HiFiVision.com - Audio Video Hi-Fi Forum
tips to increase picture quality in led tv
Discuss tips to increase picture quality in led tv at the Digital Cable and DTH within the HiFiVision.com - Audio Video Hi-Fi Forum; I own a Samsung ua40d5006 led tv and connected videocon d2h to it. The problem ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > AV Sources > Digital Cable and DTH
Digital Cable and DTH Discuss Digital Cable and DTH programming, software and hardware.
Advertise Here
Reply
Bookmark and Share Thread Tools
  #1
Old 28th July 2012, 11:02 AM
Reputation points: 11
ramvalleru is on a distinguished road
I own a Samsung ua40d5006 led tv and connected videocon d2h to it. The problem is am not able to enjoy the television channels like in my previous CRT. When I check the showrooms they are playing well. Is there any optimal settings I should make or avr receiver will do the job
Sponsored Links
  #2
Old 28th July 2012, 11:08 AM
Reputation points: 292
aakashr is a jewel in the roughaakashr is a jewel in the roughaakashr is a jewel in the rough
Re: tips to increase picture quality in led tv
Quote:
sorry to disappoint you but CRT tv's are made for SD signals, so cable will always look best on CRT compared to flat panel tv's. Your LED tv is built for HD and will excel with HD content. If you have not already subscribed for HD, I suggest you do.
Also, in showrooms you might have seen HD channels being played hence the difference.
The Following User Says Thank You to aakashr For This Useful Post:
  #3
Old 28th July 2012, 11:30 AM
Now dish providers are providing only few hd channels and If I subscribe to hd then I would watch star movies, movies now in hd and hence waste of money. Purchasing an avr will do the job as amplification is also built in it
  #4
Old 28th July 2012, 11:31 AM
baijuxavior's Avatar
Reputation points: 1520
baijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant futurebaijuxavior has a brilliant future
You need HD channels or HD content to see the best PQ on your HD TV. SD channels look better on CRT TVs. It is like watching mobile phone clips on a computer display. The clip may seem of great quality when watched on that small mobile screen, but not so on the bigger display.
Adding an AVR won't improve the picture quality. The AVR just acts as a switch to select hdmi inputs and to process audio. There are some AVR models with video upscaling feature, but nothing comes close to original HD content.
  #5
Old 28th July 2012, 12:14 PM
+ 1 to baiju
Adding an AVR will not help.........its always GIGO : garbage in garbage out. If the original signal is weak and of poor quality, upscaling by the AVR might make it look slightly better but will never be able to convert SD to HD. Entry level AVR's mostly use Faroudja chip for upscaling which is not of great quality. Higher end AVRs use HQV Reon which is better but can never be the same as true HD content.
If you want to truly enjoy HD, you need to get HD channels..........which I understand is increasing.
  #6
Old 28th July 2012, 12:18 PM
Yes I don't need true hd but upscaling. I'm going for Bose 201 v series and am limited to 22k for an avr which should into for
  #7
Old 28th July 2012, 12:51 PM
Shivam's Avatar
Reputation points: 513
Shivam is a glorious beacon of lightShivam is a glorious beacon of lightShivam is a glorious beacon of lightShivam is a glorious beacon of lightShivam is a glorious beacon of lightShivam is a glorious beacon of light
Not related to your original query but -
Have you tried any other speakers before opting for Bose 201 v ?
  #8
Old 28th July 2012, 01:15 PM
You have another thread for BOSE speakers.............suggest to use that for it. As much as everyone is trying to guide you NOT to go for BOSE, you seem to have your mind fixed on them. In the end it has to make you happy..............we are just trying to guide you, but it has to be ur decision. Many have regretted after buying BOSE after realizing what their limitations are.
  #9
Old 28th July 2012, 03:12 PM
Reputation points: 96
viper08 will become famous soon enough
Thumb Rule: Any output can not be better than it Source. If you want best PQ get the best signal. Upscaling adds artifacts to some extent and results may not close to expectations.
My 480P (Faroudja Chip) projector does a fantastic job when playing DVDs(480P by nature) and its awesome for HD (DVI) as well. Same 480p DVDs on 1080P tv simply look pathetic using even upscaling player.
There is no other option other than good old CRT to watch SD to its fullest.
  #10
Old 30th July 2012, 10:27 AM
Reputation points: 10
gvsriks is on a distinguished road
I assume your LED Tv must be already doing upscaling if you provide SD signal before displaying as it is HD resolution.
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: tips to increase picture quality in led tv
Thread Thread Starter Forum Replies Last Post
Simply put.. Best available hd dth for picture quality karansfi Digital Cable and DTH 39 28th July 2012 11:52 AM
best picture quality for flat screen tv salbev What Should I Buy? 7 23rd June 2011 06:35 PM
Media Player with best picture quality pseudophile Media & Streaming Players 19 2nd November 2010 07:00 PM
Component Picture Quality spiderman Television 14 23rd February 2009 10:43 AM
Picture Quality - DVD vs high quality downloads sud98 AV Lounge 3 28th January 2009 07:49 AM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189
