samsung hdmi cable
Discuss samsung hdmi cable at the Audio & Video Cables within the HiFiVision.com - India's Audio Video Hi-Fi Forum; I recently bought a samsung hd 870 dvd player which comes with a free hdmi ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > Audio Video Essentials > Audio & Video Cables
Notices
Audio & Video Cables Interconnect, speaker cables, component video cable, mains cable, etc
Reply
Thread Tools
  #1
Old 21st April 2008, 06:33 PM
Chacko Koshy is on a distinguished road
samsung hdmi cable
I recently bought a samsung hd 870 dvd player which comes with a free hdmi cable
After having connected hdmi to my lcd i found there was no real visible difference in picture quality when i switched to coaxial.
Any suggestions ?
Chacko
Sponsored Links
  #2
Old 21st April 2008, 08:34 PM
ranjeetrain is on a distinguished road
Re: samsung hdmi cable
Your question reads like a banner.
HDMI cannot enhance the output. It will carry whatever signal is being sent. May be the DVD player's output doesn't warrant more than a coax.
It may also have something to do with the quality of cables. May be your coax is of far better quality than the HDMI.
  #3
Old 22nd April 2008, 11:44 AM
thanks for your comment unfortunately sometimes it takes a banner to get a reply.
With all due respect ,i was hoping to get a solution.
can anyone suggest a hdmi cable brand which could make a difference?
  #4
Old 22nd April 2008, 12:37 PM
particleman's Avatar
particleman is on a distinguished road
Perhaps if you post some details of your TV, such as model no., etc. then members who own it or know more about it will be able to help out. Specifically they may be able to tell you what level of quality to expect from your TV with various connections.
  #5
Old 22nd April 2008, 01:03 PM
Ditto. Please describe your system and we will try to help you in best possible way.
  #6
Old 22nd April 2008, 06:42 PM
Thanks a lot for your replies
Well,I have a 32" S series Sony Lcd from which the samsung hd 870 has been connected via HDMI.
Chacko.
  #7
Old 2nd June 2008, 10:56 PM
well chaps over the past few weeks i did notice a difference in some lower resolution dvds and vcds where the resolution seemed to be better through the HDMI than on a normal coxial connection.
Regards Chacko
Sponsored Links
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: samsung hdmi cable
Thread Thread Starter Forum Replies Last Post
Samsung Vs Sony LCD therider Television 23 4th September 2008 07:20 PM
DVI HDMI or Component Video? Mohan Audio & Video Cables 1 19th July 2008 11:22 AM
Onkyo launches Three new receivers with HDMI lakshmant Surround Amplifiers/Receivers 0 26th March 2008 09:57 PM
Help on HDMI setup planetavi Surround Amplifiers/Receivers 6 8th March 2008 08:21 PM
Best HDMI upconverting AVR under 50K spycatcher Surround Amplifiers/Receivers 9 1st March 2008 01:17 PM
Copyright © 2006-2008, HiFiVision.com All Rights Reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
