| Discuss Vanguard wall mounts at the Audio Video Accessories within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Has anybody used vanguard tv mounts. Cantilever mounts which can be moved front and sides. ... |
| Notices |
| Audio Video Accessories Speaker stands, hi-fi racks, power conditioners, remote control, headphones, isolators, etc |
Thread Tools |
#1
Cantilever mounts which can be moved front and sides. What is your opinion ? My doubt is VM 435 says 23-37" but max weight is 40 kgs. If a 40" tv is 19 kgs can I use this ? instead of a VM561 which is for 32 -50" since it is very expensive. |
| Sponsored Links |
#2
Re: Vanguard wall mounts
A couple of my freinds are using the vangaurd stuff for some time & seem to be satisfied i.e no complaints till date. Though i'm unaware of the models you've mentioned so can't comment.
All the best. Cheers. |
#3
thanks neo. i have ordered VM 531, lcd mount. for 9k.
It has a narrow foot print and it looks good. Even omnimount has these things marketed by onkyo. |
| Sponsored Links |
| Bookmarks |
| Thread Tools | |
Similar Threads for: Vanguard wall mounts
| Thread | Thread Starter | Forum | Replies | Last Post |
| Concealing in-wall speakers | raman340 | Speakers | 40 | 16th December 2008 11:05 PM |
| Availability of Wall Mount brackets for 10 - 15 Kg Speakers | Dylanite | Audio Video Accessories | 4 | 13th October 2008 04:17 PM |
| wall plates for A/V connections | zelda_venom | Audio Video Accessories | 2 | 13th April 2008 09:55 PM |
| speaker mounts or brackets??? | zelda_venom | Audio Video Accessories | 2 | 2nd April 2008 01:33 PM |
| Great Stand Mounts | dinyaar | Speakers | 7 | 6th January 2008 05:10 PM |
