| Discuss Audio Rack Shelves? at the Audio Video Accessories within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Hello, I have a big rack to accomodate both my Stereo & HT rig. I ... |
| Audio Video Accessories Speaker stands, hi-fi racks, power conditioners, remote control, headphones, isolators, etc |
Thread Tools |
#1
Audio Rack Shelves?
Hello, I have a big rack to accomodate both my Stereo & HT rig. I got this rack made when i was just a newbie. The shelves of this rack are all 1/2" glass which is making sound thin and tizz at high frequencies. I tried MDF instead of glass which made sound bass heavy with less clarity. Is there any other material for shelving which is more neutral then glass and MDF ? Regards Vasu |
| Sponsored Links |
#2
Re: Audio Rack Shelves?
Not sure how big your shelves are .. and i assume you are placing your speakers in the shelves and hence the issue.
I could think one the below: 1. take the speakers out of these shelfs and give them a more open environment.. if they are bookshelfs put them on stands etc. 2. If option 1 is not possible, then pad the inner area of your shefs with any sound dampening material.. which could be as simple as your old turkish towels across the shelf lining. To prevent rattling of your speakers ensure that they are on a firm and thick plywood base. please do not put your speaker directly on cloth or on soft material where the speaker would sink in. try and tell us if they make any inprovement.. Last edited by realactivex; 27th March 2009 at 10:48 PM. Reason: added a line. |
#3
Hello Realactivex,
My speakers are floorstanders and they are spiked on the floor. Regarding dampening of shelves, i have put newspaper i.e. glass shelf > newspaper > component. This has worked out good for me. The sound is more on neutral side now but then the newspaper look ugly on shelves. That's why i am looking for a new shelf which is neutral as well as goes with WAF. Regards Vasu |
#4
myriad,
i have read that 2 MDFs sandwitced either with Cork OR with Dynamat (the material used for damping in cars) deadens the sound. the problem with glass is that it rings although you do get accoustically treated glass as well these days |
#5
Quote:
Regards Vasu |
#6
Most car audio installers should stock it..else they would have Bitumen sheets which are also effective.
#7
Quote:
Regards Vasu |
#8
Quote:
Please post a pic of your rack and mention your audio rig specs and room dimensions. That will give us better idea. Regards |
#9
PS: Putting your rack on spikes may change things perceptibly. Please try it before running around for less available/experimental solution.
Regards |
#10
Quote:
![]() Regards Vasu |
| Bookmarks |
| Thread Tools | |
Similar Threads for: Audio Rack Shelves?
| Thread | Thread Starter | Forum | Replies | Last Post |
| DIY audiophile rack | Anil kumar | DIY | 178 | 20th October 2009 03:22 PM |
| AV Rack in chennai | j_kalyanaraman | Audio Video Accessories | 55 | 4th October 2009 12:11 PM |
| DIY AUDIO RACK JUSTCAD design | kaushik | DIY | 37 | 1st September 2009 02:44 PM |
| Equipment Rack | yogi | Audio Video Accessories | 3 | 23rd May 2008 04:42 PM |
| Rack for DVD Cases | daumaster | Audio Video Accessories | 0 | 12th November 2006 11:06 AM |
