Need to connect PC to Sony Home theater
Discuss Need to connect PC to Sony Home theater at the Audio & Video Cables within the HiFiVision.com - Audio Video Hi-Fi Forum; Hi, I have a Pc with Standard 3.5mm Jacks I want to connect it to ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > Audio Video Essentials > Audio & Video Cables
Audio & Video Cables Interconnect, speaker cables, component video cable, mains cable, etc
Advertise Here
Reply
Bookmark and Share Thread Tools
  #1
Old 4th July 2009, 11:56 AM
Reputation points: 10
harishgayatri is on a distinguished road
Exclamation Need to connect PC to Sony Home theater
I want to connect it to my SONY Home theatre system DAV DZ-570 which has
options.
DMPORT
OPTICAL IN
DIGITAL IN
is there anyway that I can get the cable i.e 3.5mm to Digital/Optical/DMport manner.
Thanks in Advance
harishgayatri
Sponsored Links
  #2
Old 4th July 2009, 12:59 PM
Reputation points: 232
reju has a spectacular aura aboutreju has a spectacular aura aboutreju has a spectacular aura about
Re: Need to connect PC to Sony Home theater
You can connect to Audio Stereo Line IN - Analogue
(I guess your HT does not have 5.1 analogue input.)
You will need 3.5 stereo to 2 RCA cable.
Of course you will not enjoy DD or DTS audio through this.
For DTS/ DD you will need a sound card with Optical/ Co-axial SPDIF output.
  #3
Old 4th July 2009, 01:45 PM
suprateep's Avatar
Reputation points: 241
suprateep has a spectacular aura aboutsuprateep has a spectacular aura aboutsuprateep has a spectacular aura about
DAV-DZ570 : DVD Home Theatre System : Home Theatre System : Sony India
the specs say it has got an analog in, optical in, coaxial in......use the line out (3.5mm to stereo RCA cable) from laptop to the analog audio in of the amplifier.
Interestingly it has also got a mini 3.5mm audio in (front mini) - so you can use a 3.5mm to 3.5mm audio cable directly between the line out of laptop and front mini in of avr
And yes in case you want to pass DTS, Dolby etc - you need an external SC (USB for laptop) - use the optical or coaxial to pass digital signal untouched
godspeed !!!
  #4
Old 4th July 2009, 02:09 PM
The analog in supports 2 channel only.
I would like to watch HD Movies on my LCD and hence enjoy it in 5.1 Dolby or DTS.
Ok
Which is the Budget soundcard I can get for my System.
My system has PCI slots not PCIe.
I am ready to keep my budget to Rs1000.
  #5
Old 4th July 2009, 02:21 PM
My onboard sound is based on SoundMAX Digital Audio.
It is giving me the option of AC3/PCM SPDIF.
When I use those options I am unable to hear sound from my 2 channel speakers.
If there is anything that can be done please mention it.
Thanks again
harishgayatri
  #6
Old 4th July 2009, 02:29 PM
suprateep's Avatar
Thanks again
harishgayatri
see if the SC supports optical toshlink output - then you can use an optical cable to transfer DD/DTSaudio from PC to amplifier.
Please note the realtek chips are generic and have many versions and have multiple HW implementations by mobo manufacturers - so its difficult to say if that can support digital signal out or not.
See if the line out outputs static noise if you are passign dolby 5.1/dts audio selecting ac3 d5.1/dts out - if it does then you can use a minitoshlink converter (spdif interface) and use a optical cable to connect the laptop to the PC
For ref check out
Recoton ADC902 Audio Video Cable - Yahoo! Shopping
Philips PH61043 Audio Video Cable - Yahoo! Shopping
Cables - SPDIF - Optical plug 3.5 mm: Compare Prices, Reviews & Buy Online @ Yahoo! Shopping
  #7
Old 4th July 2009, 02:38 PM
I think it is better that i give you the images of my PC.
Please give me a minute
  #8
Old 4th July 2009, 02:44 PM
This is my Pc's image.
These are the ports available behind my Home theater system
Please tell me what to do and what to ask the shopkeeper
harishgayatri
  #9
Old 4th July 2009, 03:07 PM
That is not my Home theater's image
It is something that i posted from google just for understanding becoz the ports look the same.
Sorry.
  #10
Old 4th July 2009, 05:29 PM
Reputation points: 376
marsilians is just really nicemarsilians is just really nicemarsilians is just really nicemarsilians is just really nice
Quote:
Originally Posted by cranky View Post
Digital output will be available on your motherboard, but it is not on the panel. There should be a header on the motherboard and it is possible to use it for digital output, but the extension bracket is not available separately, you will have to make one on your own, or get someone to make it for you.
The only other option is to buy a soundcard, I know of none within your budget of Rs. 1000/-, maybe other members will be able to suggest.
fleabay is the only option along with used.
eBay India: 5.1 Creative Sound Blaster 5.1 Sound Card (item 220443477548 end time 04-Jul-2009 18:55:02 IST)
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Need to connect PC to Sony Home theater
Thread Thread Starter Forum Replies Last Post
Want to connect my PC with Sony Bravia 32 LCD. HELP PLEASE! sambit Digital Cable and DTH 21 21st April 2012 04:22 AM
Sony home theater system with cassatte player samml Audio & Video Cables 2 25th February 2010 03:12 PM
Home theater for 50k compatible with Sony LCD klv-32v550a srinigk Home Theater 9 21st February 2010 06:34 AM
How to connect DAV-DZ 390 with Sony LCD ashishkala Home Theater 3 27th November 2009 08:28 AM
Home Theater Shopping (Sony dav dz 690 Vs 790 Vs Onkyo hts3100) tellranga Home Theater 16 19th October 2009 06:17 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
Recommended Websites - www.HiFiMART.com - www.ProSoundVision.com
