HiFiVision.com - Audio Video Hi-Fi Forum
Tata Sky+ HD WiFi Dongle @ Rs.100/-
Discuss Tata Sky+ HD WiFi Dongle @ Rs.100/- at the Digital Cable and DTH within the HiFiVision.com - Audio Video Hi-Fi Forum; Originally Posted by just4kix You will have to activate your account first. The dongle is ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > AV Sources > Digital Cable and DTH
Digital Cable and DTH Discuss Digital Cable and DTH programming, software and hardware.
Advertise Here
Reply
Thread Tools
  #31
Old 10th July 2013, 07:52 PM
vishaltanksale's Avatar
Reputation points: 14
vishaltanksale is on a distinguished road
Re: Tata Sky+ HD WiFi Dongle @ Rs.100/-
Quote:
Originally Posted by just4kix View Post
You will have to activate your account first. The dongle is only for connecting to internet to download VOD (paid) content.
This also required for mobile remote using android /ios mobile app on WiFi.
Sponsored Ads
  #32
Old 10th July 2013, 09:54 PM
Reputation points: 10
thamizh is on a distinguished road
I am also using wired Internet on my tatasky HD+. This Internet connection enabled me to use the new tatasky app on my iPad and android phone as a remote control. I can change the channels using my phone or iPad as long as all these devices are connected to the same network. No need to point the phone or the tablet towards the set top box.....!!! This is a great app.
-thamizhavel
  #33
Old 12th July 2013, 07:52 PM
Alby Tommy's Avatar
Reputation points: 67
Alby Tommy will become famous soon enough
Will it support the normal Tata sky HD as I can find a USB port on the front panel?
  #34
Old 12th July 2013, 10:10 PM
just4kix's Avatar
Reputation points: 1719
just4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant futurejust4kix has a brilliant future
Quote:
No. It won't. The dongle is to connect to the network. The driver is with the firmware of the Tatasky+ box. Secondly, it is used to connect to the vod website from where the purchased movie can be downloaded and stored on the hdd of the ts+ box.
  #35
Old 21st July 2013, 11:49 PM
mgdelhi's Avatar
Reputation points: 213
mgdelhi has a spectacular aura aboutmgdelhi has a spectacular aura aboutmgdelhi has a spectacular aura about
Hey guys, can anyone with Tata Sky+ HD, buy a Tata Sky wifi dongle for me, if you are not planning to get one for yourself?
My PC USB Wifi dongle died and this one is working fine on my PC. So need another for Tata Sky.
  #36
Old 1st December 2013, 02:01 PM
Gerry_the_Merry's Avatar
Reputation points: 156
Gerry_the_Merry has a spectacular aura aboutGerry_the_Merry has a spectacular aura about
Any feedback on this service thru the dongle so far? Will be most appreciated.
  #37
Old 19th March 2014, 11:00 AM
HTuser's Avatar
Reputation points: 72
HTuser will become famous soon enough
If I enable WiFi Hotspot on my mobile, can I connect to it using this dongle?
Currently I don't have wifi router at home. I have iphone 5s and planning to connect directly to Tataskty HD+ STB using the WiFi dongle
Anyone tried this?
Rajesh
  #38
Old 19th March 2014, 12:59 PM
Reputation points: 71
zervinb will become famous soon enough
Theoretically, yes. You should be able to connect using WiFi hotspot from your mobile. However, your mobile data will get used quite a lot. Only if you have an unlimited data plan from your mobile provider, will it make sense to go this way.
  #39
Old 19th March 2014, 02:14 PM
HTuser's Avatar
Quote:
I am counting on it. Got the dongle delivered at home today. Need to check in the evening.
I have 3GB Airtel LTE(4G) plan. Beyond 3GB there is a rate limit. But in effect it is like unlimited plan.
More than VoD downloads, I am planning to use the Wifi Connection for using as a remote and accessing the EPG to change channels. This will help me to go through EPG without disturbing the current channel being played on the TV.
Later I will be having broadband connection at home with a wifi router
  #40
Old 20th March 2014, 10:42 AM
HTuser's Avatar
I tested this Yesterday.
STB is able to reach internet and show the VoD contents.
But I am not able to reach the STB from the Tatasky Mobile App.
Even though STB is connected to the hotspot. As per iPhone WiFi configuration it is not connected to any WiFi network. Hence the App is saying that there is no wifi connection to the STB !!
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Tata Sky+ HD WiFi Dongle @ Rs.100/-
Thread Thread Starter Forum Replies Last Post
LG BD 550, WIFI dongle / Adaptor ravidharap Blu-ray/DVD players & DVD/hard-disk recorders 3 23rd April 2013 07:24 PM
Non wifi led + wifi dongle = wifi(smart) ? multi What Should I Buy? 4 7th April 2013 03:58 PM
WIFI Dongle for samsung TV nithin Television 1 28th December 2012 01:10 PM
For Sale Xtreamer Wifi Dongle rajudhs For Sale by Owner 6 16th January 2012 02:09 PM
LG wifi dongle harishbalaji Portable Audio Players & Accessories 0 14th July 2011 04:33 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199
