HiFiVision.com - Audio Video Hi-Fi Forum
Which component cable (5-RCA or 3-RCA)
Discuss Which component cable (5-RCA or 3-RCA) at the Digital Cable and DTH within the HiFiVision.com - Audio Video Hi-Fi Forum; hi guys, Simple question - I have Airtel IPTV, but will go for one of ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > AV Sources > Digital Cable and DTH
Digital Cable and DTH Discuss Digital Cable and DTH programming, software and hardware.
Advertise Here
Reply
Thread Tools
  #1
Old 8th July 2010, 11:13 AM
Reputation points: 10
sandys is on a distinguished road
hi guys,
Simple question - I have Airtel IPTV, but will go for one of the HDTV options in the next month or so.
Which RCA cable (no HDMI option available!) to buy so that I get audio and video on my HDTV ?
Would this be sufficient - PREMIUM 6FT 5-RCA Component Video/Audio Coaxial RG-6 18AWG 75Ohm CL2 Rated Cable
Or should I get a 3-RCA video cable with S/PDIF. If yes, then is this the correct S/PDIF cable - 6ft High-quality Coaxial Audio/Video RCA CL2 Rated Cable - RG6/U 75ohm (for S/PDIF, Digital Coax, Subwoofer & Composite Video)
or is it http://www.monoprice.com/products/pr...t=1#largeimage
Just for research purposes, google turns up Airtel IPTV STB with port descriptions at http://www.airtel.in/IP-TV/airteltv_YourSTB.htm
what is the best non-HDMI option ?
Sponsored Ads
  #2
Old 8th July 2010, 03:42 PM
Reputation points: 14
server3249 is on a distinguished road
Re: Which component cable (5-RCA or 3-RCA)
Quote:
Originally Posted by sandys View Post
hi guys,
or is it For only $3.67 each when QTY 50+ purchased - PREMIUM 6FT Optical Toslink Cable w/ Metal Fancy Connector | Toslink to Toslink
Just for research purposes, google turns up Airtel IPTV STB with port descriptions at Digital TV from Airtel
Don't buy anything. See what comes with the kit and then think about it
  #3
Old 8th July 2010, 04:55 PM
Reputation points: 22
navinmra is on a distinguished road
I would recommend a 3 RCA connection and a coax connection cable separately... I just felt that the combo ones doing the round are higher priced than the individual ones and not really value adding. In fact if you want to components to go straight to the TV and the coax to the AV receiver for some reason, you will have a problem with the combo pieces.
  #4
Old 8th July 2010, 05:26 PM
@navinmra, thanks for your reply.
Does that mean most of the S/PDIF out ports are the coax variety ? The one that I see on the Airtel IPTV diagram (that I linked to earlier) looks like it is a male port and I need a female-to-male coax cable.
Any ideas ?
  #5
Old 8th July 2010, 07:52 PM
thekinge's Avatar
Reputation points: 152
thekinge has a spectacular aura aboutthekinge has a spectacular aura about
sandys,
The best option would be to connect the Airtel box using Component (3 rca) cable for video and S/PDIF for audio. However, a couple of questions:
1. From the pictures of your STB in airtel site, it looks like the S/PDIF connection is TOSLINK (optical digital) and not RCA. Have you checked the STB and are you sure its coaxial?
2. Does your TV have digital optical or coaxial input?
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Which component cable (5-RCA or 3-RCA)
Thread Thread Starter Forum Replies Last Post
Where can i get the component cable in chennai..?? naughtyboy Audio & Video Cables 4 6th July 2010 01:57 PM
RCA cable wires (Vs) Component Cables hifi1975 Audio & Video Cables 2 30th March 2010 05:26 PM
Component Video Cable vadiraj Audio & Video Cables 30 13th March 2010 11:06 PM
Purchasing Component & HDMI cable tech2010 Digital Cable and DTH 5 10th January 2010 07:55 AM
Component Cable Problem frnd08 Audio & Video Cables 12 1st May 2009 07:18 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199
