Zephyr Power Conditioner + Halcyon Voltage Stabilizer
Discuss Zephyr Power Conditioner + Halcyon Voltage Stabilizer at the Audio Video Accessories within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Audire Technologies introduces its newest lineup of power conditioners and voltage stabilizers. Featured in the ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > Audio Video Essentials > Audio Video Accessories
Audio Video Accessories Speaker stands, hi-fi racks, power conditioners, remote control, headphones, isolators, etc
Advertise Here
Reply
Thread Tools
  #1
Old 18th January 2009, 01:11 PM
sandeepnaird is on a distinguished road
Audire Technologies introduces its newest lineup of power conditioners and voltage stabilizers. Featured in the January issue of Av Max Magazine, Audire's power conditioner is a budget oriented high performance power conditioner specifically made to suit the Indian power scenario. Completely built in India, this scalable system is custom configured to the customer's specific application, and has output capabilities ranging from 1kVa and upwards , for residential and commercial usage. The salient feature of this power conditioner is its ability to clean up your existing power supply, giving you a huge performance improvement in both audio and video. The audio signals become much cleaner, transient and life like, while the black levels and contrasts in video are enriched. Further features include mains isolation, q transformation, line filtering, balanced power output, high voltage cutoff, spike suppression, and delayed switch on on selected outputs. The basic system can be upgraded to any extent, including the usage of high end internal wiring, high end power cords and the best output sockets in the world. The Zephyr is built on Audire's twenty year experience in the medical power electronics field, and it is truly the easiest and most cost effective way to get much more from your existing system. You will be surprised by the amount of difference clean power makes to your system.
Audire also makes a halcyon servo addon system to the zephyr package to manage ungainly fluctuations in voltages.
For more information please do contact us from the contact page in our website:
http://www.audire.in/contact.html
Sponsored Links
  #2
Old 13th May 2009, 12:59 AM
manu4panjab's Avatar
manu4panjab is on a distinguished road
Re: Zephyr Power Conditioner + Halcyon Voltage Stabilizer
how much does it costs
  #3
Old 13th May 2009, 11:53 AM
gobble's Avatar
gobble has a spectacular aura aboutgobble has a spectacular aura about
Nice. Do you have 1.5kva also? What is the "not so high-end" wiring option that you use in the stock product?
TIA
  #4
Old 13th May 2009, 12:10 PM
yes we do have a 1.5 kva standard power conditioner and servo system to go with that as well. not-so-high-end would be high quality fireproof teflon-sleeved copper wiring with gauge varying with application. These cables withstand very high temperatures easily. On request we even use ultra pure 99.9% oxygen free buss bars.
  #5
Old 9th June 2009, 03:49 PM
avexplorer is on a distinguished road
None of the links mentioned seem to be working. Whats the way getting these products in Bangalore
  #6
Old 24th September 2009, 10:08 AM
santhol2's Avatar
santhol2 will become famous soon enoughsanthol2 will become famous soon enough
Bump!!
The website does not work. Does anyone have any info about audire in India?
Thanks in advance!!
  #7
Old 24th September 2009, 10:30 AM
myriad is on a distinguished road
Hello Santhol,
You can contact Sharath Chandran on +919003355444 or V.S. Chandrasekhran on +919894722600.
Vasu
The Following User Says Thank You to myriad For This Useful Post:
santhol2 (24th September 2009)
  #8
Old 24th September 2009, 03:18 PM
santhol2's Avatar
Quote:
Originally Posted by myriad View Post
Hello Santhol,
Vasu
Thanks Vasu, I spoke to Dr.Chandrasekharan this morning. Fantastic gentleman, he seems to be very passionate about music too.
After listening to my requirement\setup, he advised me not to buy the Servo Voltage Stabiliser as it will be redundant if I buy a UPS. He advised me to first go in for an Online UPS (Double Conversion Sine Wave)and then only think of a Power Conditioner. The 2KVA Zephyr Power Conditioner is based on an Isolation Transformer and costs around 18k.
  #9
Old 24th September 2009, 08:50 PM
cmsajith's Avatar
cmsajith will become famous soon enough
Its depends on the requirement. You need to check whether to spend on an online UPS for an audio-video setup, its really expensive. Plus he was recommending for another 18K for conditioner.
If you are planning for your entire house and hence planning to include this as part of that, servo stab will be redundant. If it is just for audio-video, a good quality servo stab is more than enough.
  #10
Old 24th September 2009, 09:17 PM
Dear Santhol,
There is one thing i found after using Zephyr and Monster Power Conditioner that they are not suitable for amps. In some instance they may be good for source but they are not at all good for amps. So, better try it before you buy. IMO two dedicated power lines from the mains, one for analog and one for digital will give you better performance than any of these conditioners.
Vasu
sameer kumar (24th September 2009)
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Zephyr Power Conditioner + Halcyon Voltage Stabilizer
Thread Thread Starter Forum Replies Last Post
Suggest A Voltage Stabilizer ram_mohan_p Audio Video Accessories 45 22nd May 2009 01:38 PM
Voltage stabilizer dichkaun Audio Video Accessories 11 8th February 2009 12:38 PM
Voltage stabilizer required? gobble Amplifiers 13 14th January 2009 11:29 AM
AV Rack & Power Conditioner in DELHI spycatcher Audio Video Accessories 7 13th October 2008 03:26 PM
AV Rack & Power Conditioner in DELHI spycatcher Audio Video Accessories 1 29th August 2008 01:24 PM
Advertise Here
Copyright © 2006-2010, HiFiVision.com All Rights Reserved.
Recommended Websites - www.CameraVision.in
