| Discuss Making Remote control universal at the Audio Video Accessories within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Originally Posted by vashok ...With great expectations, I punched in the number in the Onkyo ... |
| Notices |
| Audio Video Accessories Speaker stands, hi-fi racks, power conditioners, remote control, headphones, isolators, etc |
Thread Tools |
#21
Re: Making Remote control universal
Quote:
As Vinay has also pointed out, it is best to go for a learning remote from Logitech, Philips, etc. if you want a simple solution. Example, see: Universal Remote Controls Home Page - Sumaria.in |
| Sponsored Links |
#22
Thanks a ton Particleman and everyone else who helped. Indeed, I just want to point my remote to this learning remote and need not have to struggle with codes. I will hunt around for one which will work. The link also helped. I will have to make sure that the universal remote has a learning port like one from Logitech. The cheaper sony one still needs remote codes.
Thanks again. regards Ashok |
#23
Ashok, you are most welcome. I would recommend you try to source the Logitech Harmony (885 or 1000) from abroad as the local prices are 80-90% higher than international. Just check that you are ordering a 220V model (the recharging cradle has to be plugged in).
That Sony is well priced but I have no idea about how well it works. Advantage with Logitech is you can connect it to your PC and download codes from a large online database for each of your devices. Some reviews on the Sony may help you out. This fellow seems to be have used its learning function successfully so it may be worth looking into: * Squeezebox*by*hairy.geek.nz Last edited by particleman; 14th May 2008 at 02:42 PM. Reason: More info |
#24
I picked up the OneForAll URC 7556 Digital 5 for Rs. 2000 and it has both modes of entering a code and also a learning mode. It controls up to 5 devices and is very easy to use. It is still a stop gap arrangement as I will be getting Logitech Harmony from the US soon. But to state the obvious the OneForAll works very well and does everything asked of it.
| The Following User Says Thank You to moserw For This Useful Post: | ||
vashok (1st November 2008) | ||
#25
Quote:
#26
spirovious,
I am not sure what model you want the information for, but I am posting for my remote which is model URC 7556 Digital 5. You can d/l the manual/instructions for any model from the manufacturer's website Welcome to One For All Global Instructions - You can find the codes mentioned in point 1 on the website too. Example: To set up the ONE FOR ALL 5 for your Television: 1 Find the code for your device in the Code list (page 201 â 221). Codes are listed by device type and brand name. The most popular code is listed first. Make sure your device is switched on (not on standby). 2 Press the TV key on the ONE FOR ALL 5 for the device you wish to Set-Up. 3 Press and hold down MAGIC until the ONE FOR ALL 5âs TV key blinks twice (the red LED underneath the TV key will blink once and then twice). 4 Enter your four-digit device code using the number keys. The device key will blink twice. 5 Now, aim the ONE FOR ALL 5 at your device and press POWER. If your device switches off, the ONE FOR ALL 5 is ready to operate your device. 6 Turn your device back on and try all the remoteâs functions to ensure they are working properly. If the functions do not work properly, repeat steps 1-5 using another code listed under your brand. Hope this helps. |
spirovious (11th November 2008) | ||
#27
Quote:
.Concern: I am not able to configure my Sundirect STB remote, can anyone please let me know the remote code of Sundirect STB. Thanks Ramesh S |
| Sponsored Links |
| Bookmarks |
| Thread Tools | |
Similar Threads for: Making Remote control universal
| Thread | Thread Starter | Forum | Replies | Last Post |
| Stereo Preamplifier with remote control | hifipal4all | Wanted | 5 | 7th November 2008 04:49 PM |
| Tips for making a dedicated home theatre | vinay | My Audio/Video Setup | 7 | 23rd March 2008 04:22 PM |
| Making 588A Region Free | kayjay | DVD players & DVD/hard-disk recorders | 5 | 26th November 2007 11:37 AM |
| JBL Control 1 | hemantwaghe | Speakers | 2 | 23rd October 2007 02:58 PM |
| Looking for a Remote Control | hifipal4all | DVD players & DVD/hard-disk recorders | 0 | 17th September 2007 01:38 AM |
