Connecting Airtel HD recorder thru HDMI cable.
Discuss Connecting Airtel HD recorder thru HDMI cable. at the Digital Cable and DTH within the HiFiVision.com - Audio Video Hi-Fi Forum; Hi guys, I brought the Airtel HD recorder connection a week ago...ihave a full HD ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > AV Sources > Digital Cable and DTH
Digital Cable and DTH Discuss Digital Cable and DTH programming, software and hardware.
Advertise Here
Reply
Bookmark and Share Thread Tools
  #1
Old 19th February 2011, 01:06 AM
Reputation points: 10
n70me is on a distinguished road
Hi guys,
I brought the Airtel HD recorder connection a week ago...ihave a full HD LCD tv but the airtel guys didnt give me HDMI cable..donno if this happens for all..i want to connect the STB thru HDMI cable .I have below questions on this.
1.Will there be any significant improvement in sound,picture quality by connecting thru. HDMI cable instead of the normal 3-cable wire.
2.If its worth buying a HDMI cable...can anyone suggest a gud HDMI cable..suitable for DTH.
Please give me suggestions
Sponsored Links
  #2
Old 19th February 2011, 04:46 PM
Banned
Reputation points: 279
prankey is a jewel in the roughprankey is a jewel in the roughprankey is a jewel in the rough
Re: Connecting Airtel HD recorder thru HDMI cable.
You can buy any cheap HDMI cable if it works. Its a digital connection so if you get proper sound and video it will work (without any quality issues at all). You could use component output to get analog HD picture, however if you are using composite (single video cable) with LR stereo to your TV, it will only give you interlaced SD picture which will be upto 5 times inferior than 1080i.
I hope you are talking of regular DVR offered by Airtel having HDMI output or is it a NEW true HD recorder?
  #3
Old 20th February 2011, 12:23 AM
I still didnt undertand the above reply.Iam using a RCA cable right now..iam not sure on wat to call ..composite?component?..it has three wires...with red,white and yellow colored sockets....wat iam asking is if a HDMI cable instead of the RCA cable will give any improvement in picture quality and sound ...yes i have a DVR HD box that Airtel normally gives wid HDMI port....donno if they are offering a True HD box.
  #4
Old 20th February 2011, 01:13 AM
Reputation points: 15
garfield is on a distinguished road
The red and white cables carry audio and the yellow one carries a composite video feed. The quality of the composite video is the least of all the outputs available. HDMI will give you the best quality and will transmit audio as well if you have a suitable TV or receiver. Through a single cabel at that.
  #5
Old 20th February 2011, 05:24 AM
Banned
Red for Right side speaker sound, White for Left side speaker sound, Yellow for Picture or Video. This gives you about 5 times less picture quality and bit inferior sound. Recommended is to purchase an HDMI cable to get the best quality from both HD and normal channels.
Let us know if you have more questions.
  #6
Old 20th February 2011, 08:34 AM
AUTOMATIX is on a distinguished road
I too have brought Airtel DVR.My pana v20 recognises the input signal as 560p.Can any one tell me whether this DVR is HD or.....The manual does not mention anything about HD.Airtel helpline says its HD but did not clarify the resolution it can display explicitly.Can any one tell me what is the resolution of CWC broadcast on ESPN star cricket.If its 560p its is ok else I will change the DVR by HD STB.Thx to the gurus in advance.
  #7
Old 21st February 2011, 10:29 PM
Quote:
The Airtel DVR is SD. The manual clearly states output resolution on HDMI is fixed at 576p. This is SD PAL. Does not mention HD anywhere on the Box.
The Airtel HD box does not mention the resolution inside. Hope it is HD but I am not sure. My receiver will tell me once it is activated tomorrow. I will raise hell with Airtel if it is not HD.
  #8
Old 28th February 2011, 05:24 PM
Can some help me on ...the specifications that i need to look while buying a HDMI cable or will any HD cable suffice.
  #9
Old 1st March 2011, 04:48 PM
Reputation points: 61
zervinb will become famous soon enough
If the DVR is not HD, then connecting an HDMI cable instead of your current connection (composite cable) is not going to improve picture quality. According to previous posts, your box is going to output SD over HDMI, so no sense in getting an HDMI cable.
Not that you cannot connect an HDMI cable, but it will be no different than your current connection, at least with this box which does not output HD.
  #10
Old 5th March 2011, 11:27 PM
I guess it is a HD....also why is the HDMI port provided ..if its an SD?
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Connecting Airtel HD recorder thru HDMI cable.
Thread Thread Starter Forum Replies Last Post
Connecting Sony DAV-DZ510 to airtel DTH audio out pravk Audio Video Accessories 10 9th March 2012 11:49 AM
DAC Speaker Cable Price and 40' HDMI cable for Home Theater iluvmusic Audio & Video Cables 4 6th January 2011 10:38 AM
connecting Airtel STB to home theatre using S/PDIF rohitr Digital Cable and DTH 16 14th August 2010 03:53 PM
Any HDMI cable from BJC better than the bundled cable with Oppo-83? Help. max123_ind Audio & Video Cables 1 27th July 2010 12:23 AM
Airtel Digital Recorder launched Spidey Digital Cable and DTH 0 22nd April 2010 06:38 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
Recommended Websites - www.HiFiMART.com - www.ProSoundVision.com
