Cable talk-Qed,Kimber,Nordost
Discuss Cable talk-Qed,Kimber,Nordost at the Audio & Video Cables within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Try Solitone-X http://www.solitone.hu It will outperform pretty much anything from Kimber and AQ IMO. I ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > Audio Video Essentials > Audio & Video Cables
Notices
Audio & Video Cables Interconnect, speaker cables, component video cable, mains cable, etc
Advertise Here
Reply
Thread Tools
  #21
Old 30th June 2008, 09:31 PM
awedeophile's Avatar
awedeophile is on a distinguished road
Re: Cable talk-Qed,Kimber,Nordost
It will outperform pretty much anything from Kimber and AQ IMO. I have done A/B comparisons with cables costing 3-4x the price and none came close.
Sponsored Links
  #22
Old 30th June 2008, 09:36 PM
reignofchaos is on a distinguished road
^^I'd not make such a bold statement about cables. You might get a completely different result if the setup is voiced differently. The best cable for a particular system may be sub optimal for some other system while something that sounds average on one maybe the best for another.
At times I've noticed even a 1000 rupee monster interconnect outperform stuff which are a few orders of magnitude more expensive. Does it make the monster better than the other cables? Probably not... it just suited that system well. Cables are all about mixing and matching for a particular system. There's no one size suits all.
  #23
Old 30th June 2008, 09:49 PM
Hi, not really a bold statement. I have tried Kimber and AQ cables and IMO the Solitones were better and I am pretty sure they will be better in his Krell/Dynaudio setup too. The solitones have actually been tested on some very high end and varied systems in India and came close to being the top. At their relatively low price, they are a bargain!
  #24
Old 30th June 2008, 09:54 PM
Quote:
Again... you probably tried one particular kimber or audioquest and compared to one particular solitone on one particular system. Does that generalize to the fact that every solitone will outperform every kimber or audioquest? I find the evidence on that front to be pretty shoddy to say the least. Thats simply over generalization.
  #25
Old 1st July 2008, 01:58 AM
Solitone makes 2 models. I compared their better model (Solitone X) to a Kimber Select and an AQ Everest or something (one of their upper models) and it beat both. So I can generally say, it will beat most Kimber & AQ cables. For what it's worth it also beat the Virtual Dynamics Master (I owned this). I have no affiliation with the company, it's simply very good and a true value product.
  #26
Old 1st July 2008, 11:00 AM
dinyaar's Avatar
dinyaar is on a distinguished road
Quote:
Originally Posted by SaurabhK View Post
H Dinyaar,
Thanks for your reply. Well why do you say that I avoid the 8VS? Any oarticlar reason why I shoudl avoid it ?
I am currently using a 4 PR borrowed from a friend. Although it is only doing what a 4 PR can do.is quite lean and lacks soem detail..However, I am told that a 8 VS is much more punchier and musical. However, also got good feedback from a QED user.
Who deals in transparent wave?
VDH i dunno.. I had demoed a piece in my set up. Lacks musicality ( even though it was a low end entry level model ).
decisions decisions..
Well i have had all the kimbers over the years so thats simply an opinion on the sound with the Rotel/B&W combo i had then. The 8VS is actually recommended as the cable for the LF in a Biwired set up. If used in a single wired set up i found the highs lacking detail.Since its double the thickness of the 4PR u will get more bass weight but i doubt u will get a better tonal balance.
Qed i have never used so wont comment. Transparent can be had at Boomerang @ 022 26194452 /9820949395.
  #27
Old 1st July 2008, 12:00 PM
SaurabhK is on a distinguished road
Does Boomerange have an Email?
  #28
Old 1st July 2008, 01:03 PM
dinyaar's Avatar
Am sure they do but i dont have it. Call the cell No. i mentioned and speak to Grattin Vaze. They can also offer u straightwire,chord apart from transparent.
Try some supra cables in the said price range. Supra is one of those companies that actually make the cables themselves and am sure Lakozy(NAD/SUPRA distributor) has an outlet in delhi. As i mentioned earlier i like the transparent ICS but didnt think much of the entry level speaker cable i had tried. Albiet many years ago and god knows in what set up back then.
Am currently done with cables et all!!!!!!!!!!!!! Though am sure i will get the urge to get something better than the Kimber 8TC as my speaker cable.
Awedeophile have heard some good things about the Solitone cables from our forum member Shanti but have never heard them. Though i feel they would be way off the budget allocated by Saurabh.
Sponsored Links
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Cable talk-Qed,Kimber,Nordost
Thread Thread Starter Forum Replies Last Post
Component Video Cable vadiraj Audio & Video Cables 16 11th July 2008 12:23 PM
Nordost dealer distributor in India Neal Authorised Dealers 1 17th March 2008 09:38 AM
Kimber 8TC rashmikant Audio & Video Cables 1 14th December 2007 11:25 AM
speaker cable suggested rashmikant Audio & Video Cables 6 4th December 2007 10:49 AM
Kimber 8TC rashmikant Audio & Video Cables 1 26th November 2007 10:07 PM
Advertise Here
Copyright © 2006-2008, HiFiVision.com All Rights Reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
