HiFiVision.com - Audio Video Hi-Fi Forum
Best device to record cable tv and export soft copy
Discuss Best device to record cable tv and export soft copy at the Blu-ray/DVD players & DVD/hard-disk recorders within the HiFiVision.com - Audio Video Hi-Fi Forum; I want to recrod tv and export it to files. DTH is encrypted so this ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > AV Sources > Blu-ray/DVD players & DVD/hard-disk recorders
Blu-ray/DVD players & DVD/hard-disk recorders DVD players/recorders and soon available HD-DVD/Blueray players
Advertise Here
Reply
Thread Tools
  #1
Old 11th July 2010, 07:51 PM
Pratters's Avatar
Reputation points: 40
Pratters is on a distinguished road
I want to recrod tv and export it to files. DTH is encrypted so this can't be done easily via DTH. What is the best device to get to record via cable tv? I can get a device from India or US. Tivo?
Please provide good options, expensive as well as cheap, india as well as US.
Sponsored Ads
  #2
Old 11th July 2010, 11:46 PM
gobble's Avatar
Reputation points: 907
gobble is a splendid one to beholdgobble is a splendid one to beholdgobble is a splendid one to beholdgobble is a splendid one to beholdgobble is a splendid one to beholdgobble is a splendid one to beholdgobble is a splendid one to beholdgobble is a splendid one to behold
Use this with your hdd recorder and the cable signal http://www.hdfury.com/
You will need component input in the hdd recorder.
Sent from my iPod touch
  #3
Old 12th July 2010, 02:58 AM
Pratters's Avatar
Re: Best device to record cable tv and export soft copy
I didn't understand any thing my friend. What is hdfury? Will it work with a tv which does not have hdmi?
Which hdd recorder to go for?
How will the process work?
  #4
Old 12th July 2010, 10:56 AM
stevieboy's Avatar
Reputation points: 545
stevieboy is a glorious beacon of lightstevieboy is a glorious beacon of lightstevieboy is a glorious beacon of lightstevieboy is a glorious beacon of lightstevieboy is a glorious beacon of lightstevieboy is a glorious beacon of light
hi pratters,
i was in the same position as you, wanting to record tv programs for seeing later again. what i remember is that you can get a dvd recorder, most of them come with a hard disk and capability to record content to a dvd later on. some of these have a built in tuner and the signal is routed from here to the tv. some have built in timers so you can keep everything on standby and it switches on to record at a preset time in case you're out of the house. sony makes some recorders you can check their india website for current models and i think panasonic also. recording to these tata sky recorders is pointless cos you can't transfer and when you fill the space the older material keeps getting deleted.
regards
  #5
Old 12th July 2010, 06:05 PM
Pratters's Avatar
Suggest me a good device please, available in India and US.
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Best device to record cable tv and export soft copy
Thread Thread Starter Forum Replies Last Post
MID Device Price and Availability in India. deba AV Lounge 13 28th April 2011 12:39 PM
exporting video from tv to a device via tv out and then converting it to soft copy Pratters Blu-ray/DVD players & DVD/hard-disk recorders 14 15th July 2010 10:50 AM
Which soft CD player is perfect for Xonar STX card? AMITNOIDA CD Players 29 16th January 2010 08:51 PM
Pls suggest device sunlinux What Should I Buy? 2 4th November 2009 08:24 PM
Stereo setup for soft music anbk123 What Should I Buy? 10 2nd March 2009 05:09 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199
