| Discuss Availability of Wall Mount brackets for 10 - 15 Kg Speakers at the Audio Video Accessories within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Hi Everyone, I was wondering if anyone knows where to buy good wall mount brackets ... |
| Notices |
| Audio Video Accessories Speaker stands, hi-fi racks, power conditioners, remote control, headphones, isolators, etc |
Thread Tools |
#1
Hi Everyone,
I was wondering if anyone knows where to buy good wall mount brackets for home theater speakers. I have Polk Audio LSi7 (surround) and LSi9 (Front) speakers weighing 10 and 15 Kg each respectively which I would like to mount - using brackets that are multidirectional. The LSiC (center) can nicely sit on top of the shelf (just beneath the LCD). I live in Ludhiana (Punjab) and so if anyone knows a nearby shop that stocks good wall mounts - that would be highly appreciated... Thanks! |
| Sponsored Links |
#2
Buddy
Welcome to the Forum ...!!! Have a nice stay here...!!! Buddy, as per the mounts are concerned for the speakers... instead of going in for the premade stuff... What i would suggest you is to go in for...the custom made mounts... go in for any good shop famous for all the iron works... Basically who works out equipments for special doors, tables angular, and all... They will make a support for all your bookshelf with nice mountings, and will include a angular ball/system in it, so that it will rotate left, right, up & down... That should cost you accordingly the weight and size of the speaker, but should go around Rs.2.5-4K each... And bargain for more number of mounts... Because if you will ask some proffessional or your dealer, they will charge you not less than, Rs.6-8K each... |
| The Following User Says Thank You to mridulgoel For This Useful Post: | ||
Dylanite (12th October 2008) | ||
#3
Re: Availability of Wall Mount brackets for 10 - 15 Kg Speakers
Thanks for the advice, man!
#4
Quote:
Dear you can try jeetander he can help you with good wall brackets 9999304774 . |
#5
Please visit www.jenefas.com. They make wide range of wall brackets for TVs and home theatre speakers. |
| Sponsored Links |
| Bookmarks |
| Thread Tools | |
Similar Threads for: Availability of Wall Mount brackets for 10 - 15 Kg Speakers
| Thread | Thread Starter | Forum | Replies | Last Post |
| Concealing in-wall speakers | raman340 | Speakers | 40 | 16th December 2008 11:05 PM |
| blu-ray availability in india | Eddierockks | Movies | 9 | 22nd September 2008 01:08 PM |
| For Sale Panasonic PT-AE1000E 1080p Full HD Projector with Free HDMI Cable and Ceiling Mount | rohit1712 | For Sale | 9 | 20th September 2008 04:46 PM |
| wall plates for A/V connections | zelda_venom | Audio Video Accessories | 2 | 13th April 2008 09:55 PM |
| speaker mounts or brackets??? | zelda_venom | Audio Video Accessories | 2 | 2nd April 2008 01:33 PM |
