| Discuss Help with Sony Blu-ray Disc Player - BDP-S350 at the Blu-ray/DVD players & DVD/hard-disk recorders within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Hello, one of my relative is using sony BDP-S350 with sony HT-DDW5000 muteki 6.2 system. ... |
| Blu-ray/DVD players & DVD/hard-disk recorders DVD players/recorders and soon available HD-DVD/Blueray players |
Thread Tools |
#1
Hello, one of my relative is using sony BDP-S350 with sony HT-DDW5000 muteki 6.2 system. Now This sony muteki system doesn't have dolby true hd and dolby digital plus. He has connected the blu ray player with the receiver using a optical cable. The bluray player specification in the website says it is capable of " 7.1ch HD Decoding via HDMI (Dolby TrueHD/Dolby Digital Plus) ". My question is if we want to use the dolby true hd decoding capacity of the player can it be achieved with optical cable? Or since it is a 6.2 system a 7.1 decoding cannot be achieved. Another strange thing he reported that it is marked with region 5 for dvds.It plays region 5 dvds very well and other regions not so well. As per my knowledge goes a player is either region locked or it is region free. Is there any particular technology using which a player shows fondness over a particular region. Thanks in advance, Mahiruha. |
| Sponsored Links |
#2
Re: Help with Sony Blu-ray Disc Player - BDP-S350
The answer is NO.
The Blu Ray player will not send a decoded signal over optical or coaxial digital outputs. When connected in this manner it is the receivers job to decode the signal. In this case it does not have the capability. I am not familiar with this Blu Ray player but if it does have 7.1 channel analog outputs use this to hook it up to the receiver. This will allow you to hear the decoded signals of Dolby True HD or DTS Master. Then again the receiver needs to have 7.1 channel ananlog input The region thing is werid. On a player that has its region lock removed there should be no playback issues. Last edited by sandeepmohan; 2nd June 2009 at 07:43 AM. Reason: missed out on a word |
#3
Quote:
To get the 7.1 channel without HDMI is to use analogue audio connections from the BDP to the receiver. This will require 8 audio cables for connections. Quote:
#4
To get HD sound over Optical, BDp must downsample/scale from 192/24bit to 96/24bit or lower.In PC,sw like powerDVD does that.
Any BDp capable of doing that can output downscaled HD-aud over opt out. |
#5
DD or DTS 96/24 is not considered high definition audio format. Its the same as the DVD or DVD-A rate.
#6
Hello,
after reading the suggestions I looked at the manual of the bluray player to check the rear panel . To my surprize I saw there is no 7.1 audio out. Only digital, coaxial and optical out. another funny thing is it has stereo out. I am bit confused about this stereo out and not sure about its intended use. Hence it can be logically concluded that this bluray player's onboard dolby true HD decoder might have some capacity of doing it but there is no way to take that decoded signal out of the player. Unless it is connected to a receiver capable of true HD decoding it is not of any use. Thanks, Mahiruha. |
#7
First of all BDP 350 doesn't have analogue output so this is out of the question. Now to enjoy lossless codecs like dolby true hd or dts hd master audio I would suggest you to connect your player with your amp using hdmi cable (if your amp has one) then there would be an option in the players where you have to select the HDMI option Under the Audio Settings Menu select it as Auto and Turn off the 2Ch PCM option this would enable the player to decode all the HD audio within itself and send as 5.1/6.1/7.1 LPCM to your amp.
| The Following User Says Thank You to ashishkesarwani For This Useful Post: | ||
mahiruha (2nd June 2009) | ||
#8
Quote:
So at96/24 ,he can hardly get any difference with Htib. |
#9
Quote:
your answer is bang on target. Thanks a lot. I have read the manual in detail and it confirms what you say. This LPCM concept is really useful in the absence of analogue connections. To achieve this the audio output priority should be set to HDMI and Audio (HDMI) should be selected as auto. One portion in the manual says, "When the A/V receiver does not support HD audio but supports multi channel LPCM , upto LPCM 7.1 channel is output. " Hence I am guessing this 7.1 channel LPCM will get output wherever it finds a speaker and kind of accomodates itself. Thanks, Mahiruha. |
#10
Quote:
| Bookmarks |
| Thread Tools | |
Similar Threads for: Help with Sony Blu-ray Disc Player - BDP-S350
| Thread | Thread Starter | Forum | Replies | Last Post |
| Oppo BDP-83 .... - bluray disc player | audiodelic | Blu-ray/DVD players & DVD/hard-disk recorders | 227 | 19th August 2010 11:41 AM |
| Sony BDP-S350 Blu-Ray Player | sgmane | Blu-ray/DVD players & DVD/hard-disk recorders | 0 | 27th January 2009 08:20 AM |
| Sony BDP-S350 vs Pana DMP-BD30 | mandeep | Blu-ray/DVD players & DVD/hard-disk recorders | 11 | 15th January 2009 03:31 PM |
| Sony Releases Blu-ray player BDP-S350 in india | mandeep | Blu-ray/DVD players & DVD/hard-disk recorders | 15 | 22nd December 2008 04:11 AM |
| Sony Bluray Player BDP S350 | gopalk | Blu-ray/DVD players & DVD/hard-disk recorders | 1 | 5th December 2008 04:00 PM |
