| Discuss Help required for a entertainment room set up at the AV Enhancers & Room Acoustics within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Its been a long time since I updated this thread, actually not much work happened ... |
| AV Enhancers & Room Acoustics Discuss audio/video enhancers, room acoustics, tips and tweaks here. |
Thread Tools |
#21
Re: Help required for a entertainment room set up
Its been a long time since I updated this thread, actually not much work happened in the last couple of months since we were working on the other areas of the house. I have now resumed the work and is moving on a fast track, since i need to finish this room by the end of this month. The balcony which was open earlier has now been enclosed completely with mesh glass and an aluminium framework. The entire room is going to be completely accoustically treated and I have engaged anutone. After a lot of research, i finally closed this deal with Anutone since the quality of their work was far superior to the others. Below are some random pix of the entertainment room in its current state, the next steps are speaker wiring, projector, LCD mounts, false cealing. I need some reference for optic lighting for the cealing, if somebody know pls provide me the contacts. |
| Sponsored Links |
#22
srisha what is your deal with anutone and how much you are being charged for that.It may help others in the forum who are interested in sound proofing their hometheater rooms.
#23
Hello Srisha,
Hope you have got all the Required acoustical material of your need. I will suggest you to go for Gypsum ceiling instead of POP. Go for maximum density. post your ceiling design. |
#24
The file size is larger than the forum limits, I will resize it and post it later,
#25
Quote:
The false ceiling is made of Gypsum, and is of two layer with about 3" gap between the two for concealed lighting. |
#26
The following things have been completed as on date
False Cealing Wiring for 7.2 Projector and LCD Ceiling Mounts Elevated flooring in the rear Frame work for accoustic panels The below pix attached are about 2 weeks old when the wiring and the mounts were being fixed, I shall post the pix of the current this weekend. And the remaining work of completing the sound panels and wooden flooring to be completed by the end of next week. |
#27
Some more progress on the work and here are the latest pictures,
we have completed fixing the accousting panels. Work is on a slow pace, since I need to complete the rest of the house and then start the fabric work on the panels. |
| The Following User Says Thank You to srisha For This Useful Post: | ||
m4w (26th August 2009) | ||
| Bookmarks |
| Thread Tools | |
Similar Threads for: Help required for a entertainment room set up
| Thread | Thread Starter | Forum | Replies | Last Post |
| Bose 3•2•1 Home Entertainment System | GeoTracks | Home Theater In A Box | 11 | 10th March 2009 11:43 AM |
| 5.1 Set up required HELP | Rocky Bharucha | DIY | 4 | 4th February 2009 02:40 PM |
| Need Help - Bose 3.2.1™ GSX Home Entertainment System - any better products ?? | prkg | What Should I Buy? | 7 | 31st December 2008 11:39 AM |
| Help required | pksnathan | Phono/Turntables | 2 | 7th September 2008 08:08 AM |
| 1st HT Room ... Room has shifted to bigger | pranab.beriya | Surround Amplifiers/Receivers | 24 | 27th June 2008 08:30 PM |
