HiFiVision.com - Audio Video Hi-Fi Forum
Sony TC-366 Solid State Reel to Reel
Discuss Sony TC-366 Solid State Reel to Reel at the Cassette / Tape Decks within the HiFiVision.com - Audio Video Hi-Fi Forum; Gents - I very recently inherited a Professional Vintage Sony TC-366 Solid State spool player ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > AV Sources > Cassette / Tape Decks
Cassette / Tape Decks Cassette and tape decks
Advertise Here
Reply
Thread Tools
  #1
Old 21st January 2014, 01:09 PM
Record Player's Avatar
Reputation points: 620
Record Player is a name known to allRecord Player is a name known to allRecord Player is a name known to allRecord Player is a name known to allRecord Player is a name known to allRecord Player is a name known to all
Gents - I very recently inherited a Professional Vintage Sony TC-366 Solid State spool player along with maybe 50 English classic tapes.
Some key highlights of this deck:
Classic model from Sony TC-366 is a 4-track, 2-channel stereo / mono.
Special features are:
Noise supressor to cut off high frequency noise.
Tape-tension regulator to reduce flutter and wow.
Automatic shut-off mechanism.
Tape selector for Low noise or High Output.
Slanted cabinet designed for convenience of, operating in either horizontal or vertical use.
7-1/2 and 3-3/4 are ideal for recording music when best sound quality is desired.
1-7/8 is ideal for speech especially when longer recording time is needed.
Built in Noise Suppressor allows full pass-band for the major part of the audio frequency range, as it does not affect response frequencies below 9kHz.
Mixing can be made by using the mic inputs and the RCA inputs simultaneously.
Sound on Sound function composing a mixed recording on one track tape,and a new external signal through one of the microphone input.
This option on 366 can create a one person record a duet, trio or other special effects.
Now, ive been told the motor has burned out and needs replacement and I don't think this is easy to find.
What do you reckon of this deck and how difficult is it to replace this part. Can I look at other brands for this motor and will it work?
Looking forward to your suggestions as this is my first attempt to look after these.
The Following 2 Users Say Thank You to Record Player For This Useful Post:
Sponsored Ads
  #2
Old 21st January 2014, 01:32 PM
Tanoj's Avatar
Reputation points: 138
Tanoj will become famous soon enoughTanoj will become famous soon enough
Re: Sony TC-366 Solid State Reel to Reel
the deck looks great
My suggestion on the repair part is , go step by step process
first open the deck and check if the motor is actually gone bad or is it not getting power
if gone bad then try to check if you find any specification written on it, that will help you if you come across same spec motor
All the best
Tanoj
  #3
Old 21st January 2014, 09:24 PM
Reputation points: 855
kuruvilajacob is a splendid one to beholdkuruvilajacob is a splendid one to beholdkuruvilajacob is a splendid one to beholdkuruvilajacob is a splendid one to beholdkuruvilajacob is a splendid one to beholdkuruvilajacob is a splendid one to beholdkuruvilajacob is a splendid one to behold
I am just getting my vintage Akai M-8 valve Reel to reel back on track. I did not use it for a very long time and both output transformers were burnt. Just got them rewound. You should really check and see if the problem is with the motor
The Following User Says Thank You to kuruvilajacob For This Useful Post:
  #4
Old 22nd January 2014, 12:38 PM
Quote:
A good suggestion Sir. I will have this checked first. This player looks so intriguing and cant wait to start play. I've read that these players do produce some quality sound.
  #5
Old 22nd January 2014, 01:39 PM
Reputation points: 14
sanjsin9 is on a distinguished road
looks kool..
  #6
Old 22nd January 2014, 03:08 PM
reubensm's Avatar
Reputation points: 2187
reubensm has a reputation beyond reputereubensm has a reputation beyond reputereubensm has a reputation beyond reputereubensm has a reputation beyond reputereubensm has a reputation beyond reputereubensm has a reputation beyond reputereubensm has a reputation beyond reputereubensm has a reputation beyond reputereubensm has a reputation beyond reputereubensm has a reputation beyond reputereubensm has a reputation beyond repute
If the motor is burnt, you've had it, difficult to get a spare. So lets hope its not the case.
I have a high end Akai GX630D with a burnt motor and I somehow managed to find an expensive NOS replacement in the United States, after nearly a year of searching. Mine has a direct drive mechanism which is quite cool, and eliminates the need for those complicated mechanicals and rubber belts.
The interesting thing about the machine which I got is that it is in almost brand new condition in original box and packaging.
Need to change its filter caps as they seem to have dried electrolytes, due to long-term storage (slight powersupply hum can be heard)
Your machine was one of the Sony workhorses from the late 1960s and 1970s, and if serviced well, will definitely sound great.
7 1/2 inch speed is the best for any kind of recording but your play-time will drop drastically.
The Following User Says Thank You to reubensm For This Useful Post:
  #7
Old 22nd January 2014, 04:03 PM
Thanks Reuben for these details. Well I only hope the motor has not gone kaput! Good thing is that I stay very close to an extremely knowledgeable person/technician who can work on these players. Lets see how it goes.
On another note, I've never used these players earlier so don't know what to expect. I intend to just listen to those 50 English classic tapes I have. Do you reckon anything else?
And Oh, surely now you are a complete Direct Drive Fan on all mediums on music equipment
Cheers...
  #8
Old 23rd January 2014, 05:05 PM
My Akai M-8 is one of the most collectible Reel to Reel. I am also trying put together a Nakamichi-1000 Tape Deck.Again a collectible item. More about these later.
  #9
Old 23rd January 2014, 05:15 PM
Reputation points: 857
Rajiv is a splendid one to beholdRajiv is a splendid one to beholdRajiv is a splendid one to beholdRajiv is a splendid one to beholdRajiv is a splendid one to beholdRajiv is a splendid one to beholdRajiv is a splendid one to behold
The single ended EL84 tube amps in the Akai M8 are very good.
My new Akai M-8 mono amps - AudioKarma.org Home Audio Stereo Discussion Forums
https://www.google.co.in/search?q=ak...w=1024&bih=571
Rajiv
  #10
Old 25th January 2014, 12:03 PM
Reputation points: 436
quad is just really nicequad is just really nicequad is just really nicequad is just really nicequad is just really nice
@OP: It may not be a motor problem, but just a faulty motor run cap.
Antique Radio Forums • View topic - OT--Sony TC-366 Reel to Reel
http://archive.siliconchip.com.au/cm...6/article.html
The Following 2 Users Say Thank You to quad For This Useful Post:
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Sony TC-366 Solid State Reel to Reel
Thread Thread Starter Forum Replies Last Post
Reel-to-reel enthusiasts? sughosh Vintage Audio 45 15th November 2013 11:00 PM
Help with Grundig Amp/Tape Deck & Akai Reel to Reel coaltrain Vintage Audio 55 17th July 2012 05:54 PM
Reel to reel taperecorder DVSAMANT Cassette / Tape Decks 8 24th June 2011 06:07 PM
reel to reel recorders treasure trove! stevieboy Cassette / Tape Decks 2 28th January 2010 11:05 AM
Wanted Reel to reel taperecorder DVSAMANT Wanted 1 21st January 2010 05:56 AM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198
