| Discuss Mains Power supply and Hi-Fi at the AV Enhancers & Room Acoustics within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Mains Power supply and Hi-Fi Optimising the power supply What's wrong with the mains supply, ... |
| Notices |
| AV Enhancers & Room Acoustics Discuss audio/video enhancers, room acoustics, tips and tweaks here. |
Thread Tools |
#1
Optimising the power supply What's wrong with the mains supply, can you improve it? Installing a dedicated supply. Mains, conditioning and filters. Battery supply? Will it improve the sound quality from your hi-fi setup? With hi-fi equipment it is not only the availability of a continuous electrical supply that is important, but also the quality of that supply. Again, some people may be surprised that something like electricity can be discussed in terms of quality but there are a number of factors which affect its quality and suitability for powering hi-fi eqipoment. They are:
What are the solutions? There are a number of measures that can be taken to improve the electrical supply which we feed into our hi-fi equipment. If you are serious about getting the best out of your system, you should consider installing a dedicated power supply from your consumer unit. The amount of work (and disruption) this entails is dependent on where your listening room is in relation to your consumer unit, what kind of consumer unit you have, whether it has the capacity to add another circuit, and how easy it will be to install the new cables. I can say, from my own experience, that all the trouble and expense is worth it. Modifications to the electrical supply have made noticeable improvements to the sound of my hi-fi system. And remember, the final signal which drives your loudspeakers contains a higher proportion of added (mains) electricity than the original signal. So, no matter how good your equipment is, the sound will still be dependent on the quality of the power supply. Having a dedicated mains supply is the building platform on which you can continue to provide better power to your equipment. A dedicated mains supply will isolate your hi-fi equipment from the rest of the electrical wiring in your home which may cause electrical interference. However, you should still make sure that the rest of the electrical system in your home is not producing any unwanted nasty effects. Make sure that the wires into each socket are secured and that the retaining screws are tightened. Check all earth wires are securely connected. Make sure all your electrical appliances are in good working order and check that the wires in the plugs are secure and that the clamping screws are tight. Some appliances like refrigerators produce interference when the thermostat switches the cooling system on and off. This can usually be cured by fitting a contact suppressor and VDR across the contacts of the switch. Make sure that all the mains leads on your hi-fi are in good condition and that the wires are securely held inside the plugs. It may sound daft, but it seems to improve the sound if you polish the pins of the mains plugs with a metal polish. Do the same with the fuses inside the plugs. The theory is that this makes for a better contact and lowers impedance but whatever the reason, it does seem to work. This polishing should be done about twice a year. |
| Sponsored Links |
#2
Re: Perfect Impediance.
Hi Hohan,
What should be the perfect impedence for the grounding?( Regarding above said subject). |
