HiFiVision.com - Audio Video Hi-Fi Forum
Dish TV launches USB recording on existing HD STB via firmware upgrade
Discuss Dish TV launches USB recording on existing HD STB via firmware upgrade at the Digital Cable and DTH within the HiFiVision.com - Audio Video Hi-Fi Forum; All, Dishtv has launched a new feature by which via normal software upgrade the existing ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > AV Sources > Digital Cable and DTH
Digital Cable and DTH Discuss Digital Cable and DTH programming, software and hardware.
Advertise Here
Reply
Bookmark and Share Thread Tools
  #1
Old 4th February 2012, 02:02 AM
haisaikat's Avatar
Reputation points: 462
haisaikat is a glorious beacon of lighthaisaikat is a glorious beacon of lighthaisaikat is a glorious beacon of lighthaisaikat is a glorious beacon of lighthaisaikat is a glorious beacon of light
All,
Dishtv has launched a new feature by which via normal software upgrade the existing HD set top boxes would be recording capable and that too on a USB drive that can be connected to the existing USB port at the back of the STB.
The recording option needs to be activated via SMS one time and a separate remote of Rs 300 needs to be ordered. As per dish tv this will allow recording which will be limited only by the capacity of the external drive(s) but it seems these recordings will not be readable via PC later on. Yet to check, will try ordering the remote over the weekend.
:: Dish truHD plus ::
The Following 4 Users Say Thank You to haisaikat For This Useful Post:
Sponsored Links
  #2
Old 5th February 2012, 08:28 PM
Reputation points: 17
Kapz is on a distinguished road
Re: Dish TV launches USB recording on existing HD STB via firmware upgrade
It's a good option. Here is my take on it:
- It requires a dedicated USB HDD/pen drive which will be formatted by the STB for sole use on the STB. In my book, that's like wasting a resource.
- All recordings will be encrypted. I am not sure if you can copy these recordings to another disk for sharing. Essentially, these recordings will be playable only by the STB which recorded them.
- No recording on MoD.
These are negatives as far as I am concerned. Only those "muffins" whose wives demand to see "Don" might be the ones interested in such an upgrade.
The Following User Says Thank You to Kapz For This Useful Post:
  #3
Old 6th February 2012, 12:20 PM
haisaikat's Avatar
Hi Kapz,
I think the the negatives you have posted are true for all present day Set Top Boxes having DVR option.
Moreover one contradicting negative point you have posted is that it will not record movie on demand but at the same time you have said that it will be of use to watch Don at 3am which is a Movie on Demand service once again.
Some obvious advantages that I saw and ordered immediately are below
1. Cost wise this is the cheapest option of all presnet hay DVR STBs in market. While others sell it at around INR 4000, dish is offering at around INR 2500 by eliminating the in built HDD, only upgrade cost is the 300 INR remote control with 4 additional buttons to control recording.
2. It is upto me to decide whether I will put a 400 INR pen drive to start with or a more higher capacity HDD, of course I do not expect it to support HDDs in TB range but will post this feedback once my remote comes.
3. If I run out of space then I would have options to add more space but adding another HDD which existing DVRs on other STB do not offer easily since their HDD is fitted inside the box so you have to live with whatever you are given with initially.
4. On the other hand this DVR option is very useful for persons like me who like to watch Bollywood songs on HD channels like MTunes HD, I can record individual songs and build my song library which I can get to play the same way via my TV and AVR (audio passthrough from STB). Now whether it is in portable HDD that I play via XBMC or some other player or via STB should not matter since end of the day it is playing on my TV. I do agree that others cannot share my items but for me only encrypted songs will not be much of a problem. I can even record documentaries / etc from Nat Geo HD / Discovery HD / CID on Sony / Travel XP HD for viewing later on, not to mention scheduled recordings.
Whether Dish HD users can exchange such recordings I am not sure and probably would have to find out after some more R&D.
The Following User Says Thank You to haisaikat For This Useful Post:
  #4
Old 6th February 2012, 08:05 PM
haisaikat, I agree to all your points and do not deny at all the VFM nature of TruHD+. When I wrote about "Don", I was merely refering to an ad
Here is how I think STB is going to work for HDD/pen drive:
When you connect the media in USB slot, STB will recognise it and proceed to format it. What will be the file system of this formatted media (Fat/NTFS/Ext3), is not known.
After formatting, it is going to convert the media into a virtual drive (like steganos does, I am only thinking here). So when you take this media to your PC, PC will not see the virtual drive.
Once you get your remote, do give an update on whether you need to input any encryption key or that option too is taken away from user.
For me, personally, if the recording can't be shared, its of no use. Later, when all pseudo HD channels get converted to real HD, I might get convinced and go for it. Till then, I guess I am gonna wait and watch.
  #5
Old 6th February 2012, 09:13 PM
haisaikat's Avatar
okay sure, I think I will be able to post some feedbacks earliest by coming weekend.
I do not expect it to be shareable content like you said.
My target for recording will be the true HD channels only. Regarding size of recordings etc I will post them once I get it.
  #6
Old 6th February 2012, 09:51 PM
Reputation points: 42
k2max6 is on a distinguished road
Its a great move. Wish airtel digital tv also comes out with something similar,then i won't have to shell out 4k for the dvr.In anycase i have a number of pen drives lying extra with me which will come to use.
But won't it take away some market share of the DVR?
  #7
Old 6th February 2012, 10:05 PM
spirovious's Avatar
Reputation points: 1853
spirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant future
Thats good news.I hope ,airtel does the same.
  #8
Old 7th February 2012, 12:51 AM
Reputation points: 62
yrk1969 will become famous soon enough
If it does not have two tuners (??), then it utility is limited, e.g you can't record a channel in the background while watching another live.
  #9
Old 7th February 2012, 09:53 AM
Reputation points: 15
terence_fdes is on a distinguished road
I think we need to be patient and watch out for a "Full-Review" about the new DishTV + Unlimitted Recordings on external usb drives. I am basically interested in
1] Quality of recording in HD - 1080p & how much size/space would say a 1 hour programme take up.
2] What is the largest capacity drive it can handle - 1 to 3 TB ?
3] Programmed/Timer recording option - while I continue to watch any other thing on my TV (say, another channel/s; or a movie from my Media Player or Blu-ray)
Note: Tata Sky came out with the same option and If I remember well, there were countless guys on this forum who went gaga over it and pre-booked the system in 1000's ?
  #10
Old 7th February 2012, 11:05 AM
nindo's Avatar
Reputation points: 81
nindo will become famous soon enough
Quote:
airtel, as told to me by their engineer, is soon going to offer a firmware upgrade for their HD STBs (at least AFAIK) which will enable USB (which it already has) recording/reading and LAN support as well- but don't know the extent to which the LAN will be useful. He could not tell me whether it will enable full internet browsing or will give access to certain apps/services provided by airtel through internet.
none-the-less when one has done it, others will follow suit by default, sooner or later.
Reply
Bookmarks
Tags
dish hd plus, dth recording, recording, usb, usb recording
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Dish TV launches USB recording on existing HD STB via firmware upgrade
Thread Thread Starter Forum Replies Last Post
Onkyo HT-S3400 Firmware upgrade ? travel_living Home Theater 9 7th October 2012 04:33 PM
Dish TV launches 30 channels on HD format mgdelhi Digital Cable and DTH 104 4th November 2011 09:56 PM
Samsung LCD firmware upgrade problem slycooper Television 0 25th October 2011 11:29 AM
anybody tried to upgrade firmware on AVR jayad08 Surround Amplifiers/Receivers 10 12th July 2010 03:12 AM
Firmware upgrade. techgadgets4379 Blu-ray/DVD players & DVD/hard-disk recorders 1 6th April 2009 07:28 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189
