bannana plugs or Bare Wire ?
Discuss bannana plugs or Bare Wire ? at the Audio & Video Cables within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Originally Posted by dinyaar Hi, Ya WBT make the best connectors, terminals etc but the ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > Audio Video Essentials > Audio & Video Cables
Notices
Audio & Video Cables Interconnect, speaker cables, component video cable, mains cable, etc
Advertise Here
Reply
Thread Tools
  #11
Old 5th March 2008, 02:32 PM
awedeophile's Avatar
awedeophile is on a distinguished road
Re: bannana plugs or Bare Wire ?
Quote:
Originally Posted by dinyaar View Post
Ya WBT make the best connectors, terminals etc but the pricing here is ridiculous. If u are intending to use in say a biwire set up u could get a budget amp in the cost of 16 spades or banana s!!!!!!!!!!!!! so u have to draw the line somewhere.
I simply suggested that WBT is the best. He can buy what he wants. What line have I crossed?
Sponsored Links
  #12
Old 5th March 2008, 02:42 PM
dinyaar's Avatar
dinyaar is on a distinguished road
To draw a line somewhere is a general statement am not in any way saying that u have crossed a line/ boundary or whatever. Of course each of us are free to use whatever connector they so choose, this is just a healthy discussion and should remain such.
  #13
Old 5th March 2008, 02:49 PM
Agreed. BTW a set of 12 spades to make up a biwire set (4 terminals at speaker and 2 at amp end per channel) will cost about $120. Not really that ridiculous considering the premium product. TEHO
  #14
Old 5th March 2008, 02:55 PM
dinyaar's Avatar
Hi again,
Well i would need 16 and when i checked here in mumbai was told its 1000/- per peice!!!!!!!!!!! Haha thats what i meant a cheap amp could be got. But at the price u mention i sure am a buyer.
Best regards
  #15
Old 5th March 2008, 03:02 PM
You're right.. My mistake.. the WBT is indeed $22 each
The Eichmaan and others are more affodable..
Eichmann, Furutech, and WBT spade, banana, binding posts
Apologies..
  #16
Old 13th November 2008, 12:05 PM
pradski's Avatar
pradski is on a distinguished road
I was using 4 mm MX banana plugs previously which were really pain in the avr terminals.
Now I bought MX gold plated 2 mm bananas which cost around Rs 75 per pair which have
angled and straight. The angled are without screws.
I soldered the ends in to these and I put the sheath over the pin after soldering.
The real advantage is they fit in to AVR terminals so well and so easyily.
Fit perfectly unlike the 4 mm. Angled are better, they avoid touching other terminals.
There is no perceptible difference in sound from bare wire as per my listening.
Speaker end wires I just soldered and use them as bare wire.
Just thought it may help some and since I did not want start a new thread.
Mx products are
http://mdrelectronics.com/categories...ryid=6&start=0
Dealers
http://mdrelectronics.com/dealer.php
Cheers.
  #17
Old 13th November 2008, 12:46 PM
spirovious is on a distinguished road
Mx products are
MX Products
Dealers
MX Products
Cheers.
Can 2mm banana fit in clip type Onkyo AVR spk connectors?
  #18
Old 13th November 2008, 12:52 PM
venkatcr is just really nicevenkatcr is just really nicevenkatcr is just really nicevenkatcr is just really nice
Quote:
Spirovious, do NOT use any banana or spade for a clip type connector. The best is bare wire. If you use a banana or any solid metal, the teeth in the clips will bite and spoil the metal or plating.
When you use a bare wire, if you need, once in a while remove the wire, clean the tips with Isopropyl Alcohol, and reinsert it again.
The Following User Says Thank You to venkatcr For This Useful Post:
spirovious (13th November 2008)
  #19
Old 19th November 2008, 11:28 PM
pradski's Avatar
just wanted give you all feedback about my 2mm bananas.
Other day accidentally one of the wires was pulled and the gold plated tip got cut off and was stuck in the terminal.
I have plugged in the rest of the left over.
Just thought of letting you know.
The Following User Says Thank You to pradski For This Useful Post:
spirovious (20th November 2008)
Sponsored Links
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Advertise Here
Copyright © 2006-2008, HiFiVision.com All Rights Reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
