hathway stb problem
Discuss hathway stb problem at the Digital Cable and DTH within the HiFiVision.com - India's Audio Video Hi-Fi Forum; hi guys i back with a new problem.i got a hathway stb few weeks ago ...
Go Back   HiFiVision.com - India's Audio Video Hi-Fi Forum > AV Sources > Digital Cable and DTH
Digital Cable and DTH Discuss Digital Cable and DTH programming, software and hardware.
Advertise Here
Reply
Thread Tools
  #1
Old 3rd November 2008, 09:28 PM
mjamal14 is on a distinguished road
hathway stb problem
hi guys i back with a new problem.i got a hathway stb few weeks ago .the picture was fine for some days,the it started getting stuck .the picture became really bad as well as the audio. sometimes the picture is good but its like once in 2 3 days.all connections are fine .is it a problem with my cable or should i modify signal setup or somethin.help me out guys please. cheers
Sponsored Links
  #2
Old 4th November 2008, 11:01 AM
doors666's Avatar
doors666 will become famous soon enough
Re: hathway stb problem
I also have the hathway stb. There is a signal selection in the menus of the box, try to choose different signal, it also shows the signal strength. If connections are fine and the settings are also fine, just the call the hathway guys, they will come and fix the issue.
  #3
Old 19th October 2009, 06:27 PM
deepak is on a distinguished road
some channels in tv stand still and some channel gives message of no signal.
always i need to adjust the 3 pin wire behind the stb to view that channel clear. without adjusting it is not possible view all channel without disurbance.
how this problem can be solved
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: hathway stb problem
Thread Thread Starter Forum Replies Last Post
Hathway single-channel audio? sqvare Digital Cable and DTH 10 22nd April 2010 08:01 PM
Hathway ground loop issue? smnrock Digital Cable and DTH 7 28th February 2010 06:00 PM
Hathway Set Top Box psj Digital Cable and DTH 4 15th October 2009 03:41 PM
problem with NAD 525 BEE AMP moktan Amplifiers 31 4th September 2009 09:29 PM
Cisco setup box with hathway?? insane79 Digital Cable and DTH 0 17th December 2008 03:56 AM
Advertise Here
Copyright © 2006-2010, HiFiVision.com All Rights Reserved.
Recommended Websites - www.CameraVision.in
