Wall mounts for Satellites (@ Hyd or outside Hyd)
Discuss Wall mounts for Satellites (@ Hyd or outside Hyd) at the Audio Video Accessories within the HiFiVision.com - India's Audio Video Hi-Fi Forum; I am desperately searching for wall mounts to mount my 3 satellites (part of Onkyo ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > Audio Video Essentials > Audio Video Accessories
Audio Video Accessories Speaker stands, hi-fi racks, power conditioners, remote control, headphones, isolators, etc
Advertise Here
Reply
Thread Tools
  #1
Old 22nd April 2009, 06:02 PM
skumar will become famous soon enoughskumar will become famous soon enough
I am desperately searching for wall mounts to mount my 3 satellites (part of Onkyo SKS-HT240 package) and couldn't get any decent ones so far. Am looking for ones which will let me mount the speakers away from the wall (5cm minimum) and also have the tilt and swivel mechanism. I did search most of the shops in Koti, Hyd and also Vector, Croma @ Hyd, but no luck yet. I do not want to mount them flush on the wall as I need to align them at an angle post mounting.
The speakers' dimensions are 12"H*5"W*4"D, 1.6kg/3.5lb and has a 1/4" machine nut thread at the back for screwing in a wall mount nut.
Something like this will work, but I am not sure if these are made of metal (plastic/nylon may break) and also whether it comes with a 1/4" nut.
I am also considering these B-Tech BT-33 and planning to get these (in black) thru a friend in UK, if I don't get anything locally. Any feedback on these mounts specifically or any better options that I could get from US/UK?
Members in Hyd - please suggest any other locations/shops that I should look at for these mounts.
I am open to consider any other options (including radical ones), suggestions, DIY models etc. etc. Sources out of Hyd who will ship across are also welcome.
Thanks for your help.
Kumar.
Sponsored Links
  #2
Old 22nd April 2009, 06:24 PM
Re: Wall mounts for Satellites (@ Hyd or outside Hyd)
Iamge and Specs.
  #3
Old 22nd April 2009, 09:01 PM
cary audio design is on a distinguished road
hi skumar!
check out with torvin in chennai. i had seen some decent wall mounts with them some time back. 044 28587256/65734288/43227256
regards,
abhishek.
The Following User Says Thank You to cary audio design For This Useful Post:
skumar (22nd April 2009)
  #4
Old 23rd April 2009, 09:45 AM
Just_in is on a distinguished road
You can try USK electronics- Babukhan Mall at Panjagutta.
USK Electronics - INDIA . Currently they are not stocking any of these.
But you can place order and get it. (there will be a delay of 2 weeks.)
Better talk to Mr Chandrashekhar (9396556197).
They have display pieces in the showroom.( I have ordered BS speaker stand and waiting for it).
The Following User Says Thank You to Just_in For This Useful Post:
skumar (23rd April 2009)
  #5
Old 23rd April 2009, 11:39 AM
scarface001 is on a distinguished road
I'm from Hyderabad and i conjured up a DIY wallmount!.Works perfect and has tilt and swivel function and costed only 50rs/peice. All the stuff is available in ranigunj and 100 odd bucks was spent in a lathe shop to get the finished product.
If your interested in DIY types then i could help you out.
The Following User Says Thank You to scarface001 For This Useful Post:
  #6
Old 23rd April 2009, 11:53 AM
prakasse will become famous soon enoughprakasse will become famous soon enough
Hi Kumar,
Kindly see Venkat's reply in this link.
http://www.hifivision.com/speakers/3...html#post31551
You get wall mounts for 175 Rs. This is from Chennai Ritchie street. But the company has a website and they might be able to get through courier.
Thanks,
Prakash.
The Following User Says Thank You to prakasse For This Useful Post:
  #7
Old 23rd April 2009, 12:35 PM
Scarface - thanks for the offer, I sent you a PM.
Prakash - the RoyalLook mounts need a speaker of 15cm width minimum, mine are only 13cm wide :-( The hunt is on...
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Wall mounts for Satellites (@ Hyd or outside Hyd)
Thread Thread Starter Forum Replies Last Post
Plasma and Sorround Spkr - Wall Mounts in Bangalore soulforged Audio Video Accessories 11 30th April 2010 12:01 PM
Are the wall mounts included in box for Sony Bravia KLV-40S550A? kitchie Television 3 31st January 2010 08:50 AM
Wall mount speaker stands for satellites in Delhi? vebk Audio Video Accessories 5 20th January 2010 07:40 PM
Wall mounting options for Energy satellites ajinkya Audio Video Accessories 1 19th December 2008 08:45 PM
Vanguard wall mounts pradski Audio Video Accessories 2 23rd October 2008 04:00 PM
Advertise Here
Copyright © 2006-2010, HiFiVision.com All Rights Reserved.
Recommended Websites - www.CameraVision.in
