Hathway Set Top Box
Discuss Hathway Set Top Box at the Digital Cable and DTH within the HiFiVision.com - Audio Video Hi-Fi Forum; Hi, My cable operator does not have stock of Hatway Set top box and doesnt ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > AV Sources > Digital Cable and DTH
Digital Cable and DTH Discuss Digital Cable and DTH programming, software and hardware.
Advertise Here
Reply
Bookmark and Share Thread Tools
  #1
Old 15th October 2009, 01:42 PM
psj psj is offline
Reputation points: 30
psj is on a distinguished road
Hathway Set Top Box
My cable operator does not have stock of Hatway Set top box and doesnt expect it for another couple of months.
Is is possible to buy a Set top box from SP Road or anyplace and use it to view Hathway digital channels using my cable connection or can i do that only with the cable operator provided box?
Please advice.
Sponsored Links
  #2
Old 15th October 2009, 02:38 PM
doors666's Avatar
Reputation points: 405
doors666 is just really nicedoors666 is just really nicedoors666 is just really nicedoors666 is just really nicedoors666 is just really nice
Re: Hathway Set Top Box
Please advice.
do you have the card. its like a credit card that slips inside the set top box. without it, no point.
check on sp road, you might find it there. ask your cable guy for the model number atleast. I know its humax. you can also search for used ones.
  #3
Old 15th October 2009, 03:01 PM
Reputation points: 19
appuchan is on a distinguished road
Please advice.
My cable operator also told me the same thing. I escalated it to their management and threatened to disconnect and it worked. They gave a me STB next day. You can try it out before looking out for third party STB.
  #4
Old 15th October 2009, 03:30 PM
doors666's Avatar
Quote:
I believe they are having issues with stb availability for past few months. Make sure they dont give you a used one or an older model. there are a few models of hathway stbs, check on web.
threatening to change always works, they will find one for you.
whenever hathway doesnt give some channels (usually sports channels during good sporting events), I cut money from the monthly bill at 50/- per missing channel, I basically get cable for 5 sports channels, if he cant provide those, cut money. if he cribs and wants more money, I tell him to take his dubba and get out, that usually calms him down.
  #5
Old 15th October 2009, 03:41 PM
Reputation points: 12
ishlesh is on a distinguished road
Pls call Hathway customer care directly and check.
I faced similar situation with Fastway in Chandigarh.
The Cable operator insisted that Fastway is not supplying them with STBs.
When I called up Fastway - it turned out that the cable operators have to submit certain documents --- Address Proof + CAF to Fastway for every customer provided with STB.
Since the Cable Operator has not submitted the same for existing customers, Fastway was refusing new STBs to that cable operator.
  #6
Old 21st July 2011, 10:04 AM
Reputation points: 10
saratchandrab is on a distinguished road
Hi All,
I stay in Bangalore Whitefield Area and My cable operator always says that the Setup Box is out of stock. The Normal cable is not so good and I dont have an option of changing the cable Operator as well as each area is allocated to one cable operator.
Can I get my own Setup box and ask my operator to Install it.?
Please suggest.
  #7
Old 21st July 2011, 10:10 AM
gobble's Avatar
Reputation points: 770
gobble is a splendid one to beholdgobble is a splendid one to beholdgobble is a splendid one to beholdgobble is a splendid one to beholdgobble is a splendid one to beholdgobble is a splendid one to beholdgobble is a splendid one to behold
Quote:
Originally Posted by saratchandrab View Post
Hi All,
OT but after going through various threads on this I thought that for all providers, the STB digital signal was highly compressed and low bandwidth hence PQ not as good as the older type of signal...?
--G0bble
  #8
Old 23rd July 2011, 08:00 AM
deanandme is on a distinguished road
Hi!
i am new here & i did not know where else to post so i'm doing it here.I am confused as to whether i should choose locl cable STB or dth connection.my budget is maximum Rs250 per month & there are certain channels like axn,hbo that i specifically want.I live in Dumdum in Kolkata.can anyone help?
  #9
Old 23rd July 2011, 09:30 AM
Reputation points: 146
rikhav will become famous soon enoughrikhav will become famous soon enough
Quote:
--G0bble
Agree with you on this
In mumbai we have a local operator named Seven Star.
With the normal cable the colors were more vibrant and picture was sharp. With the STB installed in some channels the picture is very bad (i can literally see pixels even on a CRT) and colors are washed
  #10
Old 23rd July 2011, 09:54 AM
doors666's Avatar
even I had the same problem, change your video cable, you must be using those junk free cables that come with various equipments. get a 100/- mx composite video cable and see your colors getting transformed.
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Hathway Set Top Box
Thread Thread Starter Forum Replies Last Post
Hathway single-channel audio? sqvare Digital Cable and DTH 10 22nd April 2010 08:01 PM
Hathway ground loop issue? smnrock Digital Cable and DTH 7 28th February 2010 06:00 PM
hathway stb problem mjamal14 Digital Cable and DTH 2 19th October 2009 06:27 PM
Cisco setup box with hathway?? insane79 Digital Cable and DTH 0 17th December 2008 03:56 AM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
Recommended Websites - www.HiFiMART.com - www.ProSoundVision.com
