| Discuss Coaxial or Analog L&R at the Digital Cable and DTH within the HiFiVision.com - India's Audio Video Hi-Fi Forum; Hi, I am using Marantz A/V Receiver 5002 and Marantz 4001 DVD player. Have had ... |
| Digital Cable and DTH Discuss Digital Cable and DTH programming, software and hardware. |
Thread Tools |
#1
Hi, I am using Marantz A/V Receiver 5002 and Marantz 4001 DVD player. Have had a lil' confusion over the sound connection. I mean which cable should I use? I have been using Coaxial Cable to connect my DVD player to receiver, which is working fine. However, few formats don't play sound for instance MPEG, or even with the VCD. The message I get in A/V Receiver is "NO AUDIO". Someone told me to use the coaxial cable instead of Analog L&R for audio connection in order to get a better sound especially for DTS and Dolby Digital. Please suggest which connection should I use to connect without compromising the sound quality. Also, which brand (specs) should I use for either of the above mentioned connection. Thanks, Rohit |
| Sponsored Links |
#2
Re: Coaxial or Analog L&R
Hi Rohit
If you are connecting from a Digital Coax 'out' on your DVD to a digital coax 'in' on your AVR, this will allow you to listen to 5.1 surround sound. You should not be using audio (a single strand of red/white pair or red/black pair) to connect to this outlet since these cables have lower impedence and are not meant to do the job. You could however connect from L/R on your DVD player using these thinner audio cables (red/white pair) to the corresponding L/R outlet of the AVR called as the "CD" connection. This will however give you 2 channel or stereo sound only. The key is to connect the appropriate outlets Digital Coax to Digital Coax. CD L/R to CD L/R. Quote:
| The Following User Says Thank You to marsilians For This Useful Post: | ||
Rohit Verma (26th February 2009) | ||
#3
Quote:
Cost from Rs.700 |
#4
Infact should perform better
| Bookmarks |
| Thread Tools | |
Similar Threads for: Coaxial or Analog L&R
| Thread | Thread Starter | Forum | Replies | Last Post |
| OPPO DV-980H , 7.1 Analog sound Output | mandeep | Speakers | 10 | 11th February 2010 09:41 PM |
| optical to coaxial switch | vint | Audio & Video Cables | 12 | 26th January 2009 11:22 AM |
| Coaxial Digital Audio Outputs | ajithlal | DVD players & DVD/hard-disk recorders | 9 | 21st September 2008 09:10 PM |
| DVD player with best 5.1 analog and component video within 10k | amol12 | DVD players & DVD/hard-disk recorders | 8 | 11th August 2008 02:23 PM |
| upscalling analog video to 1080p through av reciver | gr_babu | Surround Amplifiers/Receivers | 7 | 27th May 2008 09:37 AM |
