HiFiVision.com - Audio Video Hi-Fi Forum
Cable and mcb
Discuss Cable and mcb at the Audio & Video Cables within the HiFiVision.com - Audio Video Hi-Fi Forum; I am very sorry i have accidentally posted in wrong section please correct me hey ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > Audio Video Essentials > Audio & Video Cables
Audio & Video Cables Interconnect, speaker cables, component video cable, mains cable, etc
Advertise Here
Reply
Thread Tools
  #1
Old 21st August 2010, 05:29 AM
Reputation points: 10
blue is on a distinguished road
Question Cable and mcb
hey guys ,i want ur help and suggestion desperately,
new wiring is going on in my house i am confuse which is the best brand of wire to choose from , i have a 2BHK house running 1.5 ton ac refrigerator water pump ,geyser, etc (u name it )what should be the proper type of wire to be used in the wiring?
1 What is a MCB ? What is type A , B, C MCB?
2 What is distribution box ? (mcb distribution box)
3 How many mcb do i need?
4 How to avoid unnecessary tripping of Mcb?
Sponsored Ads
  #2
Old 21st August 2010, 11:40 AM
deba's Avatar
Reputation points: 112
deba will become famous soon enoughdeba will become famous soon enough
Re: Cable and mcb
I have used Finolex Wire and go for Havells or even better Hager made MCB to replace the old concept of Ceramic Fuse....MCBs are best as they protect you against fire hazard by tripping off if the line is overloaded or if there is any short circuit..........go for MCBs, the correct amperage of each MCBs can only be calculated by your electrician after considering the load.
Distribution box will consist of all your MCBs / Never overload your electrical line to avoid tripping of MCBs.
Visit the page below:
MCB 0.5 to 63A Hager
  #3
Old 21st August 2010, 07:04 PM
Re: Cable and mcb
thank u for replying deba
electrician suggested me anchor wires and mcb
are they any good?
  #4
Old 22nd August 2010, 07:53 AM
studiomaster's Avatar
Reputation points: 17
studiomaster is on a distinguished road
Re: Cable and mcb
I support :
Hager is good, we have 6 yr old hager ELCB Still without any issues in our office distribution panel.
Wires : There are good opinions for RR KABEL.
thanks,
studiomaster
  #5
Old 23rd August 2010, 07:45 AM
Reputation points: 21
uziel is on a distinguished road
Re: Cable and mcb
Finolex is also good. Make sure each 16A pints have seperate MCB, each room ha a seperate mcb for outlets as a whole and the load balancing should be good. Havells MCB also makes no trouble n works years troublefree.
  #6
Old 23rd August 2010, 07:52 AM
Re: Cable and mcb
MCB ( miniature circuit Braker) is an overload protection mechanism wherein if there is an electrical fault, there are high chances that the MCB will trip n accidents are avoided. Types are not followed these day majorly. ABCD have to do majorly with the mechanism they use to trip like instant trip, double trip etc. To avoid trippings, use good quality wires n make sure all have earthings. Do not overload points.
  #7
Old 23rd August 2010, 11:03 AM
deba's Avatar
Re: Cable and mcb
Ask your electrician to go for Finolex cables and Hager or Havells MCB.
I have not used Anchor but it may be good........
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Cable and mcb
Thread Thread Starter Forum Replies Last Post
MX RCA cable gopscreative Audio & Video Cables 10 3rd July 2011 12:18 AM
Any HDMI cable from BJC better than the bundled cable with Oppo-83? Help. max123_ind Audio & Video Cables 1 27th July 2010 12:23 AM
Which component cable (5-RCA or 3-RCA) sandys Digital Cable and DTH 4 8th July 2010 07:52 PM
AV Cable Hub KBS Audio Video Accessories 11 22nd November 2009 12:56 PM
Underground cable-tv + telephone cables - pipes and cable recommedations skumar AV Lounge 2 1st November 2009 09:55 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
