HiFiVision.com - Audio Video Hi-Fi Forum
Best music system(DVD player,speakers & amps)
Discuss Best music system(DVD player,speakers & amps) at the Car Audio within the HiFiVision.com - Audio Video Hi-Fi Forum; Hi all, I have Chevrolet aveo brand new car and my budget for in car ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > In-Car Entertainment > Car Audio
Car Audio Discuss in-Dash car units & CD/MP3 players, Amplifiers, Speakers, etc here
Advertise Here
Reply
Thread Tools
  #1
Old 11th February 2009, 09:25 PM
Reputation points: 10
itsmemadhans@hotmail.com is on a distinguished road
Thumbs up Best music system(DVD player,speakers & amps)
Hi all,
I have Chevrolet aveo brand new car and my budget for in car music system with speakers is 50 K.
MY priorities are need the crystal clear sound like my home used Bose speakers and also need the punch effect which nice clear banging base effect( not like loud noise).
please suggest me which brand to go for to get player,amps (if needed) and speakers .
i heared that JBL,JVC,pionner,polkaudio are one of the best ones..pelase suggest me which one to go suiting my budget also tell me the best brands to go for which has crystal clear sound output with nice base effect.
Sponsored Ads
  #2
Old 13th February 2009, 11:41 PM
grubyhalo's Avatar
Reputation points: 338
grubyhalo is a jewel in the roughgrubyhalo is a jewel in the roughgrubyhalo is a jewel in the roughgrubyhalo is a jewel in the rough
Re: Best music system(DVD player,speakers & amps)
Quote:
Originally Posted by itsmemadhans@hotmail.com View Post
Hi all,
If I had 50K for a sound system for my car, the following would be the probable components I'd select. Please remember that I do not know the exact price of these components but it should not be way off your target budget:
Pioneer DEH-4190SD head unit: Excellent feature set and decent sound quality. IMHO, Pioneer gives you the best bang-for-the-buck quotient in the market, though the quality is not what it used to be.
Infinity Kappa 5 1/4" 2-way components for the front: These are priced slightly on the higher side but well worth it IMHO. Though made by the same parent company as JBL, these are much better sounding and has unbeatable clarity in it's price range. Strangely, most dealers seem reluctant to stock the Infinity brand and you usually would have to have them ordered.
Infinity Kappa 6X9 3-way multi-comp. for the rear.
Pioneer GM-6300F 4-ch. amp: You would really need a decent amp for the Infinity components and the sound would be more than just a step above the built-in amps on the head-units.
Pioneer TS-W1207D4
12" dual-coil sub: Though I do not have experience with this particular model, I've always found Pioneer subs to have good VFM for their price. Make sure the installer mounts this sub on a sealed box and not a ported one to ensure tight and fast bass.
Pioneer GM-D8400M Class D amp for the sub: If the cost of this pushes your budget over the limit, you could go in for a cheaper class D amp from Sony or similar and still not lose too much sound quality. Other than the sub-amp, I would stay way clear of anything Sony.
This might be slightly over what you would be looking to spend, but IMHO these would be well worth it and might even end up sounding better than your home setup. Whichever way you go, please post back with your decision and listening impressions. Good luck!
  #3
Old 15th February 2009, 10:00 AM
Hi man thanks for the reply,
but recently i visted a music store with best technitial in my town and he suggested me to go for alpine mp3 player,
FOCAL 6 inch front speakers,MTX back speakers and subwoofer and a MTX amp and all package costs me around 70 K which is the best package used for music listenenrs who love th most ...and its the best in the world...please suggest me how these focal speakers are...
he told be focal speakers are best in the world..
  #4
Old 15th February 2009, 12:10 PM
Rem's Avatar
Rem Rem is offline
Reputation points: 75
Rem will become famous soon enough
For the player Alpine has to be one of the best
  #5
Old 15th February 2009, 07:52 PM
Reputation points: 793
hemantwaghe is a splendid one to beholdhemantwaghe is a splendid one to beholdhemantwaghe is a splendid one to beholdhemantwaghe is a splendid one to beholdhemantwaghe is a splendid one to beholdhemantwaghe is a splendid one to beholdhemantwaghe is a splendid one to behold
I personally feel Blaunkupt is equally good.
Do not blow money on any one componant.
Also are you using normal cables?? As car audio enthu too use special cables.
You wanted a dvd player - so you want to watch moves in car? So what type of screen you are looking for? You have not discussed this.
Also be wary from the people who claim that they are supplying the best... and it is good you have budget - cause one of the most expensive car audio componants are Mcintosh
McIntosh | Car Audio
I did not get prices but this ebay page is sufficiant - you may end up spending 75 K on single componant!!!
mcintosh, Car Amplifiers, Car Audio In-Dash Units items on eBay.com
Anyway stick to a budget - and do not think bose is benchmark -- as I was a bose devotee earlier who has matured ,,, and note - bose car audio systems are not available as aftermarket fitments!! So anyone offering it must be fake!!
Frequently Asked Questions - Bose Automotive Systems Division
  #6
Old 15th February 2009, 09:24 PM
skt skt is offline
Reputation points: 11
skt is on a distinguished road
I just done it for my Getz.
1st need a good player - alpines or some top end Kenwood for sound quality. consider one with support mass storage std USB port. (we can attached a HDD with songs on it.)
2nd Speakers i taken a pair of 6.5" Component speaker from Bull audio with 10" sub woofer.
3rd a 4 ch amp 1st two channel to drive my front door component speakers next two channel clubbed together to drive the SUB. I took the amp also from bull audio for a better matching with speakers. TCO: INR 48k. also need speaker cable, ICs and amp wiring kit, Frond door dampening- noise kill.
-skt
  #7
Old 15th February 2009, 11:06 PM
magma's Avatar
Reputation points: 839
magma is a splendid one to beholdmagma is a splendid one to beholdmagma is a splendid one to beholdmagma is a splendid one to beholdmagma is a splendid one to beholdmagma is a splendid one to beholdmagma is a splendid one to behold
Focal is a reputed brand and have god quality stuff but i find them a bit too expensive for the sound they deliver.specially the focal polyglass
However if you lke them and can afford them then its good.
go ahead
JBL Power series components are also good here
Spend upto 12k here ( if you are driving)
however just make sure they are component speakers ( 2 6inch midbasses and 2 tweeters with crossovers) and not coaxials
for the budget hes given you they better be compos.
Now as for the amp and rear speakers his suggestion of MTX is ok .
you can do better definetely
Try the JBL 1004 Amp its avaible for 13-14k with bill and 10 k in the grey market.its a 4 channel amp that deleivers 100rms odd per channel
There is also another 4 channel ground zero amp which retails for 11k and delivers 75W per channel
For the sub MTX is fine according to your description of the bass you want.
However there are brands like Ground Zero , Illusion and ID if you can afford them.
i love ID's personnaly
spend 8-10k here
For the rears it doesnt mater much if youre the one driving.
MTX is fine and so are Infinity Kappa 6*9
i would advice not to spend over 7-8 k here ( again thats if youre the one driving)
bridge 2 channels of the 4 channel amp for the sub and use the other two channels for the component speakers upfront.
The rear 6*9's can be driven off the HU
you will need to spend 2k forbuilding the sub box,3-4k on wiring and 2 k on the install
that should be about 50k
now if you dont drive and sit behind then things will change a bit
  #8
Old 15th February 2009, 11:56 PM
Reputation points: 376
marsilians is just really nicemarsilians is just really nicemarsilians is just really nicemarsilians is just really nice
Hi all,
If you are satisfied with Bose at home then you can get the same effect for much less than 50K, go to any audio store and get a mp3 player with the appropriate car speaker and dont even both with an amp and you should be fine.
One thing to remember, you car is affected by external and internal noises unlike your home. So getting it to sound really good (unlike Bose ofcourse) will be hard and expensive and time consuming.
  #9
Old 16th February 2009, 01:18 AM
Reputation points: 2845
venkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond reputevenkatcr has a reputation beyond repute
What ever you buy, there are a couple of things I have found to be invaluable in a car system.
1. An USB port.
2. A full function remote control.
3. A screen for the player.
Over the last two days, I plugged a 4 GB USB stick in my car's player, and realized it is near impossible to choose the song you want - by title, by singer, or by album. I had over 300 songs, and got tired after sometime. I am so used to seeing the list on my computer or TV. I think a good remote should help.
I think a player with a screen would also help by displaying the directory structure. That with a good remote would solve the issue.
  #10
Old 16th February 2009, 08:45 PM
Hi Guys thanks for all your suggestions
The technitian was telling me about FOCAL polykevlar front speakers
he said it cost me around 16 k pair and it was the best speakers for listeninig to rock kind of music..pleas suggest me if its true.
Or else can i use MTX itself for front speakers ......?
also he told me tht he wil use amp which has 75W rms 4 way output each and he will bridge 2 output(150) to give it to subwoofer , is it ok or do i need more power to give it to subwoofer?
mainly i am rock,hiphop music lover please suggest me the best to go for..
One more thing, first i planned ot buy a touchscreen DVD player from JVC which costs me around 25k withh bill but since i am a best music love the technitian told me not to go for DVD players as these dosent produce good sound,so he suggested me alpine mp3 player whcih costs me 16K in grey market.is it good ot buy grey markt and does mp3 player produce good sound than dvd player?
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Best music system(DVD player,speakers & amps)
Thread Thread Starter Forum Replies Last Post
Want to build a pro music system mostly listening to metal music + lot of divx movies topazamp123 Speakers 30 16th November 2013 02:53 PM
Need on choosing Speakers And Amps Etc. Rajagamesbond007 Speakers 15 17th December 2009 08:19 PM
Music system for Indian classical music mmjoshi Introductions 22 1st November 2009 04:02 PM
Canton speakers -Full text of 472 post disc on speakers, amps and such things in life srramanujam Amplifiers 8 17th August 2009 11:30 AM
Speakers And Amps reiki Speakers 7 13th July 2007 12:23 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
