HiFiVision.com - Audio Video Hi-Fi Forum
Problem in Tata Sky Set top box...
Discuss Problem in Tata Sky Set top box... at the Digital Cable and DTH within the HiFiVision.com - Audio Video Hi-Fi Forum; Hi, i just came to know from my mom that the TS set top box ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > AV Sources > Digital Cable and DTH
Digital Cable and DTH Discuss Digital Cable and DTH programming, software and hardware.
Advertise Here
Reply
Thread Tools
  #1
Old 6th December 2011, 09:32 AM
Reputation points: 20
Vagabond is on a distinguished road
i just came to know from my mom that the TS set top box giving problems...
After working for say 5 - 10 mins its shows big red light (same place when switched off light is shown) and the it gets off !!
I am away from home and need your help .. plz...
Sponsored Ads
  #2
Old 6th December 2011, 09:34 AM
Re: Problem in Tata Sky Set top box...
update:
my 7 std nephew read ---> dvv ssu + s loader
new software being downloaded
do not switch off...
is everything okay ??
  #3
Old 6th December 2011, 09:38 AM
nindo's Avatar
Reputation points: 81
nindo will become famous soon enough
this has happened a couple o times in my airtel hd box as well. its actually downloading a new software and you are not supposed to fiddle with it (and the remote) till the downloading and installing is over.
it will automatically start after the installing is done. leave the STB on for at least 45 mins. if it does not start on its own even after, say an hour, the best solution - call customer care..!
  #4
Old 6th December 2011, 09:40 AM
baijuxavior's Avatar
Reputation points: 1567
baijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant future
Wait for the software upgrade to complete. If problem still persists after the upgradation then you need to repair it.
  #5
Old 6th December 2011, 09:57 AM
Reputation points: 26
danccc is on a distinguished road
If it gets stuck at 0% or anywhere else, switch off the box, remove all cables, power cable, HDMI cable, and the cables coming in from the dish. Wait for a few minutes and plug in again with the cables. It will restart the download.
It worked for me yesterday.
  #6
Old 6th December 2011, 10:04 AM
wow ! quick response guys....
i just called, it downloaded completely now working fine since last 10 mins...
i will update if it goes off again...
thanks a ton guys...
  #7
Mean while can u guys tell me whats this new update bring us to table ???
  #8
Old 6th December 2011, 10:49 AM
Reputation points: 1328
omishra has much to be proud ofomishra has much to be proud ofomishra has much to be proud ofomishra has much to be proud ofomishra has much to be proud ofomishra has much to be proud ofomishra has much to be proud ofomishra has much to be proud ofomishra has much to be proud ofomishra has much to be proud of
Quote:
It seems I got new problem. Irrespective of whatever we were watching, after going to standby and again ON, it moves to channel no. 100 always. I am not sure whats happening.
  #9
Old 6th December 2011, 11:00 AM
Reputation points: 23
buxx is on a distinguished road
^ as the IT guys here will tell ya: " its not a bug , its a feature "
LOL !
  #10
Old 6th December 2011, 11:45 AM
Reputation points: 10
susancts is on a distinguished road
I have come across the similar problem with my Tata Sky set up box which I have been using for past few months. However, it is not often it creates a nuisance. But one thing which I am really unhappy about is its remote control as you have to press too hard to check the guide and surf channels.
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Problem in Tata Sky Set top box...
Thread Thread Starter Forum Replies Last Post
Tata Sky launches Tata Sky+ HD at just Rs. 3999/ Jigneshg Digital Cable and DTH 546 24th July 2012 10:02 PM
Series Link problem in Tata Sky Plus SD. Even repeat telecast getting recorded... hiteshkkk Digital Cable and DTH 3 23rd March 2011 05:15 PM
Tata Sky Plus + Jagat Digital Cable and DTH 53 4th June 2009 01:03 AM
Tata Sky vs Big Tv nitinbose Digital Cable and DTH 50 1st February 2009 09:45 AM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199
