| Discuss Polk Audio at the Car Audio within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Hi, How would you rate the Polk Audio MMC690 ( MOMO ) speakers for the ... |
| Notices |
| Car Audio Discuss in-Dash car units & CD/MP3 players, Amplifiers, Speakers, etc here |
Thread Tools |
#1
How would you rate the Polk Audio MMC690 ( MOMO ) speakers for the car ? The 6 x 9 " 3 way speakers have 300W RMS and 100W RMS continuos power handling capacity. Also, which AMP would be better a 240W RMS JBL AMP or a 350W RMS SONY XPLOD ? Awaiting advice & info.. |
| Sponsored Links |
#2
Re: Polk Audio
Hi there,
I have no experience with polk Audio so cant comment on that. But please stay away from Sony Xplod. Be it a head unit, speakers or amps JBL is way better for amps and speakers then Sony Xplod |
#3
Hi rikhav,
thanks for the info, will keep that in mind...! Regds, |
#4
Re: Polk Audio
Hi Prashant
I have to add that I have read about people installing Polk audio component speakers in their cars. This information is from some other forum. I think quality wise they are quiet good but not sure about the prices, If my guess is right they come in the hi-end car audio section I was not totally sure about this information so did not post it earlier. Just check out the prices of different brands which are there in the market. By the way you still have to buy a headunit or you already have one? |
#5
Well, I already have a Sony Xplod Headunit : CDX-GT410 installed in my car. They currently power my JBL GTO 937 6 x 9 speakers at the rear.
#6
Re: Polk Audio
Okay...
If possible go for a 4 channel amp for future upgrades(if you are thinking of installing components in the front). You can bridge the 2 channels each and use it in 2 channel mode, so you use the full potential of your amp and speakers. If you are not going to add front speakers, go for 2 channel amp which compliments your current JBL speakers perfectly. If you are not keen for heavy bass the 6X9 should produce enough bass if used with a properly matched amp. |
| The Following User Says Thank You to rikhav For This Useful Post: | ||
prashant_dv (18th August 2008) | ||
#7
thanks rikhav,
i will check out the options and let you know. mostly this weekend i should end up with something... will keep what you have mentioned in mind b4 i buy.. and yes, the POLK audio is from the hi-end car audio section and i am looking forward to get my JBL's replaced with the POLK speakers since it will be a 1 level upgrade from my current setup... will keep you posted.. |
#8
Re: Polk Audio
Prashanth:
Take a look at Boston Acoustic speakers for car also. I have two reasons for saying this. 1. They have been around for a long time manufacturing speakers for cars. 1. I have them fitted in my car along with a JVC head unit. They seem to sound much better than the Blaupunkt speaker cum head unit I had in my previous car. Cheers |
#9
Re: Polk Audio
Hi Venkat..
i will look into what models are available from BOSTON and will do.. thnx for the info |
#10
Prashant also look at the famous JBL GTO 937 series, due to public demand they have relaunched the same, these speakers provide a bang for your buck, and will pair well with JBL amps
| Sponsored Links |
| Bookmarks |
| Thread Tools | |
Similar Threads for: Polk Audio
| Thread | Thread Starter | Forum | Replies | Last Post |
| Polk Audio RM705 5.1 Home Theater System | kumareshwar | Speakers | 10 | 9th August 2008 11:53 AM |
| CANTON Vs POLK | mhushain | Speakers | 3 | 22nd July 2008 11:05 AM |
| Velodyne CHT 10/12R Vs Polk Audio DSW PRO 500/600 Vs Sonodyne SLF 200A | vivekd1999 | Speakers | 5 | 6th June 2008 09:49 PM |
| polk vs jamo vs wharfedale | mandeep | Speakers | 12 | 28th March 2008 11:26 PM |
| Polk Audio dealer distributor in India | Neal | Authorised Dealers | 0 | 27th November 2006 10:39 AM |
