at least). Hope this helps SUhas Last edited by SuhasG; 14th August 2008 at 12:21 PM. Reason: typo |
#3
Hello mekr
Pls check SU-KAM Line Interactive UPS on web and talk to their engineers , im sure this will help you & you dont need to worry much for after sles service ! hope it will help |
| The Following User Says Thank You to sandhutar For This Useful Post: | ||
robot (15th August 2008) | ||
#4
Quote:
Most people believe that power conditioners actually degrade the sound and recommend against using one. This again depends on the per quality. If your power quality is poor and there is risk of damage to your equipment, then you have no choice but to use one. Again, the amount of difference it will make totally depends on your existing power quality. I personally use a regenerator as we have horrible power in my area with frequent spikes, surges, brownouts, etc., etc. and have had many blown power supplies in the past. I too feel that a regenerator is the best thing for bad power but it is expensive. The best part though is that power cords connected after the regenerator make little or no difference. |
#5
Quote:
I too agree with the power cable aspect, have experienced pretty significant differences. As mentioned above it also depends on how much EMI/RFI you have and whether your power cable has this shield or not, believe it or not, not all power cables have this shield to start with. My recommendation - instead of buying a good power conditioner, but a good double conversion online pure-sine wave UPS such that it always runs of the battery and this will sound much better than any good power conditioner as your power source (batter) is next to your equipment. cheers |
| The Following User Says Thank You to odyssey For This Useful Post: | ||
#6
#7
I too have experienced some minute changes brought in by a well-made power cord from Cadence Bangalore based dealer. But...this But is very important ...those changes are very very minute in nature or could be a borderline case of placebo effect.
I use HP printer cables costing Rs 300 (each) instead of stock power cords and that serves my purpose well, no need to spend even Rs 1000 on power cord and make those special efforts to listen those very minute scale changes. I wrote a small review (in a hurry) on that (Cadence Bangalore based dealer’s) power cord (on the other forum) but now I openly confess, it was nothing but a Placebo effect. My hearing is good, my system (all Cadence) is revealing enough, my listening room is appropriately sized, my music is well recorded and I got training in Indian Classical music by Pandit Arvind Gajendragadkarji so I know how and what to listen in a piece of a music. In my case it was Rs 1000 (+100 towards shipping) so I really don't care much for the money I wasted like this. But when people claim power cord to be a system-improving tool then that becomes a snake oil for me. I have seen, people putting $1000 power cord for a $400 CDP! If at all they are so much bend to spend , they are better off by a $1300 CDP and at the most $100 power cord for it. Being an Electrical Engineer by training I can short list here, what is needed:
If existing stock power cord is not meeting the above mentioned criterions , then do replace with one that meets but spending in tune Rs 5000 to Rs 20000+ is outright insane. Now regarding power conditioner / Servo Stabs/ UPS. I myself use KryKard 3 KVA Servo Stab with built in EMI –RFI filter . I have taken care that current capacity of my Stab is atleast 3 times more than worst case current requirements of my amp. I would have loved to have a UPS here but the cost of Pure Sine Wave UPS with required current rating is prohibitive. My sincere appeal to those advocating an UPS (Venkat it is you!) please go that extra mile , contact UPS manufactures (NO SUKAM please) , find out prices and publish that data here so people will have a clear cut idea of what it takes to put an UPS in the chain. Same is true about Power regenerators, can anybody put forward information about brands , availability in India , Service support position and ball park pricing? Stand alone Power line filters or terminal strips with small filter devices. If you are looking at Made In China thing, may God Bless You. That’s all I want to say. Other brands Monster included , mostly use cheap components and MOVs. MOV can protect your system from voltage surges and spikes but not for long. After every such surge attack, it weakens and one fine morning it simply fails and exposes your system to those spikes again and that too without you knowing it. Other filter components are mostly RC networks but such simple networks won’t provide much of a protection. You need to spend quite a lot to get some real protection. In most well made HiFI gear such care is already been taken and that’s why reputed brands don’t recommend any Power conditioning devices, they simply say, connect the equipment direct to your wall socket. Audio and HiFI is very subjective and many times what we call as a difference is in fact a Placebo effect. There are enough Double blind tests carried out all across the globe to substantiate this point. Hope this helps. SUhas Last edited by SuhasG; 14th August 2008 at 10:08 PM. Reason: Typo |
| The Following 3 Users Say Thank You to SuhasG For This Useful Post: | ||
#8
SuhasG:
I was propagating the use of an UPS as a via media between a expensive stabiliser/line conditioner/isolation transformer on the one hand and an inverter on the other. An UPS with a 15 minute shutdown will suffice for audio and video. At least you can shut down a movie at an appropriate place, and allow the DVD player to remember where the playing was stopped. Similarly with music, you can stop the song, remove the CD, and start the shutting down process of all the equipment. Regarding power cords, I am bit skeptical to say the least. In my mind it is a very simple logic, When the power reaches the supply point cleaned, stabilised, and filtered, how can a power cord which is just a passive unit make any difference? Does it have any internal electronics to clean the power some more, unless just passing power through those cables does something to the power? If such a material were really available, it's specifications will be available to all physicists. The only thing the cable can do, and this is simple physics, is absorb some energy from the power flowing through it. If you remember, I had mentioned about Bryston's claim not to do anything, but connect directly to the mains. They claim all the stabilising and cleaning is done by their internal power unit that converts to DC and requisite voltages. I have read innumerable articles on this, and including blind tests, I have not read any scientific and believable data. Again, please remember, power passing through a cable can be very accurately measured at both ends. It is the lack of these measurements that have forced blind tests, and even they have not resulted in any acceptable percentages. According to Stereophile and other magazines, blind test results on power cords are less than 49% consistent, and that is a statistical no no. I don't want to argue this point. In my mind, I need to see something with my eyes that is logical before I can believe my ears. Regarding prices for UPS, here is what I have been able to find in the market. It is not as bad as we thought it will be. APC - 1KVA - Rs.5,850 APC - 2KVA - Around Rs.15,000 (Can be reduced with lesser batteries) Microtek - 1KVA - Rs.3750 Microtek - 2KVA - Rs,12,000 Emerson - 2KVA - Rs.32,400 All are 15 minute back up time. In UPS, the prices depend upon the back up time. Numeric and Krykard also have similar prices, though Krykard does not favour the consumer market any more. I mentioned the Emerson for comparison. They are for industrial use, and have very fast switching time, plus RS232C interface for continuous data logging, a fancy digital screen, etc. Under pressure the Emerson dealer I spoke to was ready to cut some 4 or 5 K. So for around 27K you get real time protection. Cheers |
#9
Venkat, Thanks for the detailed reply.
Let us take that UPS thing first because that was my straight question to you. Your price list seems to be inclusive of Batteries. Get prices w/o batteries. Further UPS can be of different types On-line, off Line, Line Interactive (they call it so) prices and performance varies accordingly. Mere prices won't help here complete specs are also needed to carry out some evaluation. Out of the list you provided only Emerson - 2KVA - Rs.32, 400 sounds Okay provided it is true/pure sine wave type. But 2 KVA rating is misleading or rather insufficient to determine its suitability. I guess it is steady state rating. What about In Rush current ratings? Further 2 KVA rating may not be sufficient for moderately rated power amplifier. I remember somewhere we two discussed KVA rating required w.r.t. Amplifier ratings. Regarding APC and Microtek I am doubtful. My idea of having an UPS in the chain is to run HiFi gear entirely on battery power. In such an arrangement I need just an Inverter but of Pure Sine Wave type. HiFi gear will always run of that Inverter as if AC mains is failed. Mains is used only to charge batteries. While playing music Inverter is physically disconnected from mains. Music will play as long as batteries are having enough juice. But I am yet to find such an Inverter that can do this job w/o costing me a bomb! Anyway, on Power cord it seems you agree with me. Regards SUhas |
#10
Cost is relative at not the point - the point is whether a cable makes a difference.
These threads on "cables making a difference" always amuse me because most people rely on what they have heard from reviews and "scientific data" they have read, but most have not experienced it. And the funy part is I used to say the same things before I "heard" the differences. Anyways, seeing where this is headed and having been there many times, I will not comment further on this subject. All the best! |
| The Following User Says Thank You to awedeophile For This Useful Post: | ||
| Sponsored Links |
| Bookmarks |
| Thread Tools | |
Similar Threads for: Power Line conditioners
| Thread | Thread Starter | Forum | Replies | Last Post |
| NewCDP Line | odyssey | CD Players | 42 | 19th November 2008 11:06 PM |
| Power Conditioners | ChetanSouthMumbai | Audio Video Accessories | 8 | 1st August 2008 10:26 PM |
| TDL RTL3 Transmission Line Speakers (UK) | Srinath_Murthy | Speakers | 0 | 25th January 2008 04:17 PM |
| DIY transmission line speakers | Anil kumar | DIY | 0 | 5th September 2007 04:08 PM |
| Power Cord Shoot-Out: 22 Power Cords Reviewed | Neal | Audio & Video Cable Reviews | 1 | 1st April 2007 01:10 PM |
