Help required for a entertainment room set up
Discuss Help required for a entertainment room set up at the AV Enhancers & Room Acoustics within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Hello Srisha ... Try auditioning the Mission speakers before you decide on the speakers. They ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > Audio Video Essentials > AV Enhancers & Room Acoustics
AV Enhancers & Room Acoustics Discuss audio/video enhancers, room acoustics, tips and tweaks here.
Advertise Here
Reply
Thread Tools
  #11
Old 22nd September 2008, 04:49 PM
hifipal4all's Avatar
hifipal4all will become famous soon enough
Re: Help required for a entertainment room set up
Hello Srisha ... Try auditioning the Mission speakers before you decide on the speakers. They are very decent sounding both for Stereo as well as for the HT and its a 100% value for money speakers.
All the best!!!
Ramesh
Sponsored Links
  #12
Old 23rd September 2008, 11:58 AM
srisha is on a distinguished road
Hi Ramesh,
Who is the dealer for mission speakers in bangalore?
Thx
Srisha
  #13
Old 23rd September 2008, 07:38 PM
Well my friend Mr.Anand of Total Solutions is dealing with this brand in Bangalore and currently he is busy shifting the showroom to a new place. He will be operational in 15 days time. I will let you know once he is ready. Please PM me your contact number to me.
  #14
Old 4th October 2008, 03:05 PM
I am looking for a 3d converter, which can convert your 2d movies into 3d and also which can play 3d movies. I have seen one in the US but it can only be played on a CRT and the HDTV doesnt support it.
Pls let me know wherever it is available>
Thx
Srisha
  #15
Old 6th October 2008, 03:29 PM
vj_box's Avatar
vj_box is on a distinguished road
do you mean some thing like this?
VFX 2D to 3D Converter: Watch movies or TV in Real 3D
Vj
  #16
Old 6th October 2008, 06:24 PM
Thats right, but the one which you have mentioned can only play on a CRT and cannot be used for HD projectors or LCDs. As per the reviews online about this product - not many are happy since it only shows images in 3D and not the object popping ot of the screen.
After some research, I have found one - which is basically a software which supports 3D for HD.
Check this link -
2 DLP 3D Glasses IMAX DVD VR DDD 3-D Starter HDTV KIT! - eBay (item 120310566621 end time Oct-26-08 19:44:28 PDT)
This product is from IMAX who have developed products for theaters in the US and have seen some good reviews on this product. And this can make the images actually pop out of the screen. I am currently reviewing this product to ensure it work to my satisfaction.
Do you know of any similar products available in the market??
Thx
Srisha
  #17
Old 7th October 2008, 09:52 AM
vj_box's Avatar
mm,this one is pretty new to me,any way i will try and gather any info i get.
Vj
  #18
Old 7th October 2008, 11:49 PM
Here are the pixs of the ent room in its current state. Plastering would be completed in another week and then the electrical wiring would begin.
This pix below shows one side of the room which actually opens to a balcony, and needs to be enclosed. The problem is the building asscociation will not allow me to errect another wall or enclose with bricks. Which means I will have to create a seperate partition within the room leaving about 3 ft at the rear end of the room. This end will be the rear section of the room behind the seating area.
Will it be good enough if I enclose this with a thick glass of 12mm thickness intead of creating a partition which will save me a lot of space. Or is it good to have another wooden sliding windows with sound absorbing material over the glass enclosure.
Pls suggest,
The second pix below shows the viewing side,where an LCD will be placed and also a screen.
What if I interchange the viewing side to the balocny side, will it any better in terms of sound absorbness.
I need some ideas from all the experts who have spent a lot of time in designing theie mini theaters...
This is a crucial stage, and hence request your ideas to flow.
Thx
Srisha
  #19
Old 8th October 2008, 12:20 AM
Moderator
venkatcr has a brilliant futurevenkatcr has a brilliant futurevenkatcr has a brilliant futurevenkatcr has a brilliant futurevenkatcr has a brilliant futurevenkatcr has a brilliant futurevenkatcr has a brilliant futurevenkatcr has a brilliant futurevenkatcr has a brilliant futurevenkatcr has a brilliant futurevenkatcr has a brilliant future
Quote:
Putting a wooden partition and then covering the wood with sound absorbing material is on way. Another way is to put sliding wooded doors (thick wood, not a thin plywood) and cover that with a wall to wall heavy drape. This way you will have sound absorption as well as flexibility to use the balcony. You will keep your wife also happy.
The area that you use for a LCD screen has to be a permanent wall. You cannot mount a LCD screen on glass or sliding wooden doors. Even if you hand it from the ceiling, you cannot have a LCD screen near an area through which you can get rain or shower, or even light. Keep it as far away from an exit as possible.
  #20
Old 20th November 2008, 01:47 PM
Venkat, I am trying to send you a PM for some clarification, and seems like your inbox is full. Can you pls provide me an alternate email ID to reach you.
Thx
Srisha
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Help required for a entertainment room set up
Thread Thread Starter Forum Replies Last Post
Eagle Home entertainment - The Reader Blu -ray kapvin Movies 4 21st February 2010 08:15 PM
AVR Suggestion for a Central Entertainment Engine mvinoos What Should I Buy? 4 13th October 2009 10:37 AM
Home Entertainment and DVD Enthsiast Here newDEEP Introductions 1 14th September 2009 04:02 PM
A human is known by his name, a man is known by his entertainment rack specs! shaklebolt Introductions 8 25th June 2009 09:15 PM
1st HT Room ... Room has shifted to bigger pranab.beriya Surround Amplifiers/Receivers 24 27th June 2008 08:30 PM
Advertise Here
Copyright © 2006-2010, HiFiVision.com All Rights Reserved.
Recommended Websites - www.CameraVision.in
