Polk Audio
Discuss Polk Audio at the Car Audio within the HiFiVision.com - India's Audio Video Hi-Fi Forum; hi Dushie, well, i currently do have the JBL GTO 937 speakers installed and I ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > In-Car Entertainment > Car Audio
Notices
Car Audio Discuss in-Dash car units & CD/MP3 players, Amplifiers, Speakers, etc here
Reply
Thread Tools
  #11
Old 19th August 2008, 12:18 AM
prashant_dv is on a distinguished road
Smile Re: Polk Audio
hi Dushie,
well, i currently do have the JBL GTO 937 speakers installed and I dont have any problem with the performance of it, but just that one of the speakers started to give me trouble.. something rattling continously inside the speakers.. moreover, i have been eyeing the POLK for some time... which is why i thought of this move...
Sponsored Links
  #12
Old 19th August 2008, 02:46 PM
panditji is on a distinguished road
Re: Polk Audio
Any idea who deals in Polk Car audio in Delhi?
  #13
Old 19th August 2008, 03:48 PM
Re: Polk Audio
i dont know any dealer names, nor am i able to find one after googling
  #14
Old 19th August 2008, 04:47 PM
rikhav is on a distinguished road
Re: Polk Audio
Quote:
I am sure you will be able find shops which sell POLK products. Ofcourse, many of them would be dealing in grey market products only
Just look around in shops who are famous for car audio installation. You will get some information from somewhere
  #15
Old 19th August 2008, 05:05 PM
Dushie's Avatar
Dushie is on a distinguished road
Re: Polk Audio
Quote:
Panditji
best is to try in karol bagh market, where u have car accessories shops, should be able to get them there,
  #16
Old 19th August 2008, 05:12 PM
Re: Polk Audio
Thanks Dushie, Rikhav...Will check out Karol Bagh..
  #17
Old 7th September 2008, 01:16 AM
pradski's Avatar
pradski is on a distinguished road
i used sony xplod to my wife's palio, and they really were bad.
So I went for polk audio oval's for rear. They sound really better.
The problem is they can't tolerate more volume.
They jarr at high volume.
Trying to get rid of them to good old pioneer.
Which are still doing great job since 4 years in my car.
Not tried others
  #18
Old 7th September 2008, 01:23 AM
Re: Polk Audio
Not tried others
IMO, there is no comparision between Sony Xplod range of car audio speakers and Polk audio car speakers
Sony is way too bad
Now about the problem you say you have with Polk audio speakers will be more to do with your headunit rather then the speakers
Are you using an amp or have connected the speakers directly to the head unit?
Head units produce max of 15-20 watts and generally perform very bad at high volumes. So i would suggest before changing your speakers check out what the problem exactly is and if you like to listen at quiet high volumes try to add a good 2 channel amp
  #19
Old 7th September 2008, 01:39 AM
pradski's Avatar
Thank you rikhav,
In fact I took out my pioneer head from my car and put in this new.
(my wife is not a fan of music so much, the set up is for long travel of us)
That head is supposed to be a good one.
It was doing very well with my 4 way 450w pioneer speakers.
And since the guy didn't have same speakers I had to put this way.
I have not connected the amp.
I was only testing in high volume i listen in moderate vol.
I am thinking of amp and sub later.
  #20
Old 7th September 2008, 01:45 AM
Re: Polk Audio
Thank you rikhav,
Even at moderate volumes, the sound quality will be definately better if you connect an amp. But if you can live with the sound quality your head unit produces at moderate volumes then no point spending
By the way what head unit are you using?
I feel there is a lot of tweaking needed in head units to get the right sound which you like with 100 features affecting the sound output.
Alpine, as far as i know have basic functions so not much of a headache but sound quality wise they are way too good. But prices are also quiet more then Pioneer head units
Sponsored Links
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Polk Audio
Thread Thread Starter Forum Replies Last Post
Polk Audio RM705 5.1 Home Theater System kumareshwar Speakers 10 9th August 2008 11:53 AM
CANTON Vs POLK mhushain Speakers 3 22nd July 2008 11:05 AM
Velodyne CHT 10/12R Vs Polk Audio DSW PRO 500/600 Vs Sonodyne SLF 200A vivekd1999 Speakers 5 6th June 2008 09:49 PM
polk vs jamo vs wharfedale mandeep Speakers 12 28th March 2008 11:26 PM
Polk Audio dealer distributor in India Neal Authorised Dealers 0 27th November 2006 10:39 AM
Copyright © 2006-2008, HiFiVision.com All Rights Reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
