pls suggest a music system for Hyundai i10
Discuss pls suggest a music system for Hyundai i10 at the Car Audio within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Hey Gang, Can you pls suggest a decent music system for Hyundai i10,no specific preference,and ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > In-Car Entertainment > Car Audio
Notices
Car Audio Discuss in-Dash car units & CD/MP3 players, Amplifiers, Speakers, etc here
Reply
Thread Tools
  #1
Old 4th August 2008, 01:59 PM
chandruybl is on a distinguished road
Thumbs up pls suggest a music system for Hyundai i10
Hey Gang,
Can you pls suggest a decent music system for Hyundai i10,no specific preference,and to be used only during the weekends,any help will be highly appreciated.
Rgds
Chandra mohan
Sponsored Links
  #2
Old 4th August 2008, 02:58 PM
rikhav is on a distinguished road
Re: pls suggest a music system for Hyundai i10
Hello and Welcome to the forum
Let us know what do you prefer and your budget, that way other members can suggest you better
By what you prefer i mean is
1) You want only speakers at the front or also at rear? If is going to be mostly 2 people traveling in car then it does not make much sense to install speakers in rear
2)Do you prefer a sub?
3) Would you want connect a I-POD to your system
I hope you got the idea
  #3
Old 4th August 2008, 03:20 PM
Wink Re: pls suggest a music system for Hyundai i10
Thanks for the reply Rikhav,I would prefer speakers on both the sides,front and rear,but not a sub since the budget would be around 5~6k all inclusive,will i get a set which can support an IPOD?thanks in advance.
Rgds
Chandru
  #4
Old 4th August 2008, 03:35 PM
Hi Chandru
I am not that well upto date with the market. But for a budget of around 6k if you want front and rear speakers and a decent mp3 playing head unit ituld be hard to get
I guess a decent Pioneer head unit with which you can connect your ipod (the one by which you can control the ipod from the head unit remote) will be around 5 or 6k
I would suggest you go step by step if you dont have a bigger budget for now. Go for decent components in the front and then when you want install the same or 6 X 9 speakers in the rear. Those 6X9 would be required to installed on the parcel shelf or would need boxes which would eat up your boot space. So its good to install component speakers which fit in the door. Do check what size components the I10 door panel can take.
I will check with some friends and give you the exact model number of Pioneer head units. Alpine is way better then Pioneer in terms of sound quality but it would be really out of your budget
Sponsored Links
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: pls suggest a music system for Hyundai i10
Thread Thread Starter Forum Replies Last Post
Want to build a pro music system mostly listening to metal music + lot of divx movies topazamp123 Speakers 19 4th November 2008 01:22 PM
Suggest Micro / Mini Hi-Fi System for Bedroom Techlover Introductions 2 10th March 2008 07:33 PM
2.1 or 3.1 component music system under 25K vilfy Introductions 5 9th October 2007 08:53 AM
Please recommend a music system for Hyundai Getz Jagat Car Audio 4 16th August 2007 03:54 PM
Recommended Music system for Hyundai Verna daumaster Car Audio 2 16th December 2006 02:06 PM
Copyright © 2006-2008, HiFiVision.com All Rights Reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
