| Discuss Car Audio for Fiat Palio@ Rs 15k at the Car Audio within the HiFiVision.com - India's Audio Video Hi-Fi Forum; My cousin installed audio system in his car which included a Pioneer head unit, Rockford ... |
| Notices |
| Car Audio Discuss in-Dash car units & CD/MP3 players, Amplifiers, Speakers, etc here |
Thread Tools |
#11
Re: Car Audio for Fiat Palio@ Rs 15k
My cousin installed audio system in his car which included a Pioneer head unit, Rockford Fosgate Components, Blaupunkt sub and a JBL 4 channel amp.
All without bill. Its almost a year and its working very fine So usually there is not a problem. The headunit is most vulnerbale part of the whole audio system. The lens tends to give problems. |
| Sponsored Links |
#12
Thanks everyone for the great suggestions:
ICED my Palio MJD: Pioneer 5050USB Front Component JBL GT5 650C Rear JBL GTO937 MDF Plank and Palio Antenna extra Total Rs 16.5K Sounds like dream
#13
Quote:
Genreally Amps don't fail if you dont overload it and same goes with the speakers. If there is a manufacturing defect you will come to know in 1 or 2 days of using. And as it is very less of a speaker is included in warranty Only issue you will have the headunit, where it might give problems (if your luck is bad) with the lens or loading mechanism. So I would suggest if you want to be safe go for a headunit with warranty. Else if i am not wrong 75 percent of people opt for without bill and warranty product as the price difference is quiet significant. |
| Sponsored Links |
