HiFiVision.com - Audio Video Hi-Fi Forum
Help Needed: Tata Sky on my LCD PC monitor
Discuss Help Needed: Tata Sky on my LCD PC monitor at the Digital Cable and DTH within the HiFiVision.com - Audio Video Hi-Fi Forum; which TV Tuner Card to buy? Need your help to connect TATASKY to my computer, ...
Go Back   HiFiVision.com - Audio Video Hi-Fi Forum > AV Sources > Digital Cable and DTH
Digital Cable and DTH Discuss Digital Cable and DTH programming, software and hardware.
Advertise Here
Reply
Thread Tools
  #1
Old 29th January 2010, 10:52 AM
Reputation points: 10
vser is on a distinguished road
Need your help to connect TATASKY to my computer, please help
My Hardware
(1)
TATA SKY dish connection
(2)
HP Core2Duo, 2 GB RAM
19 inch HP LCD MONITOR (HP w1707 wide LCD monitor) (1440 x 900 resolution)
I would like to WATCH TATASKY on my HP w1707 *AND SIMULTANEOUSLY* work on my computer on the same monitor
I understand its possible to use LCD monitor AS *ONLY* TV or *ONLY* computer monitor, but i need to view them both simultaneously
Please help me in selecting the TV Tuner Card or/and other equipment if needed
Internet TV Tuner card? which model and make?
External TV Tuner card? which model and make?
will appreciate your help
Sponsored Ads
  #2
Old 29th January 2010, 11:00 AM
kapvin's Avatar
Reputation points: 332
kapvin is a jewel in the roughkapvin is a jewel in the roughkapvin is a jewel in the roughkapvin is a jewel in the rough
Re: Help Needed: Tata Sky on my LCD PC monitor
You could buy a TV tuner card which has a line in and attach the tata sky to the line in of the tuner card. this would allow you to watch the tata sky feed in a window (or full screen) through your computer. a video capture card would would serve purpose as well, if you can find one that is cheaper.
alternately, you could use the RF out of the STB to connect the tatasky to the TV tuner card, tune the TV to the appropriate channel, which will allow you to get a TV window through your computer. you could then use the line outs of the Tata sky to connect to your monitor directly (provided your monitor supports it/ or through an interface.). this would allow you to get TV on the monitor irrespective of whether the CPU is off or on.
cheers
Kapil
  #3
Old 29th January 2010, 11:18 AM
thanks for your reply
the 2 scenarios you have mentioned, which one will give the BEST picture quality?
also, any pointers to a particular Brand of TV tuner card and model no. (internal or external) that can achieve , would be beneficial to me
regards
  #4
Old 29th January 2010, 02:09 PM
spirovious's Avatar
Reputation points: 1950
spirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant futurespirovious has a brilliant future
You can get avermedia,intex OR pinnacle ext TVtuner box.
Price starts from 2k.
  #5
Old 29th January 2010, 04:56 PM
Reputation points: 437
asliarun is just really niceasliarun is just really niceasliarun is just really niceasliarun is just really niceasliarun is just really nice
A suggestion: Why don't you buy a second monitor (assuming your video card or video chip will support it)? If you get used to working with 2 monitors, you will never go back to a single monitor. 2 monitors are also ideal for the kind of usage you are looking for, and you can get a small one for very reasonable prices. Your current monitor's resolution is also not good enough for you to comfortably tile two windows side by side.
Just a suggestion though
  #6
Old 31st January 2010, 11:36 PM
Reputation points: 329
sud98 is a jewel in the roughsud98 is a jewel in the roughsud98 is a jewel in the roughsud98 is a jewel in the rough
You can do this in an LCD TV. My current TV (Samsung Bordeaux) allows Picture in Picture between TV mode and PC mode.
  #7
Old 1st February 2010, 04:50 PM
Reputation points: 16
gopscreative is on a distinguished road
Go for internal TV tuner card.Pinacle and Avermedia has got good reviews.Using internal TV tuner card wil make u to open the picture in a window and simultaneously u can work with other activities.It wil also enable u to record the content in mpeg2, mp4 and avi formats also.Aver media costs arnd 1.5k and has a composite in.U can connect ur composite out of Tatasky to card's composite in directly .Just check it out.
  #8
Old 1st February 2010, 10:47 PM
sam9s's Avatar
Reputation points: 1089
sam9s has much to be proud ofsam9s has much to be proud ofsam9s has much to be proud ofsam9s has much to be proud ofsam9s has much to be proud ofsam9s has much to be proud ofsam9s has much to be proud ofsam9s has much to be proud of
My Hardware
(1)
(2)
Hauppauge has got some excellent product for TV on PC, and you can watch TV and work simultaniously, that is actually the whole point of having a PC TV, anyway not only you can work/watch at the same time, you also get the full advantage of a PVR (personal video recorder) much like TataSky+ (pause, record and rewind live TV).
And incase you dont know Pinnacle the leading company in Video Products has sold off their PCTV product to Hauppauge. Check out THIS page for current line of products, you can choose one per your needs....
  #9
Old 15th March 2010, 05:37 PM
naripeddi is on a distinguished road
My Hardware
(1)
(2)
Hi, let me tell you what I am using: I use a Pinnacle PCTV USB2.0 (Not produced anymore, but you can go and checkout on their website to see which models are current). It connects to the PC via USB Port. You can connect the Composite output (Yellow cable) of TSky to the Composit input of the Pinnacle PCTV USB. You can also use the S-Video cable to connect TSky and the Pinacle. Coming to the audio, Pinnacle PCTV USB accepts only Line-in, which means you will have to purchase one of those connectors that will connvert your RCA Type audio White or Red cable) into the ine-in port of the PCTV USB. Remember, the PCTV USB accepts only Mono audio. It records mono audio too, but not sterio. I have been successful in recording TSky programs at VCD Quality using this set-up. It is not suggested for DVD -quality video though the product manual says we can record at DVD-Quality.
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads for: Help Needed: Tata Sky on my LCD PC monitor
Thread Thread Starter Forum Replies Last Post
Tata Sky - DVD Quality?? hemantwaghe Digital Cable and DTH 28 27th June 2009 07:39 PM
Tata Sky Plus + Jagat Digital Cable and DTH 53 4th June 2009 01:03 AM
Tata Sky vs Big Tv nitinbose Digital Cable and DTH 50 1st February 2009 09:45 AM
TATA SKY to LCD Monitor sooriya.s DIY 4 7th August 2008 10:33 PM
Tata Sky Anil kumar Digital Cable and DTH 6 1st July 2008 01:47 PM
Advertise Here
Copyright © www.HiFiVision.com 2006 - , All rights reserved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199
