HiFiVision.com - Audio Video Hi-Fi Forum
What is AUX ? and how to use it ?
Discuss What is AUX ? and how to use it ? at the Car Audio within the HiFiVision.com - Audio Video Hi-Fi Forum; Hi all, I have Pioneer player in i10. The player has a Auxilary mode to ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > In-Car Entertainment > Car Audio
Car Audio Discuss in-Dash car units & CD/MP3 players, Amplifiers, Speakers, etc here
Advertise Here
Reply
Thread Tools
  #1
Old 9th October 2008, 01:10 AM
Reputation points: 10
Aryan is on a distinguished road
Hi all,
I have Pioneer player in i10. The player has a Auxilary mode to run things like ipod.
could you please advise how to use it. coz the cable that it has attached with the player does not play my Sony MP3 Walkman Series player.
Thanks,
Sponsored Ads
  #2
Old 9th October 2008, 02:10 AM
unleash_me's Avatar
Reputation points: 275
unleash_me is a jewel in the roughunleash_me is a jewel in the roughunleash_me is a jewel in the rough
Re: What is AUX ? and how to use it ?
...not familier with car audio. Hope someone can help you out here.
All the best.
  #3
Old 9th October 2008, 08:44 AM
persiflage is on a distinguished road
Hi Aryan,
Can you describe the problem in more detail? Usually the following sequence works:
- Switch on the deck
- Select channel to 'Aux', using controls that allow you to switch between cd/ tape/ tuner/ aux etc.
- Plug in your external device into the Aux port
- Play your device!
  #4
Old 9th October 2008, 05:52 PM
Quote:
Originally Posted by persiflage View Post
Hi Aryan,
- Play your device!
Hi Persi,
The Sequence you've given is correct i.e, switch on the deck, select 'AUX' from the deck panel, Connect external device to Aux port.
Now the Aux port is an "A" male USB cable coming out of the deck.
External devise is Sony NW-A608 MP3 player with USB mini "B" outlet to charge the devise at one end and headphone connection at the other.
I tried to connect the device from USB side and then headphone side but doesn't seem to work.
I don't really know how to explain the technicality of the whole thing but I have tried.
Hope someone can help.
Thanks,
  #5
Old 9th October 2008, 06:08 PM
Reputation points: 248
rikhav has a spectacular aura aboutrikhav has a spectacular aura aboutrikhav has a spectacular aura about
Can you please give the model number of your Pioneer HU
That will make things easy to explain you
  #6
Old 9th October 2008, 06:19 PM
Nikhil's Avatar
Reputation points: 408
Nikhil is just really niceNikhil is just really niceNikhil is just really niceNikhil is just really niceNikhil is just really nice
Have you tried using the correct cable?
USB Cables - Cables
  #7
Old 9th October 2008, 08:10 PM
Quote:
USB Cables - Cables
Actually I did but it did not help.
Thanks,
  #8
Old 9th October 2008, 08:14 PM
Model No : DEH-P4800MP.
Thanks,
  #9
Old 9th October 2008, 10:38 PM
Hi aryan
I checked the manual of 4800 and it says it has 2 aux connections
One which uses stereo mini plug and another IP-BUS-RCA connector.
I guess the one which uses stereo mini plug would be useful for you as you would be connecting your Sony MP3 player by its headphone out.
So maybe its just that you have to switch between AUX1 and AUX2?
If you are using the stero mini plug there is no reason why it should not play.
  #10
Old 9th October 2008, 10:49 PM
Hi aryan
Thanks for going thru the trouble of reading the manual.
I am not carrying my deck today, I might be wrong with the model number, sorry about that, but I definitly be doing some R n D and will be updating all on the results.
Thanks for help
Aryan
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199
