| Discuss optical to coaxial switch at the Audio & Video Cables within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Something like the above. Anyone knows where to find this in India ?... |
| Audio & Video Cables Interconnect, speaker cables, component video cable, mains cable, etc |
Thread Tools |
#1
![]() Something like the above. Anyone knows where to find this in India ? |
| Sponsored Links |
#2
Re: optical to coaxial switch
I think MX company makes that?
MX website not available anymore on net. Last edited by spirovious; 23rd January 2009 at 09:33 PM. |
#3
Vint, what exactly are you looking to solve with this apparatus? What is the connectivity you are looking for?
Cheers |
#4
It is opt to coax converter.MX web?
#5
Quote:
Is there anything else that can do this job ? BTW, one amaetur q: Is SPDIF and co-axial same or different ? I saw this on ebay. Will this solve my problem ? |
#6
Quote:
The link is not coverter but switcher bween opical to opt devices. Last edited by spirovious; 24th January 2009 at 01:34 PM. |
#7
Quote:
![]() Sadly, I'm not able to find it in India so far
#8
If its Philips then they have only coaxial. Is it a DVDP/Amp combo in your HT or a separate DVDP. If DVDP is separate then you might as well pick up another DVDP that would come with optical/HDMI options. This might work out cheaper too.
#9
Sorry I forgot to check on that. U anyone coming from US? I bought it in US for 10$
Why dont u order directly from Amazon? Amazon.com: Digital Fiber Optical (Toslink) to Digital Coaxial (S/PDIF) Converter: Electronics I read in our forum that cables etc are delivered without any problems... Last edited by madbullram; 24th January 2009 at 11:18 PM. |
#10
^^ thanks madbullram. Amazon says it doesn't ship tools/hardware etc outside of US. Anyway, I will check if there's anyone coming back from US.
Will I get this in Singapore ? I've some relatives there. I don't know where to search for if this is available in Singapore ! |
| Bookmarks |
| Thread Tools | |
Similar Threads for: optical to coaxial switch
| Thread | Thread Starter | Forum | Replies | Last Post |
| Multichannel & Optical Connections | reju | Surround Amplifiers/Receivers | 12 | 27th May 2009 10:44 AM |
| Coaxial or Analog L&R | Rohit Verma | Digital Cable and DTH | 3 | 26th February 2009 09:18 AM |
| philips ht 3569 - optical out to coaxial in - help needed | vint | Home Theater In A Box | 42 | 5th February 2009 02:49 PM |
| optical cable query | Asit | Audio & Video Cables | 0 | 5th November 2008 05:49 PM |
| Coaxial Digital Audio Outputs | ajithlal | DVD players & DVD/hard-disk recorders | 9 | 21st September 2008 09:10 PM |
