| Discuss Car Audio for Fiat Palio@ Rs 15k at the Car Audio within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Car Audio for a new Fiat Palio @ Rs 15k Looking for high end clarity ... |
| Notices |
| Car Audio Discuss in-Dash car units & CD/MP3 players, Amplifiers, Speakers, etc here |
Thread Tools |
#1
Looking for high end clarity for those intricate instrumentals and vocals, less power and poor HU display does not matter. Any suggestions will be appreciated. Thanks Amar |
| Sponsored Links |
#2
Re: Car Audio for Fiat Palio@ Rs 15k
Amar I can only suggest that you stretch a bit and go in for component kit with a Pioneer head unit and a JBL amp. the normal CD head unit costs around 7-8 (grey market) and the JBL power amp (2channel, powering the component) is around 3-4K and the JBL component kit is also in the same range so total 8+4+4=16K ! with this set-up you can get a very decent sound that you described,Offcourse don't expect any thunderous bass or anything (thinking that since you've used power amp ) but the mids and highs will be very good and faithfull !! Regards. |
#3
Quote:
Used the same set up in my dad's Swift - Sounds GOOD - comps sound good even without Amp. Though later, whenever your budget permits add JBL GT5 A604 4-Channel Amp - Rs. 7000/- |
#4
Quote:
#5
Has anyone heard of Mutant...!!!
They are great players in UK market, for AMPs and Speakers... They even have Head Units, but they are not much prefered. Speakers and Subwoofers and Mutant, when clubbed to Pioneer HeadUnit, sounds fantastic... Mutant is there basic series... Mutant-X is the one up series... And the best one Mutant-XXX Rockz... Check Out there website - WWW.MUTANT.UK.COM Mutant Series 505xc - Rs.5500 Component JBL Subwoofer Rs.3500 + Rs.1000 Box Rear Speakers - Nakamichi - Rs.3000 approx... Head Unit - Pioneer - 5050 - Rs.7,000 (New but w/o bill) (Not Grey Market) Wiring Kit - Rs.1,000 Total Will come to Rs.20,000 approx, but that will be a superb combo... You can consult Mr. Palani, Auto Planet, for the same, in Bangalore, he will be the best one to suggest you the best. Regards Mridul Goel |
#6
I second the suggestions about Pioneer and JBL given above by fellow members. They offer a good value for money in that price bracket.
Another one that I want to add to that list is: Blaupunkt speakers. They are clean and I like their sound quite a lot. |
#7
Thanks Guys for all the ideas to start hunting car audio however my main concern was can i use any good round speakers in the rear corner setting without fixing an extra wooden plank which kills the storage space.
How are Kenwood HU compared with Pioneer Any suggestions will be most welcome |
#8
Quote:
Dont know much about Kenwood As far as I know Alpine is the best and later on comes Pioneer and Blaupunkt. |
#9
Actually am totally out of car audio but will still give my 2 cents.
Pioneer is best VFM for head Unit. Am using a 5250 HU + Pioneer CD Changer + Pioneer Oval rears in my old Honda city for ages and it sounds very good. Much better than the Alpine set up i got factory fit in the new city and even better than the really poor (think its a damn clarion) set up in the Accord. On checking with my car audio gurus i changed the rear speakers in the Accord to a Blaupunkt oval (think its 3 way) speaker pair and the sound has improved a lot. Have heard the JBL speakers/bass tube in my young neighbours car and all i hear is a thump and an even louder thump but i would not really call it musical. Problem with Pioneer at least the speakers is that there is tremendous duplication so be careful. As far as blaupunkt goes i have a positive opinion on the speakers but HATED the Blaupunkt' Munich' HU that came in an opel corsa i bought/ soon sold a few years ago. Horrible sounding combo. Regards |
#10
Should i go for the whole car audio with B&W paying almost 30% extra or will a grey market stuff will do,please suggest is it worth paying the extra money where i can add an Amp for the same cost.
| Sponsored Links |
