Making Remote control universal
Discuss Making Remote control universal at the Audio Video Accessories within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Particleman, You are right it is logitech harmony 880. I have programmed scenes for the ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > Audio Video Essentials > Audio Video Accessories
Notices
Audio Video Accessories Speaker stands, hi-fi racks, power conditioners, remote control, headphones, isolators, etc
Advertise Here
Reply
Thread Tools
  #11
Old 3rd May 2008, 05:21 PM
vinay's Avatar
vinay is on a distinguished road
Particleman,
I have programmed scenes for the lights, 25%, 50%, 75%, 100%, like before the movie starts it is set to 100%, during intervals it is set to 50%, while listing to music it is set to 25%, moreover with this remote i can make the lights dim to 5% too.
With this universal remote, i do not have to use the eight remotes which i have, i think universal remote is a must for home theatre.
I have stored eight pictures of my mini theatre in the remote, it has a slide show, which is just too good.
Sponsored Links
  #12
Old 3rd May 2008, 10:54 PM
vinay's Avatar
The Red Mini Theatre
Mohan, i thank you very much that you have liked my mini theatre, true there was a great deal of passion, hard work and patience, as far as the money goes, the cost escalated too much, it was like a tap was left on, the water was just flowing.
There are just too many people who have seen my mini theatre, they also say that it is a master piece, i used to eat, drink, sleep, theatre, the amount of dry runs and related which i did on most of the things were extensive, i have seen pictures of around 20 home theatre's i and my friends found my theatre the best among them, as technically a lot of acoustic treatment has been done, other technical details have been taken care of, and the best is that, it is a dedicated theatre room, generally people have a home theatre in the living room.
I did go wrong at certain places, of which was pointed by some members on this site, and i too realized some errors, but thank god, over all it turned out to be a good one, otherwise 4 magazines would have not covered this theatre, and now times of india, is also on the verge of covering my theatre.
I have shown the pictures of my theatre, because i believe in sharing the knowledge.
Thank you very much.
  #13
Old 5th May 2008, 12:23 PM
vashok is on a distinguished road
Re: Making Remote control universal
Quote:
Originally Posted by ranjeetrain View Post
How is the Elac sound in a long term? I demoed it and found it was pretty tight. How are you finding them.
Hi Ranjeet,
I am bit novice in hi-fi jargon, but I gather you meant whether the speakers were more expressive for different ranges after having run for many hours. I do agree that when I first heard the Elac it was a bit less crisp and sharp compared to say Whaferdale or a Jamo. There is a lot of bass which sometimes was annoying - but I doubt if I need a subwoofer now . So thanks to the 505 I have reduced the bass output and also plugged the two bass cones in the speaker.
Then on, after couple of months of regular played, the other day when I played Jesse Cooks, I noticed the difference. It was just right bit of sharpness and treble. Not too crisp on high frequencies and after hours of listening also, it was not tiring at all. (I do not play the volume high). However, U2 did gave me a huge bass output which made listening much less pleasant, I must confess.
I am also amazed by the fact that so few people have auditioned Elac or talked about it. Somehow for a 3-way, I felt the price (~30k) was a good match. Elac needs good drivers was one other learning for me. Hope I have answered what you asked and was helpful.
regards
Ashok
  #14
Old 5th May 2008, 03:37 PM
suniil is on a distinguished road
I've logitech harmony 1000 programmed for controlling the full house via X10, including heating, lighting, electric PJ screen etc.
This is controlled via Marmitek IR mini controller
Quote:
Originally Posted by particleman View Post
Vinay, that is interesting. May I ask which model of Logitech Harmony you are using? Is it 880 or 1000? I thought Logitech remotes could not send X10 commands to lights, etc. Are you using a central X10 transceiver module?
  #15
Old 5th May 2008, 09:47 PM
ranjeetrain is on a distinguished road
Hi Ashok,
Very well explained. I must say you got a good deal if you got them for 30k.
Plugging in the bass cone was a right move. Also I have a feeling they will get better with more use. May be you can run them out of the phase for a few days on a low volume.
Ranjeet
  #16
Old 12th May 2008, 11:48 AM
This page says your Onkyo has a Pre-Pro/Learning Remote, whicg is a good news!
Hi again
So I looked up the codes for my dvd player [pioneer dv 400 - code 368] and the cable/sat box [humax nd 1000c - code 0863 ]. With great expectations, I punched in the number in the Onkyo remote [sr505 - supposedly a learning one]. The dvd button blinked twice after pressing in the number for dvd player. Still no response from the player. I tried the same cable/sat and no response.
So I could have got the codes wrong or perhaps it just does not work with onkyo remote . Now I am wondering, even if I buy a universal remote, I may still have the same issue.
Can somebody please help me out.
Thanks,
Ashok
  #17
Old 12th May 2008, 11:07 PM
vinay's Avatar
Ashok, you are facing quite a struggle, i had faced several problems and related, but i traced my way out, i had contacted the logitech's office in mumbai, they had come over, and solved a lot of the issues, than i came across a guy who had considerable knowledge on this remote, so he too helped me a lot, i paid him consultation, so now whenever i need some changes, etc, i call these people, and not to forget that logitech has a toll free number of malaysia, they too have helped me a lot, and please be assured that with the branded universal remotes, things can just not go wrong.
Thank you.
  #18
Old 13th May 2008, 09:40 PM
Sounds frustrating. But the only thing that can be done is - to try again. The DVP should not need its own remote but cannot rule out that possibility. Many manufacturers do that.
  #19
Old 14th May 2008, 11:51 AM
particleman's Avatar
particleman is on a distinguished road
This is exactly why a "learning" remote control is preferred to a "universal" one.
  #20
Old 14th May 2008, 01:54 PM
vinay's Avatar
Universal Remote control
Members at this forum did try their best to help ashok, but the matter remains unresolved.
The logitech remote is dual, it is a learning one and universal too, it is just that ashok needs to find a better way out, or he has to follow the lines, by which i handled my problems over the remote.
Sponsored Links
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Making Remote control universal
Thread Thread Starter Forum Replies Last Post
Stereo Preamplifier with remote control hifipal4all Wanted 5 7th November 2008 04:49 PM
Tips for making a dedicated home theatre vinay My Audio/Video Setup 7 23rd March 2008 04:22 PM
Making 588A Region Free kayjay DVD players & DVD/hard-disk recorders 5 26th November 2007 11:37 AM
JBL Control 1 hemantwaghe Speakers 2 23rd October 2007 02:58 PM
Looking for a Remote Control hifipal4all DVD players & DVD/hard-disk recorders 0 17th September 2007 01:38 AM
Advertise Here
Copyright © 2006-2008, HiFiVision.com All Rights Reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
