HiFiVision.com - Audio Video Hi-Fi Forum
Remote Code for LG Plasma TV??
Discuss Remote Code for LG Plasma TV?? at the Audio Video Accessories within the HiFiVision.com - Audio Video Hi-Fi Forum; I have just installed a SR6004 and all sources have been programmed to work with ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > Audio Video Essentials > Audio Video Accessories
Audio Video Accessories Speaker stands, hi-fi racks, power conditioners, remote control, headphones, isolators, etc
Advertise Here
Reply
Thread Tools
  #1
Old 28th January 2010, 10:15 PM
Raghav's Avatar
Reputation points: 99
Raghav will become famous soon enough
I have just installed a SR6004 and all sources have been programmed to work with the AVR remote including Tata Sky+
The only problem is with the TV, which is a LG 42" Plasma. Both codes given for TV of LG do not work. the codes were 1024 and 1030. Does anyone have another code for the LG TV.
Sponsored Ads
  #2
Old 28th January 2010, 10:31 PM
Reputation points: 738
hemantwaghe is a splendid one to beholdhemantwaghe is a splendid one to beholdhemantwaghe is a splendid one to beholdhemantwaghe is a splendid one to beholdhemantwaghe is a splendid one to beholdhemantwaghe is a splendid one to beholdhemantwaghe is a splendid one to behold
Re: Remote Code for LG Plasma TV??
try codes for goldstar if you have...
The Following User Says Thank You to hemantwaghe For This Useful Post:
  #3
Old 29th January 2010, 12:41 AM
Raghav's Avatar
will do so in the morning.
Quote:
  #4
Old 29th January 2010, 08:12 AM
Try following
1003
1013
1045
1080
1100
1112
1154
Pls inform if any of these codes worked ...pls
All the best!
  #5
Old 29th January 2010, 11:09 AM
Raghav's Avatar
Thanks a ton. The first one worked fine. Did not try the others.
Does Goldstar make Plasmas for LG
Try following
1003
1013
1045
1080
1100
1112
1154
All the best!
  #6
Old 29th January 2010, 05:18 PM
Goldstar is LG!!!!
LG is abbrivation of Lucky Goldstar and their earlier brand was Goldstar
So it was my smart guess
Codes I got it from Net from some marantz remote manual!
  #7
Old 29th January 2010, 07:30 PM
Raghav's Avatar
good one.
code I also found in the Marantz Sr6004 manual
Goldstar is LG!!!!
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Remote Code for LG Plasma TV??
Thread Thread Starter Forum Replies Last Post
PS3 - How to find the DVD Region code and Blu-Ray Region code? senthilsss Console & PC Gaming 20 20th January 2011 05:58 PM
remote control code for sony bd360 gr_babu Blu-ray/DVD players & DVD/hard-disk recorders 0 28th December 2009 07:05 AM
region code setting generations Blu-ray/DVD players & DVD/hard-disk recorders 0 14th November 2008 08:59 PM
remote code for reliance bigtv gr_babu Audio Video Accessories 0 3rd September 2008 07:48 PM
onida dvd remote code manofernando Blu-ray/DVD players & DVD/hard-disk recorders 13 19th June 2008 01:37 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197
