HiFiVision.com - Audio Video Hi-Fi Forum
How to connect tata sky to AV receiver
Discuss How to connect tata sky to AV receiver at the Digital Cable and DTH within the HiFiVision.com - Audio Video Hi-Fi Forum; Hi, I have TATA sky connection which is connected to my sony LED tv. I ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > AV Sources > Digital Cable and DTH
Digital Cable and DTH Discuss Digital Cable and DTH programming, software and hardware.
Advertise Here
Reply
Bookmark and Share Thread Tools
  #1
Old 14th April 2011, 04:32 PM
amitzhankar's Avatar
Reputation points: 12
amitzhankar is on a distinguished road
I have TATA sky connection which is connected to my sony LED tv. I also have an home theater system. i want to connect the TATA sky to my AV receiver ie. onkyo TXSR-608 for watching movies and listing music. pls adivce me.
Thanks in advance.
Amit Zhankar
Sponsored Links
  #2
Old 14th April 2011, 05:05 PM
Reputation points: 34
mailalok is on a distinguished road
Re: How to connect tata sky to AV receiver
If you have the TS SD box then you have only option to connect using analog stereo connection (the red and white cable). If you have HD or HD plus box then you can use HDMI , Coaxial or optical out connection to your AVR.
  #3
Old 14th April 2011, 06:00 PM
Reputation points: 71
zervinb will become famous soon enough
If you have Tata Sky+ HD, then connect the box to the receiver using coaxial cable (a simple RCA cable). The HDMI port of the HD+ box does nnot output Dolby Digital. Hence the coaxial connection is required. HDMI can be connected directly to the TV.
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: How to connect tata sky to AV receiver
Thread Thread Starter Forum Replies Last Post
Tata Sky launches Tata Sky+ HD at just Rs. 3999/ Jigneshg Digital Cable and DTH 546 24th July 2012 10:02 PM
Connect Tata Sky+ HD STB to Panny 42V20D using Viera Link rajanvinod Digital Cable and DTH 13 12th September 2011 01:19 AM
Help required for buying a 5.1 channel audio system to connect to my Tata Sky HD cosmoss_1974 Speakers 3 12th September 2010 07:08 PM
Tata Sky through AV receiver Ajit Digital Cable and DTH 5 21st January 2009 11:16 AM
How do I connect Onkyo 506 Receiver to the HDMI Up-scaling Player rreddy18 Blu-ray/DVD players & DVD/hard-disk recorders 12 31st October 2008 01:19 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189
