Earthing Problem
Discuss Earthing Problem at the Audio Video Accessories within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Hi, I jsut purchased a CA 340 SE/340c combo for the folks in calcutta from ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > Audio Video Essentials > Audio Video Accessories
Audio Video Accessories Speaker stands, hi-fi racks, power conditioners, remote control, headphones, isolators, etc
Advertise Here
Reply
Thread Tools
  #1
Old 20th May 2009, 07:24 PM
SaurabhK is on a distinguished road
Earthing Problem
I jsut purchased a CA 340 SE/340c combo for the folks in calcutta from SKS traders. Now the stock power chords are soemhow 2 pin plugs which are causing earthing problems. I replaced one of the chords with a 3 pin computer power chord ( disconnected the other player which still has a 2 pin chord ). However , I am still getting the problem.
P.s -My electrician says that the earthing on the wall socket is ok . ? What to do next? Could the equipment be defective ?
OT:Why do AV manufacturers use 2 pins power chords at all??
Sponsored Links
  #2
Old 20th May 2009, 07:31 PM
particleman's Avatar
particleman is on a distinguished road
Re: Earthing Problem
I too am eager to know the answer to this. My new Arcam CD player also has the same problem. But in my case, all equipment is now packed in boxes as renovation is ongoing. So, once I get my new power cables and set it up again I will have the answer.
I too was hoping that the 3-pin power cables I was to buy would solve the problem. Rather worrying to hear that a 3-pin cable does not solve it. Is there a possibility of defective grounding in the player itself?
P.S. Saurabh, sorry to piggyback on your thread.
  #3
Old 20th May 2009, 08:03 PM
hitensitapara will become famous soon enough
Smile Re: Earthing Problem
Hi All
found out two web pages on earthing and Mains cables supply to audio equipment. Though I have simple Pioneer hifi system, I was still interested in finding out, thats why such effort. Hope you find following website usefull. (Too technical but informative) overall the whole website is usefull
for earthing
Earthing (Grounding) Your Hi-Fi - Tricks and Techniques
for mains supply cable
Cables, Interconnects and Other Stuff - The Truth
regards
The Following User Says Thank You to hitensitapara For This Useful Post:
particleman (20th May 2009)
  #4
Old 20th May 2009, 10:04 PM
cranky is a glorious beacon of lightcranky is a glorious beacon of lightcranky is a glorious beacon of lightcranky is a glorious beacon of lightcranky is a glorious beacon of light
What exactly is this 'problem' we are referring to?
For double-insulated equipment safety ground is not mandatory, and may degrade performance and introduce ground noise. Which is why most equipment in audio does not use the earth pin.
If the chassis is live, a simple solution is to reverse the plug at the outlet. Obviously this indicates improper grounding and poor isolation within the equipment, but you can't do anything about that.
The Following User Says Thank You to cranky For This Useful Post:
  #5
Old 20th May 2009, 10:47 PM
Cranky: Thanks. The problem in my case is a fairly mild shock (a "tingle" as someone described it) when operating the metallic front panel buttons of the CD player (an Arcam CD-37). If the problem persists with a 3-pin cable then I will have the unit exchanged. This is very disappointing in a £1000 player from a reputable company
  #6
Old 20th May 2009, 11:10 PM
spirovious's Avatar
spirovious is just really nicespirovious is just really nicespirovious is just really nicespirovious is just really nicespirovious is just really nice
I didnt get how 3pin chord can fit in 2pin socket.
you didnt specify earthing prob in detailed.
If shock is the problem then amp chasis has to be grounded.
1.It can be done internally(connect negative pole on circuit to chasis with new wire)This can be done by authorised person as it is in warrenty.
2.externally you can connect wire to chasis to ground on circuit board.ask your wireman to do.You can connect wire with clip connector.
3.Check you system at other's house ,if prob goes,your house wiring must be faulty.(check on spike-guard)
  #7
Old 20th May 2009, 11:18 PM
dinyaar's Avatar
dinyaar has a spectacular aura aboutdinyaar has a spectacular aura about
Saurabh what is the problem u are facing? Are u getting a mild shock when u operate the units? Are u getting a buzz?
Dont go by the two pin plug on the equipment, rather check the IEC socket on the reverse of the gear. If there are 3 pins then u should earth the gear, if there are only 2 pins then just invert the plug into the wall outlet as cranky suggested. Most gear comes with a schuko plug which DOES NOT get grounding if pushed into our wall sockets. One can easily snip of that plug and affix any decent 3 pin plug.
Particleman i have used these arcam cdps and there is no tingle or shock and these do need grounding. I have not used the stock power cords rather some of my own power cords (all have a 3 pin female IEC and 3 pin mains plug) and there has never been a problem. As cranky mentioned most gear today has done away with the ground pin (double insulation symbol is on the back panel) as its one less problem one can encounter.
Rgds
  #8
Old 21st May 2009, 12:07 AM
particleman, try reversing the plug at the outlet and see if it persists, also disconnect all equipment and see if the problem persists when you operate the CDP alone. I would not recommend draining a live chassis unless you really know what you're doing, as this will maintain the earth throughout your house at a voltage higher than zero, and thus be unsafe for the rest of your house. The earth wire does not have infinite capacity, so be careful what you do.
It is only safe to drain a live chassis if it is not double-insulated, such as most PC equipment, you will notice that such equipment will maintain a voltage above zero if the earth is disconnected and left floating at the outlet. So the root of the problem could be somewhere other than the CDP itself, and is apparent only because the CDP has metallic buttons - if your controls are plastic, you will not even spot the problem.
  #9
Old 21st May 2009, 01:36 AM
sandeepmohan is on a distinguished road
Another area to check is the electrical socket you are using with your Hi Fi. Check the earth pole with a line tester for any current. It is a rare occurance but poor/old house hold wiring can also be the reason. Also check if the Positive and negative are inversed at the socket itself. As mentioned earlier by someone else try reversing the plugs on your equipment. Check you stabilizer (If you are using one). There are rare cases of the leak starting there. Recently discovered this on my uncles V Guard Digital 100. He was using it with his Brand New Onkyo Rig and there was mild shock on the body of the Receiver and DVD Player
  #10
Old 21st May 2009, 11:27 AM
yes it is a mild shock!!
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Earthing Problem
Thread Thread Starter Forum Replies Last Post
hathway stb problem mjamal14 Digital Cable and DTH 2 19th October 2009 07:27 PM
Problem with PT AX-200E sabotage Home Theatre Projectors & Screens 5 14th May 2009 11:53 PM
Component Cable Problem frnd08 Audio & Video Cables 12 1st May 2009 08:18 PM
strange problem in onkyo-606 noking Amplifiers 7 25th March 2009 10:16 AM
Car CD Player Lens Problem kups007 Car Audio 1 5th August 2006 06:27 PM
Advertise Here
Copyright © 2006-2010, HiFiVision.com All Rights Reserved.
Recommended Websites - www.CameraVision.in
