HDMI cable
Discuss HDMI cable at the Audio & Video Cables within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Hi , I am scouting for a HDMI cable to connect my Amp with the ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > Audio Video Essentials > Audio & Video Cables
Notices
Audio & Video Cables Interconnect, speaker cables, component video cable, mains cable, etc
Reply
Thread Tools
  #1
Old 19th June 2008, 10:01 PM
Mukundsv is on a distinguished road
HDMI cable
Hi ,
I am scouting for a HDMI cable to connect my Amp with the Projector, the dealer has suggested QED Qunex HDMI-P, which is costing me about 18K for 15m length. I couldnt find many reviews of the said cable but 1 of them did mention this
"Interestingly, the longer versions (10m-plus) employ cable of larger diameter - this contains higher-grade wiring to cope with the longer distances, thereby explaining the pricing 'jump'. Yet these are only certified to version 1.2a, not 1.3, so it can't offer bitstream support for Dolby Digital Plus, Dolby TrueHD, and DTS-HD, or other 1.3 benefits like automatic lip sync adjustment"
Group test: HDMI cables pt2 - AVReview Cable reviews
Now, as a newbie i am kinda in a flux if these things are a absolute must ( i think they are, considering i am building a HD projection room to play full HD movies, games with HD audio etc )......
Any recommendations for alternative cable brands ?
Help !
Sponsored Links
  #2
Old 23rd August 2008, 10:48 AM
sub's Avatar
sub sub is offline
sub is on a distinguished road
Re: HDMI cable
There are so many brands available in india like Panasonic, Diyo, Bandrige etc., with version 1.3a
  #3
Old 23rd August 2008, 01:04 PM
venkatcr is a jewel in the roughvenkatcr is a jewel in the roughvenkatcr is a jewel in the rough
Re: HDMI cable
Mukund:
There is a long and detailed test done by Clint DeBoer of Audioholics on long HDMI cables. His conclusion? For up to 10 meters any HDMI cable will suffice if you are looking at just 720p/1080i or at 1080p at 8 bits. If you want Deep Colour, or TrueHD, you have to be a little more careful. For lengths longer than 10m, it is not just the cable, but a combination of cable, the projector (or TV), and the bit rate (or bandwidth being sent) that come into play. Please read the following article carefully:
Long HDMI Cable Bench Tests - Monster Cable Shootout — Reviews and News from Audioholics
I quote Clint's conclusions:
QUOTE
Your take-away from all this should be the following:
* At lengths less than 4 meters you can just about use silly string (OK, not really) and get HDMI to pass at any current resolution. At less than 3 meters you'll even extend that to 12-bit color and possibly the next crazy idea HDMI Licensing decides to throw at consumers. Don't spend a lot on these cables and if you want to save money you won't let anyone at a big box store talk you into buying from them.
* At long lengths (over 10 meters) you really need to pay attention to the manufacturer if you don't want to risk running into potential problems with 1080p and future formats such as Deep Color. With that said, just about any cable at or under 10 meters will pass 720p/1080i and nearly everyone will pass 1080p at 8-bit color as well.
* If you have an existing HDMI cable and are running into problems, we'd suggest at least attempting the insertion of an active component at the sink (display) side. This is going to be far cheaper than ripping out your walls and re-running new cables - and likely just as effective.
* HDMI has proven to be a moving target and there is no telling what crazy (likely unnecessary) format they will try to push down the cable next. Due to this, it's always good to "overbuild" your cable install, especially if it's a longer distance and going to end up behind drywall.
* If you're not prone to upgraditis and think 1080p will be your maximum resolution for the life of your install, don't sweat it...
There are going to be exceptions to all these "rules" but in the end I'd have to say that I really thought I'd see more differences in the real-world performances of longer-length cables. Since we're all basically pinned at 8-bit 1080p, I didn't. It's likely you won't either. So all those people saying "buy any cable you want, it doesn't matter" are, for the most part, correct - at least until manufacturers advance to 12-bit software and signal transmission. Where they are not accurate is in assuming HDMI (since it is digital) is either "on" or "off" (it either works or doesn’t). HDMI signals can be partially corrupted as you saw above. The other area in which they are off concerns the future. If and when 12-bit "Deep Color" video truly comes to market (as more than just a listed spec) individual cable situations can (and likely will) change. For this reason take all of the above measurements and principles into account and make sure you build your installation wisely.
UNQUOTE
I would also suggest you to look at DAC's HDMI cable sold by Designer Audio (Designer Audio - Products) I have been using this for some time and am very happy with it. I am not using the length you are specifying. In addition they are 1.3 certified. If you live in Mumbai, go across to Designer Audio shop and ask questions and maybe a guarantee on 15m lengths. If they have a 15m piece lying around, get a test done at 1080p.
If you live elsewhere, call them on the phone and talk to them. Find out if they are ready to take back the cable if it does not work at those lengths.
Since HDMI is an evolving standard, there are certain risks, and one cannot guarantee that a particular cable will or will not work. At the same time, I am sure you can get a good cable at much less than 18K.
Cheers.
  #4
Old 23rd August 2008, 01:28 PM
psychotropic's Avatar
psychotropic will become famous soon enough
Re: HDMI cable
It will be easier to find HDMI cables offering 1.3 in the smaller sizes, but it may difficcult to find them in the lengths that you require. But on the other hand, the benefits of 1.3 over 1.2a are marginal and often superfluous as devices that can provide the incremental benefits are almost non-existent on the ground.....Do look around if you are particular, but my gut feel is that you shouldn't fret too much. You're investing in quality cable, and for 15m lengths that would be essential, and I don't think you'll suffer at all by not hunting down that particular cable that can gie you 1.3 for a whole 15 metres. Also the incremental cost is likely to be high. So my personal opinion is that you should chill and go for the QED (unless you're able to find something better for a competitive price, but I doubt it).
Quote:
Originally Posted by Mukundsv View Post
Hi ,
Help !
  #5
Old 23rd August 2008, 05:58 PM
Re: HDMI cable
Hi Venkat, Thanks a bunch for the link and the reply. Too late though as I have already bought the QED and have been using it for a month now. Its pretty amazing and I dont think i can pick out any vices.
But yeah, the article sure points out to lot of interesting facts and i wish i could have seen it earlier.
Hi Psychotropic, I couldnt find an alternative for the QED and as mentioned above i am pretty satisfied with its performance. Thanks for your inputs
Sponsored Links
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: HDMI cable
Thread Thread Starter Forum Replies Last Post
How to Connect TV and DVD (HDMI) with HT non HDMI gaurav013 Home Theater In A Box 4 22nd August 2008 12:32 AM
How to Connect TV and DVD (HDMI) with HT non HDMI gaurav013 Television 3 12th June 2008 05:23 PM
samsung hdmi cable Chacko Koshy Audio & Video Cables 6 2nd June 2008 10:56 PM
Help on HDMI setup planetavi Surround Amplifiers/Receivers 6 8th March 2008 08:21 PM
Best HDMI upconverting AVR under 50K spycatcher Surround Amplifiers/Receivers 9 1st March 2008 01:17 PM
Copyright © 2006-2008, HiFiVision.com All Rights Reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
