Mains Power Cable for NAD 320BEE
Discuss Mains Power Cable for NAD 320BEE at the Audio & Video Cables within the HiFiVision.com - India's Audio Video Hi-Fi Forum; anyone has experiance of Main Power Cord Supra LoRad with NAD 320BEE? it is possible ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > Audio Video Essentials > Audio & Video Cables
Notices
Audio & Video Cables Interconnect, speaker cables, component video cable, mains cable, etc
Reply
Thread Tools
  #1
Old 2nd September 2008, 05:42 PM
rashmikant is on a distinguished road
anyone has experiance of Main Power Cord Supra LoRad with NAD 320BEE? it is possible to change power cord in NAD 320BEE?
any significant sound improvement?
Sponsored Links
  #2
Old 2nd September 2008, 06:57 PM
venkatcr is a jewel in the roughvenkatcr is a jewel in the roughvenkatcr is a jewel in the rough
Re: Mains Power Cable for NAD 320BEE
Rasmikanth:
There have a number of threads discussing power cords, cables, etc. Please use the Search button and look for these threads.
  #3
Old 2nd September 2008, 09:51 PM
dinyaar's Avatar
dinyaar is on a distinguished road
Hi Rashmikant,
I feel Supra cables are very well made. Power cords included. Will it make a big difference in your set up i cant say. Will it make any difference in the sound of your set up also i am not sure.
Yes it is possible to replace the stock cord with a supra Lorad 1.5 or 2.5. If u were to believe the Nad distributor then supra( also carried by him) brings out the best in Nad gear.
Sorry i cant give a difinitive answer so its best for u to explore for yourself.
  #4
Old 2nd September 2008, 10:20 PM
Dinyaar,
My curiosity has been piqued and I have to ask these questions, even though they may sound stupid.
1. Let us say we buy a Supra Lorad power cable. As fas as I can see, it comes with a UK plug. So what do we do? - do we cut the cable near the plug and replace it with an Indian plug, or do we buy a extension board that can take such plug types and use that? By doing this will we be degrading the cable's capabilities.
2. I have wired my whole house with Finolex 720 Flamegaurd wires. All my sockets are MK, and I have slowly replaced all the plugs in my appliances with MK plugs so that the fitment is perfect. Over the last 10 years, I have not had a single incident (touch wood) of any kind, except once when there was sustained lightning for half a day, and I forgot to unplug some devices. All I lost was a fuse on my TV that was easily replaced.
My question is this - If I buy a good quality IEC male, use Finolex cables and a MK plug, will I be creating a DIY equivalent of the Supra Lorad?
3. A Suhas has suggested in many places, what will happen if I buy a HP cable, and replace the plug with an MK plug.
I know these questions are stupid, but I have the urge to create new extension boxes and use MK plugs and sockets throughout for all my expensive electronics. I have great faith in the MK plugs and sockets.
  #5
Old 2nd September 2008, 10:53 PM
SuhasG's Avatar
SuhasG will become famous soon enough
I second Venkat. Don't go for those exotic and over priced brands. Power cords make no noticable difference.
Good quality conductor (low resistance and enough current carrying capacity) , proper insulation (to avoid short circuits), good amount of shielding (to reduce EMI-RFI ) and firm contacts (secure contacts, no loss or distortion) is all that is expected from a power cord. Rest all is 'Snake Oil'!
A HP printer cord serves this purpose and some more. Those are the best for any budget system (Like NAD) . One can get some 2.5 mmsq FINOLEX wire, good connectors with brass parts and make a nice power cord out of it. Google for 'DIY Power cord' for additional information.
A midway solution is DIY power cords made by Cadence dealer in Bangalore , decent quality (imported German wire) and workmanship. 1 meter cord is for Rs 1000.
Hope this helps.
  #6
Old 3rd September 2008, 11:46 AM
dinyaar's Avatar
Quote:
Originally Posted by venkatcr View Post
Dinyaar,
Hi Venkat,
Yes pre terminated Supra will come with one of two options. A 3 pin 13 amp fuse protected UK plug or a schuko plug. One can choose the option one requires. Yes u will need to connect to an adapter that accepts the UK flat pin in case your wall sockets dont also accept Uk flat plugs.Better option is to use MK/Anchor/Anchor Roma or whatever instead of using the above supra plug+MX adapter method.
Yes u can surely make a good power cord with the components u have outlined above. Finolex/Polycab make good cables.
I have no expererience with an HP cable. But yes u can put the MK plugs on any cable. Just keep the IEC Socket intact and chop off the other end and replace it yourself with an MK/Anchor plug or whatever u choose.
As i mentioned to Rashmikant that using a supra mains lead may/may not lead to any audible difference.
My house is wired with Finolex cables too and the wall outlets are assorted. By that i mean some are Anchor Roma and the ones for the audio set up are bought from UK.
Basically one has to ensure a solid firm contact and the plugs should be of a reasonable quality and u should go with MK since ur experiences have been good. I would not make extension Boxes though. Just replace plugs on the cables and plug directly into mains.
Have tried tons of mid priced power cords from various manufacturers.(most were taken for demo and not purchased) and i have written about my experiences on a couple of similar threads. This Supra is a well made cable/coated in tin/has an additional metal screen (and hence is certified hospital grade in the Uk)/rejects RF/EMI / is very flexible and is really cheap when bought un terminated, off a reel in the UK and hence i had bought about 10 metres ages ago.
  #7
Old 3rd September 2008, 12:55 PM
awedeophile's Avatar
awedeophile is on a distinguished road
In my experience, power cords do make a difference and I can prove it in my setup. It is not entirely cost dependant as I have heard cheaper power cords that sound better than some more expensive ones.
However, the difference they make is entirely based on the quality of AC power that you have to begin with, your setup and any RF/EMI present near/around the cords and setup. The Ground (Earth) connection is also very important.
No one can accurately tell you if any power cord will make a difference in YOUR particular setup and environment. It is best to ask some dealers for an in house demo and make your own decision.
  #8
Old 3rd September 2008, 01:09 PM
Not a stupid question at all. A good contact can make a very very large difference. Although I have not experimented with it, many people claim to find a difference in sound with the change of wall outlets. All my cables have US style connectors (easier to buy and sell these online) and hence I use US wall outlets. I feel these give a very tight and excellent connection, while not costing much. I use the Pass & Seymour ones (Cryo treated) at the bottom of the following page. I paid 2/3 the price they are now listed for:
Oyaide R1 IsoClean and Furutech Receptacles
  #9
Old 3rd September 2008, 07:07 PM
Thanks Awedeophile and Dinyaar for your patient replies.
The Pass & Seymour AC Receptacles look interesting. Wish I had known about these 10 years ago. If I touch my walls now, my wife will kill me. I am assuming these receptacles can handle 220 volts.
Man, it is amazing what all you can do to your house if you are serious and you know what you are doing. I am constantly amazed by the lack of knowledge. particularly about new techniques and products, that our civil and electrical contractors have. They have a stock answer - 'This will not work in India, Sir!!!' for everything.
  #10
Old 3rd September 2008, 07:20 PM
Hi, mine aren't in the wall, they are in a box and I have a dedicated circuit from the main breaker to the box. I have been using these for quite a few years now without any problems.
Sponsored Links
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Mains Power Cable for NAD 320BEE
Thread Thread Starter Forum Replies Last Post
Mains power trip switch? PbR Audio Video Accessories 12 18th August 2008 04:44 PM
Nad 320bee rashmikant For Sale 6 17th July 2008 06:16 PM
nad 320bee vishnu Amplifiers 2 28th March 2008 06:05 PM
Power Cord Shoot-Out: 22 Power Cords Reviewed Neal Audio & Video Cable Reviews 1 1st April 2007 01:10 PM
Mains Power supply and Hi-Fi Mohan AV Enhancers & Room Acoustics 2 8th September 2006 12:32 PM
Copyright © 2006-2008, HiFiVision.com All Rights Reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
