| Discuss connecting Airtel STB to home theatre using S/PDIF at the Digital Cable and DTH within the HiFiVision.com - Audio Video Hi-Fi Forum; Hi Friends, I just wanted to know how do you connect your AIRTEL HD sound ... |
| Digital Cable and DTH Discuss Digital Cable and DTH programming, software and hardware. |
Thread Tools |
#1
Hi Friends, I just wanted to know how do you connect your AIRTEL HD sound output with 5.1 home theatre system. The AIRTEL box has S/PDIF output. Any ideas? Thanks, Rohit |
| Sponsored Links |
#2
Re: connecting Airtel STB to home theatre using S/PDIF
Hi Rohit
SPDIF means it is an Optical Out. It is also known as a TosLink connection. If your AV receiver has an Optical In jack, you can get an optical cable and use this to connect the HD STB to your AV receiver. The receiver will automatically decode the 6 channel sound and give the output through your speakers and subwoofer. Alternatively, since the Airtel HD STB also has HDMI out, and if your AV receiver can pass through audio using HDMI, you can simply connect the HDMI out from the Airtel HD STB to your AVR's HDMI in, and connect the HDMI out from your AVR to your TV (if your TV has HDMI). The AVR will then pass through the video (or upscale depending on the model of the AVR and its features) to your TV, and give the output to your speakers. If on the other hand your AVR does not support audio thru HDMI, then you can connect the HDMI out from your STB directly to your TV and the optical out from the STB to your AVR. Most AVRs have at least one optical in port. Hope that helps and I haven't confused you! ---Venkat |
#3
Hi Venkat,
Thanks for the information. Unfortunately I have a very basic philips 5.1 and it does not have a optical input. So in this case I will have to change my AVR am i right |
#4
does it have coaxial digital audio-in?
SPDIF has 2 variants.. optical and coaxial.. optical to coaxial converters are available.. in that case you don't need new AVR.. |
#5
Hi Alok,
I doubt my AVR has an coaxial digital in. But I will check Thanks, Rohit |
#6
Does the Airtel HD STB really have 5.1 suround sound (let alone 7.1 as they claim)? I connected my STB to the AVR and the AVR shows that the source is in Stereo. I used a HDMI cable for the connection.
#7
Quote:
This would mean that It doesn't have a DAC, I wonder if we can still call it an AVR then. Last edited by gurubhai; 3rd August 2010 at 01:44 PM. |
#8
Quote:
I got my Airtel HD STB activated on the weekend as it came free with my LG 50PJ560 plasma. I am quite happy with the quality of Nat Geo HD, but like you said, the sound does not seem to be DD 5.1. Even my Yam 459 AVR shows it as stereo and defaults to Prologic mode which is basically fake 5.1 as it splits a stereo signal into the 5 speakers. Since my AVR does not have HDMI (2007 model), I have connected the STB's HDMI out to the plasma and the Coaxial Digital Out from the STB to the Coaxial Digital In of my AVR. The AVR clearly shows "Dolby Digital" and "DTS" when it receives those signals. It even shows "DTS 96/24" from my DTS demo DVD. Should we raise this as an issue? Cos this is contrary to their ads where they keep saying it is in DD Plus 7.1 surround! ---Venkat Last edited by VSG12777; 3rd August 2010 at 02:30 PM. |
#9
yes, i have encountered the same problem. i have also got an yamaha AVR which shows Dolby Digital and indicates the small emblems of six speakers when dd signal is fed in thru coaxial. i think airtel is bluffing, as they know very well that very few people in general population has true idea about what really " DD Plus 7.1" is.
#10
u can post the pics of the connectors at the back of both philips and the stb.
| Bookmarks |
| Thread Tools | |
Similar Threads for: connecting Airtel STB to home theatre using S/PDIF
| Thread | Thread Starter | Forum | Replies | Last Post |
| How to enable EMU-0404 USB S/PDIF out in Vista? | ajinkya | Portable Audio Players & Accessories | 1 | 10th April 2010 11:52 PM |
| BigBazaar offers FREE Airtel DTH home demo | BLASTO | Digital Cable and DTH | 1 | 2nd February 2010 09:49 PM |
| Home theatre pc | Eddierockks | What Should I Buy? | 8 | 8th October 2008 04:43 PM |
| Can i connect a Notebook via S/PDIF? | tinny9 | Home Theater | 11 | 27th June 2008 12:32 PM |
| S/PDIF out | dichkaun | Audio Video Accessories | 5 | 18th June 2008 12:07 PM |
