HiFiVision.com - Audio Video Hi-Fi Forum
MX Cables in Bangalore
Discuss MX Cables in Bangalore at the Audio & Video Cables within the HiFiVision.com - Audio Video Hi-Fi Forum; Hello Guys, I've bought this Onkyo 5105 for more than a week now and yet ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > Audio Video Essentials > Audio & Video Cables
Audio & Video Cables Interconnect, speaker cables, component video cable, mains cable, etc
Advertise Here
Reply
Thread Tools
  #1
Old 28th January 2009, 11:50 PM
Reputation points: 12
Ketan is on a distinguished road
Hello Guys,
I've bought this Onkyo 5105 for more than a week now and yet not managed to set the system up completely.
I'm going to need some extra cable for the sourround speakers. The one that has come with the system are 22 AWG and I guess it should be good, but the length they have provided is around 9Mtr. I may need around 12-14Mtr for one of the two sourround speakers and that may require to buy a seperate cable running around 12-14Mtr, this left me thinking whether I should go for some high end cable like 16 or 14 AWG cables for both the sourround speakers (that 22 AWG should be good for my front and center speaker - my personal view).
Can anyone please let me know whether going for a better AWG for sourround speakers (which is going to run around 9Mtr right one and 14Mtr left one) is a good idea!! if so, I understand that the MX has got the decent quality OFC cable that I can buy.
I had been to SP road and saw MX catalogue at one shop where the 16 AWG was around Rs. 42xx and 12 AWG was around Rs 45xx for 100 Mtr roll. The shop guy told me that they sell only 100Mtr rolls and do not sell loose. Can anyone tell me where can I get the Mx cable in Bangalore in loose quantity per my requirement and I dont need 100Mtr for sure.
I'm also looking for a decent HDMI cable, Does the one by Mx do a decent job here? I will be using it either from my AVR to TV or from my Xbox to AVR.
Thanks in advance
Ketan
Advertisements
Advertisements
  #2
Old 29th January 2009, 08:13 AM
Reputation points: 376
marsilians is just really nicemarsilians is just really nicemarsilians is just really nicemarsilians is just really nice
Re: MX Cables in Bangalore
You don't need expensive cables at all. Its all snake oil when you look at pricing for cables esp. in India. The guage is a bit too low. I would go atleast 16 or 14AWG if you can all around.
Lots of cheap options even if buying directly from Amazon.com and adding customs duties to the purchase
Amazon.com: Philips Spooled Speaker Wire - 100ft - 16 gauge: Electronics
Quote:
Originally Posted by Ketan View Post
Hello Guys,
Thanks in advance
Ketan
  #3
Old 29th January 2009, 10:32 AM
doors666's Avatar
Reputation points: 426
doors666 is just really nicedoors666 is just really nicedoors666 is just really nicedoors666 is just really nicedoors666 is just really nice
Hello Guys,
Thanks in advance
Ketan
There is a shop in sp road that is just for cables. I think its called cabletron or something. Its about half way thru sp road and is on right hand side. That guy sells all sorts of cables, any length, any gauge, branded and unbranded.
  #4
Old 29th January 2009, 10:40 AM
krauss's Avatar
Reputation points: 24
krauss is on a distinguished road
hi ketan!
22 awg is too low for speaker cables. u should go for 14 or 16 awg max. you may talk to Abhishek of audio dynamics (9845881387). one of our forum members once bought some good taiwanese cables from him and seems to be satisfied.
  #5
Old 29th January 2009, 11:25 AM
madbullram's Avatar
Moderator
Reputation points: 925
madbullram is a splendid one to beholdmadbullram is a splendid one to beholdmadbullram is a splendid one to beholdmadbullram is a splendid one to beholdmadbullram is a splendid one to beholdmadbullram is a splendid one to beholdmadbullram is a splendid one to beholdmadbullram is a splendid one to behold
You have a PM on HDMI. 22 is way low go for 14 as you don't change cables often.
  #6
Old 25th April 2009, 08:58 PM
@doors666
I had been to SP road and I guess I did find a shop that sells all types of cable (Cabletron or something), he was not aware of the MX cable at all and was offering some 18AWG imported cable which was very costly too.
@krauss
Do you know exactly which cable (14 AWG?) you have bought from Abhishek? if you can tell me the spec and price, that will be good.
@Ram
Do you still have those HDMI left with you?
  #7
Old 26th April 2009, 10:13 AM
doors666's Avatar
@doors666
@krauss
@Ram
You can get the MX cables at the MX shop. Luckily I got his card yesterday and here are his details. I saw that he has speaker cables too.
Sanson Electroniks
Ph - 22240912, 22898079
No 1/1 Gopal Complex,
Sadar Patrappa Road (I guess thats what SP stands for, never knew)
Bangalore - 560002
These guys are authd distributors for MX.
  #8
Old 26th April 2009, 01:04 PM
soundsgreat's Avatar
Reputation points: 147
soundsgreat will become famous soon enoughsoundsgreat will become famous soon enough
Doors Sanson guys are just the dealers for the MX and have an exclusive outlet thats it ! they are not the Distributors !! The MX Distributor is sitting some place else and they supply materials to this Sanson !!
Ketan Have you finally got some cable or not ?? if not try with Radiotronics on the Right hand side of the lane in SP Road,They are basically into PA stuff but have some decent imported speaker cables which are cheap !
Another place to check out would be,A shop inside the lane on the first right turn diagonally opposite to OM Electronics ! its on the left hand side (just a couple steps inside this lane) they have some decent speaker cables too ! check them out !
If you are unable to get it please do PM me so that I can try to help !!
Regards.
  #9
Old 27th April 2009, 04:49 PM
doors666's Avatar
Quote:
Regards.
I have his visiting card and it says "Authd. Distributor" right next to the MX logo.
  #10
Old 27th April 2009, 06:09 PM
Buddy Am sorry if I have given any wrong impressions to you ! But the is the truth ! they may have given a wrong idea or misrepresented themselves !
Sanson Electronics is not the official Distributors for Karnataka ! They are just Exclusive Mx retail outlet !
I have dealt with them and also the official distributors,so I know very well ! Infact I know SP Road in & out !
Please don't take it in the wrong way,Am not trying prove anything here !
Off the topic,Ketan please excuse me if I have intruded on to your thread !
I have a 12Awg Speaker Cable Full Roll (100Mtrs) which I wish to sell !! Its made in USA and is of Blue colour !I bought this sometime back for some DIY project but never used it ! Am expecting 26K for the Roll (100Mtrs)!
If anyone is interested please PM me for further............
Regards.
Advertisements
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: MX Cables in Bangalore
Thread Thread Starter Forum Replies Last Post
Y-Cables good or bad? gobble Audio & Video Cables 0 5th January 2010 12:33 PM
Should i buy new cables ? Harley Audio & Video Cables 4 13th January 2009 12:17 AM
DIY speaker cables Vs. Branded Speaker cables rikhav Audio & Video Cables 6 24th September 2008 07:20 PM
Cables from UK deepakgang Audio & Video Cables 7 19th August 2008 11:10 PM
DiY cables klone DIY 24 1st May 2008 02:34 AM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
